Help???
Davy83
:huh:Hi everyone!! I use VMWare to try out Build 7595 and when I try to set it up it works fine until I get to the page where it asks which OS I would like to install, the space where it should be listed is blank. I'm using a DVD-RW which I burned the download from digitex link. If I skip it I get the cancelled window. I posted the scvreenshots; any ideas as to what's wrong??
    Windows Vista/7/8 Pro
    HP Pavilion a6009n Desktop
    AMD Athlon 64x2 3800 + 2.00GHz
    ASUS M2N68 LA-Narra
    3.50GB
    NVidia GeForce 6150 nforce 430 (onboard)
    Realtek HD
    HP mx 705
    20 kbps
myzr
Have you a DVD-R blank disc instead of DVD-RW that you could burn? Or maybe try a 4 gig USB thumb drive.
    WDP 8 x86
    Dell Lat 530 Lappy
    Dual Core
    24 Mbps sometimes high speed cable
vrosa
Tech Addict
:huh: Why do you need to burn a DVD when you can install the OS directly from the ISO ?
~edit~
The build number isn't 7595, it's 7955 :ninja:
Also try Oracle VirtualBox instead of VMWARE :)
    Windows 10.0.10122
    My Build - Vorttex Ultimate
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    32GB DDR3 @ 1822 MHz (OC)
    7.1 HDA
    LCD LG 22" + CRT LG 17"
    1760 x 1320 / 1280 x 960
    1 x 240 GB SSD (System)
    3 x 500 GB HDD (Data/Media)
    1 x 2000 GB e-HDD (Backup)
    ThermalTake 1000W PSU
    Corsair Carbide R300
    Corsair H60 (Push-Pull)
    Microsoft Wireless Keyboard
    Microsoft Wireless Mouse
    60 Mbps (Down) 5 Mbps (Up)
    IE, FF, Chrome
    AVG Internet Security 2015
    Some wired stuff
Davy83
Well I have the USB drive but it says 4GB and the ISO* file is larger by .32GB don't think it will fit. I'll try VirtualBox and
see. Also I created a partition for it but wqhen I try to install it says I can't because the partition may be dynamic ...I've tried installing on "unallocated space" and "New Volume" and it's the same thing...I'm stuck. The ISO* file is on my desktop and I waant to install it on my laptop, how would I go about moving it?
    ASUS M2N68 LA-Narra
    3.50GB
    Realtek HD
    HP mx 705
    20 kbps
DocBrown
Crazy Scientific Senior
Correct .iso size for Build 7955 should be 2.594gb which is much less than a 4gb flash drive. You may have a corrupted download.
    Win_8 Build 7959 x64
    Custom Built
    AMD Phenom II x6 1100T x64 3.3ghz AM3 CPU
    Gigabyte GA-890FXA-UD5
    16gb GSkill F3-12800CL9D
    EVGA GeForce 210 - 512mb DDR3 PCI-E 2.0
    on Motherboard
    23" Samsung
    1440 x 900
    1tb Sata Samsung, WD 500gb Blue
    OCZ PSU Mod-X-Stream-Pro 700w
    Red Custom $ 9.99 on sale special !
    2 fans
    Re-Cycled from Thrift shop
    Emprex Optical
    Cable Internet
    " Doc's " Home for Re-Cycled Computers & Parts !
Davy83
I just don't get it....with the 7 builds I had no problem at all. This one for some strange reason I can't seem to get going. maybe I'll wait for the Beta builds or the Release Candidate. Another thing I've noticed is the build is only 64 bit so if I get it running I have to use my new laptop cause my desktop is 32 bit. I thought since my CPU is an Athlon 64x2 +3800 that i could switch back and forth between 32 and 64 bit which I guess is impossible.
    ASUS M2N68 LA-Narra
    3.50GB
    Realtek HD
    HP mx 705
    20 kbps
DocBrown
Here is a snip of my B-7955. It is x86 (32 bit) ? Not sure what you have.
    Custom Built
    on Motherboard
    23" Samsung
    1440 x 900
    2 fans
    Emprex Optical
    Cable Internet
vrosa
Tech Addict
@Davy83
The build is 7955 x86 or 7959 x64 ?
Anyways, like DocBrown said, your ISO must be corrupted :huh:
    Windows 10.0.10122
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    7.1 HDA
    IE, FF, Chrome
    Some wired stuff
Davy83
This is what I downloaded from Digitex or whatever the name is....
    ASUS M2N68 LA-Narra
    3.50GB
    Realtek HD
    HP mx 705
    20 kbps
vrosa
Tech Addict
ISO Size for build 7959 x64
Your ISO size seems to be correct and surely fits on a 4GB flashdrive.
:huh:
    Windows 10.0.10122
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    7.1 HDA
    IE, FF, Chrome
    Some wired stuff
DocBrown
Yes that is the win8 Build 7959 x64 (64 bit) Windows 2008 R2 Server build
This will probably run on your 64 bit laptop if you partition you HD & dual boot with you current laptop. But it will not dual boot on your desktop that is 32bit, with it's own partition, since it is 64 bit
    Custom Built
    on Motherboard
    23" Samsung
    1440 x 900
    2 fans
    Emprex Optical
    Cable Internet
Kodi
Geriatric Member
    Windows 10 Pro 64bit
    Home Custom Build
    Intel i7-4770K
    Asus Z87 Sabertooth
    16 Gig DDR3-2400
    Gigabyte GT740
    Onboard
    Benq 27" - Benq 22" - Dell 23"
    1680x1050
    Samsung 840 pro 128g SSD
    1xWestern Digital Caviar Green 1TB
    2xWestern Digital Caviar Green 2TB
    Seasonic 760 watt platinum
    HAF-X
    Noctua NH-C12P CPU Cooler
    Logitech illuminated keyboard
    Logitech Performance MX
    Cable
    Avast Internet Security
Davy83
Okay I have it on aa 4GB flash drive, now I want to create a partition to test it on; should it be unallocated space or a simple volume? i tried both before and it says I cannot install to that volume because it's a dynamic volume or something like that...
    ASUS M2N68 LA-Narra
    3.50GB
    Realtek HD
    HP mx 705
    20 kbps
myzr
Davy. Have a look at this tutorial from SevenForums. Make sure that you read and understand what you are doing. You can very easy trash your win7 install if you do something by mistake. Be sure you select the correct partition to work on.
Partition or Volume - Create New - Windows 7 Forums
    WDP 8 x86
    Dell Lat 530 Lappy
    Dual Core
Davy83
I've created partitions before and installed Win 7 builds with no problem. could it be cause it's a server build, instead of a regular ol' build??
Tried on VMWare and VirtualBox...no go, tried booting from a USB drive and booting from a disc...still no joy. I give up and guess i'll wait and try the Release Candidate when it arrives...
    ASUS M2N68 LA-Narra
    3.50GB
    Realtek HD
    HP mx 705
    20 kbps
SIW2
Team Member
You may have a dynamic disk.
Have you created more than 4 partitions?
Have a look in disk mananement and see if it says dynamic.
If it does - you may want to change it back to basic.
    7/8/ubuntu/Linux Deepin
Davy83
Yes It has four partitions, though I didn't create them; they came already made although I don't know if I could erase them. Of course there's the C: and Recovery partitions but there's two more one says SYSTEM 199MB and another says HP Tools 103MB. My laptop is a Compaq Presario CQ-56 115DX. Can I delete these partitions?
    ASUS M2N68 LA-Narra
    3.50GB
    Realtek HD
    HP mx 705
    20 kbps
DocBrown
The 199mb & the 103mb tools would not give you enough to install win8. The 199mb is used as a boot section for your win7 OS. The other is for HP Tools. You would probably be better off getting a second destop HD for a test install of win8 :D
    Custom Built
    on Motherboard
    23" Samsung
    1440 x 900
    2 fans
    Emprex Optical
    Cable Internet
