Help with Word 2013
Barbee
Hope someone out there is familiar with Word 13 cause I got a big problem.
I'm turning my documents into ebooks. The one document had justified right margins. I finally undid them (don't ask...I can't remember) but now all my words are spaced funny. Is there a way to fix that? :confused:
    ASUSTeK M1188 Series
    3.20GHz
    AMD 64 bit
    12.0GB
    AMD Radeon HD 7310
    Business class
    Chrome/FF/IE
    Microsoft Defender
Mark Phelps
1,041
Click the Home tab.
Highlight the text you want to realign.
Look at the Paragraph section in the ribbon bar. The lower section has four text alignment settings, from left to right: Left, Centered, Right, and Fill. IF you click Fill, it will add spaces between the words on each line to align the leftmost word and rightmost word with the document margins. To undo do that, just click the Left alignment symbol in the ribbon bar.
Barbee
Mine program 2013 doesn't have "fit" It has Left, Center, Right and Justify. My problem is that the document I'm editing has justified right margin. I want ragged. I got ragged but now I have some words 2 and 3 spaces apart.
    3.20GHz
    AMD 64 bit
    12.0GB
    AMD Radeon HD 7310
    Business class
    Chrome/FF/IE
    Microsoft Defender
Mark Phelps
1,041
Mine doesn't have "fit" either; it has "Fill". But, it's strange that we have different ribbon entries for the same version of Word.
Mine is updated automatically, so you should check if yours needs any Office updates.
Barbee
Good idea. Does your version have the feature that shows the paragraph breaks?
    3.20GHz
    AMD 64 bit
    12.0GB
    AMD Radeon HD 7310
    Business class
    Chrome/FF/IE
    Microsoft Defender
Barbee
Oh, I Googled it and discovered you just click the paragraph icon the funny "P"
    3.20GHz
    AMD 64 bit
    12.0GB
    AMD Radeon HD 7310
    Business class
    Chrome/FF/IE
    Microsoft Defender
