Hovering acts as left mouse click
CuriousOne
I don't know if this is normal but I find it annoying. Using the synaptic touch pad on a Windows 8.1 laptop, I find that if the cursor lingers over an icon or shortcut for a second or so, it sometimes acts as if I had clicked on it. I don't think it is the touch pad sensitivity setting. Is there a separate setting that makes a cursor hover act as a click?
Thank you.
Ztruker
As a test, disable Tap-to-clcik for the touchpad, see what happens.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    [email protected]
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
    Country Flag
    USA
    State/Region Flag
    us florida
CuriousOne
Thank you for replying.
OK, I disabled the touch pad tapping. It will take some time for me to know if this resolves the problem because it doesn't happen all the time.
But, even if it solves it, is there another option because I've gotten very used to double tapping on the Touch pad as a quick way to select or start something and would hate to give it up.
Ztruker
I can't think of anything. I don't remember seeing any sensitivity setting for the touchpad. If there were then decreasing the sensitivity might help.
Tap-to-click is the first thing I turn off when working on a laptop. It drives me crazy.
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    [email protected]
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
    Country Flag
    USA
    State/Region Flag
    us florida
