High Hardware reserved memory
khile
Hi all.
Been having an issue for a few months now i have 4gb corsair dominator gt ram installed but my system in only showing 1.96gb usable and looking in resource monitor its showing 2091 mb as system reserved
cpu: OctalCore AMD FX-8120, 4000 MHz
Motherboard Name Gigabyte GA-970A-DS3P
Module Name Corsair Dominator GT CMT4GX3M2A2133C9
Video Adapter AMD Radeon HD 7950 (3gb)
is this a resolvable issue ive reinstalled and problem is still there
Ive tried booting of one DIMM and it boots fine bios shows 4gb as well im stuck
    Windows 8 64Bit
Ztruker
Space coast of Florida
I don't think there is anything you can do about it. I had a similar problem with my Dell Precision 370.
had 4GB ram but only 3GB was useable, 1Gb was reserved and could not be changed.
Lots of hits on Google but not fixes I could find.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
CountMike
Belgrade , Serbia
If you are not running into "free memory error" it's not a big problem because some of that reserved memory will be released when necessary. BTW, with 4GB of RAM with an 8 core processor you are at it's minimum requirements or even under maybe. Normal amount would be 1GB per core, so you may be loosing some of it's performance.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
AddRAM
R.I.P. Gary
The East Coast
What do you mean "For a few months now" ??
Did something change ?
Does windows report 4 GB ?
Every motherboard is different, if you`re not happy with it, by all means scrap it.
That board supports 32 GB of memory, so there`s not reason not to put at least 16 GB in.
GIGABYTE - Motherboard - Socket AM3+ - GA-970A-DS3P (rev. 1.0)
Could you please explain exactly what you mean by your last sentence ????
    Windows 7 Pro x64 Windows 10 Pro x64 Build 9926
    Gateway GT5404
    Intel Core 2 Duo E6700 @ 2.66 GHz
    Intel D945GCL
    4GB PC2 6400 @ 800 MHz CL 6-6-6-18
    MSI GTX660 TF3 2GB
    Realtek HD
    Gateway FPD1975W
    1440 x 900
    Samsung 850 EVO 120GB SSD / WD 500GB
    Corsair HX750
    OEM
    OEM
    Gateway KB-0401
    Gateway MOAKUO
    Verizon Quantum Gateway 60 / 60
    Chrome / IE11
    MSE / Defender / MBAM
