Home WiFi Internet Speed
Nando Frade
Hello,
I have a high-speed Internet connection at home (100/10). The main computer is connected through an Ethernet cable off a cable-modem, and both the download and upload speeds are excellent, just as the ISP claims it to be.
Then, the afore-mentioned cable-modem is linked to my 300Mbps TP-Link WR1043ND router so that I can get Wi-Fi on my iPhone 5... I have been running several Internet speed tests, and the download speed just won't go any higher than 40Mbps. Upload speed is perfectly fine.
Gone through some tutorials and then all the settings on the router and everything is fine... Plus the iPhone 5 is designed for Wi-Fi ultra-high speeds (well over 100Mbps).
Am I missing something? How come I cannot get any more speed? When I do the tests, the phone is just centimetres away from the router so there's no walls, objects or anything that may slow things down by over 60% as it is the case.
What can I do? Is there any possibilities of getting at least 80% of the maximum speed?
    Windows 8.1 Update Pro (64-bits)
    Custom Built
    MC INTEL 1155 CORE i5 3470 3,2 GHZ
    PB GIGABYTE 1155/GA-H61M-D2H-USB3
    Kingston KVR13N9S8/4 1.5V DDRM3 - 4x4GB (Single-sided)
    ATI Radeon HD 4600 Series
    Realtek High Definition Audio
    HP w2216
    1680 x 1050
    SanDisk SDSSDP128G ATA (128 GB) - Windows 8 OS installed
    ST3000DM001-1CH166 ATA (3 TB) - Data disk
    WDC WD10EACS-65D6B0 ATA (1 TB) - Back-up disk
    800W
    HP Pavillion Elite m9554es
    HP Wireless
    HP Wireless
    50 Mbps / 5 Mbps
    Internet Explorer 11 / Mozilla Firefox / Google Chrome
    Cisco EPC 3825 cable-router in bridged mode that works as a cable modem, which is connected to a TP Link TL-WDR4300 router that serves as a home Wi-Fi network.
Wullail
Active Member
This really isn't a Windows 8 issue , you will need to ask in the TP-Link support area/forums to see how you can change your wifi channels etc to maximise your throughput.
I can say that under normal use you will never get 300 Mbs using wifi , the network overheads and more will reduce that to 180-200Mbs maximum , 300 is a very idealised figure.
As for iPhone 5 , I do remember there were issues with wifi speeds , binarytoad details the issue here iPhone 5 Slow Wifi Fix (workaround) - YouTube
    Windows 8 Pro
    6 GB
    1280 x 1024
    12 TB in 6 disks
    TX650
    G15
    Intellimouse 3.0
    100 Mbits
    Chrome
    Trend Micro
chev65
Closed
Hello,
To get the maximum rated speed from any router it's required that you use the non mixed mode settings which should appear as 802.11n Only, the mixed settings are there to support legacy devices but won't allow for full wireless N speeds.
You can also turn on channel bonding for even better throughput, should appear as 20Mhz-40Mhz setting. Finding a clean channel that isn't being used by the neighbors can also help obtain the best possible wireless speeds.
With these settings and 5 bars signal strength 300Mbps is quite possible though the phone connection may have other limitations, not to mention that using wireless in general will show a connection speed much slower than the ISP's rated speed because you are testing through a 300Mbps wireless connection instead of a 1Gb wired connection.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
