HELP wrong installation of drivers
khenyat
Hello, this may be one of the most common sense mistake ever. I am using 8.1 64 bit system , and i stupidly installed windows 8 drivers on my mother board, what will i do? the system 32 seems to be corrupted or not functioning properly, whenever i will install the 8.1 drivers this shows up ken.png
also bios is not working properly you please read this thread i posted yesterday http://www.eightforums.com/general-support/60614-system32-bios-problems.html#post470480
Help! thankyou in advance :cry:
KYHI
The bios loads way before windows loads..
restart your pc and keep tapping F2 or DEL key to enter bios setting..
or you can keep tapping F12 to enter the boot options menu to select, boot from setup media, then re-install OS and correct drivers
    Windows 3.1 > Windows 10
    Dell XPS 8700
    I7
    24 GB
khenyat
Tried that :( it wont work . when i plug in the cd rom it wont boot the cd. it becomes like a Flashdrive, that you can open and see the files inside. :( so i cant reformat using windows installer
KYHI
if you can see the files -try to run - setup.exe
and I said keep tapping the key - not just one tap or constant hold
as there is no way your locked outta the bios settings without asking for a password..
you can't get into bios settings because you are not using the right key or at the right time
Two of the following keys will get you where you want to be by tapping them right after powering on the pc..
F2 - DEL - F12
    Dell XPS 8700
    I7
    24 GB
alphanumeric
slightly off center
Gold Member
As mentioned, the BIOS is the first thing to load. You could take your hard drive out and still access the BIOS. The BIOS is what launches the OS.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
