Help with upgrading my laptop to an SSD and to W8
Hi guys! First post, and I expect making alot more. Glad to be apart of the community, and I hope not to break any rule.
First of all, here's my laptop's specs (ASUS N53Jq-SX145V):
• Operating System: Windows 7 Home Premium 64 bit
• CPU: Intel i7 740QM (1.73GHz, Turbo2.93G, 6MB)
• Memory: 6GB
• Hard Drive: 640GB
• Screen: 15.6" LED 1366*768
• Chipset: Intel HM55
• Video: NVidia GT425M 1GB VRAM
Anyway, I recently upgraded my laptop's RAM to 8GB so that I could operate better with heavy software like Vegas Pro, CorelDRAW, Illustrator and Photoshop. But recently I just heard that the best upgrade to a laptop would be an SSD. I've only heard of SSD's existence a few months ago, and since then i've been researching about them and everyone says they're so much faster, efficient, reliable and...well, better. So I can't wait to upgrade =D
After alot of research, i've decided to go for Samsung 256GB 2.5-inch SSD 840 Pro since I love Samsung and many reviews said it's one of the best on the market. But I want to ground myself before I do this, i'm a noob when it comes to upgrading laptops so i'm still a little intimidated by it. So here's my questions:
• First of all, how can I know if my laptop's compatible with SSD's? (and with 840 Pro too)
• I've heard that SSD's lifespan decreases the more writes it does. Should I be worried about this?
• Do SSD's require defragmentation at all?
• I wanted to put Windows 8 in my SSD, but I keep hearing 7 is better for it. Is the difference that huge, or is 8 better after all?
• I've heard it's possible to revome the DVD Burner form a laptop and put another SSD/HDD in it's place. So could I put my SSD in my current HDD's place, and put my old HDD on the DVD Burner's place? And if so, would the performance of the SSD make reading the HDD's files faster?
I think that's it for now. When I actually get my very own SSD, i'll probably have alot more questions xD
Thank you for your time.
    Windows 7 Home Premium x64
    ASUS N53Jq-SX145V
    Intel Core i7 740QM, 1.73GHz
    8GB
    Nvidia GeForce GT 425M VRAM 1GB
HippsieGypsie
It's Gururrrrrr8!
Lilymoor, IL
13,547
Welcome to EightForums ,Kratos Aurion. It's good to have you.
SSDs run great on just about any OS. You'll have to check your machine's documentation on what's possible and compatible. Please fill out your specs so it's easy for others to help.
Defrag is beyond my knowledge at this point. I plan on purchasing one for my tower. I've read a long thread where some were discussing the pros and cons.
Windows 8 is a great OS. Leaner and more efficient system. I'm sure you'll read otherwise here. :D I suggest to run it on a machine or dual boot for awhile to see if you like it.
Again, welcome. :)
    8.1 Pro X64
    Acer T690
    Intel Pentium D Dual Core
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Dual case fans + CPU fan
    Acer Windows PS/2
    Wireless Microsoft Arc
    54mbp/s
    IE11
    Defender
Again, welcome. :)
Thank you for the reply :)
I've added the specs to the main post, shouldn't have just left a link for them. Sorry for that.
And i'm familiar with 8 already, just not as familiar with 7. I've installed on an older laptop I have, and it runs phenomenally. That's the reason I want to put 8 on my laptop so bad, but i've read that 7 was better for SSD's. I doubted that, that's why I came and asked for insight on this.
    ASUS N53Jq-SX145V
    8GB
azasadny
Moved to ten*****s.com
Good advice here from HippsieGypsie. SSD's do not need defrag, so don't setup scheduled defrag for the drive. I would replace the existing hard drive with the SSD and put the old HD in an external enclosure and use it to store data/image files, etc... I have run both Win8 and Win7 on SSD's and they both provide a noticeable improvement over hard drives. SSD's run cooler and are silent, which is great! Welcome aboard here!!
    Win 10 Pro 64bit
    Corsair M65 wired
    85MBps DSL
    Chrome and Edge
    1GBps Ethernet ports
Thanks for the reply :)
Since i'm a guy who likes to keep up with technology and stuff, I think i'm gonna go for 8 :p
This article says that W8's scheduled defrag for SSD's isn't really defrag, but sending trim hints for the disk =0 This is some amazing shiz from Microsoft, has anyone else proved or tested this? If it is true, I won't disable it.
Can anyone tell me if my laptop is compatible with the SSD i'm planning to get? Please help me on this...
Thank you so much =D
    ASUS N53Jq-SX145V
    8GB
azasadny
The article was referring to Win8 when they mentioned the "special" defrag, so I wonder if Win7 does the same thing? Thanks for the info!!
    Win 10 Pro 64bit
    Corsair M65 wired
    85MBps DSL
    Chrome and Edge
HippsieGypsie
It's Gururrrrrr8!
Lilymoor, IL
13,547
Thanks for the article and info on SSDs, defrag, and trim hints. :) I'm glad to read that you are attempting to try 8.
I'm sorry, but I'm not that technically advanced to know whether or not your planned SSD is compatible with your laptop. Perhaps you could contact Asus to find out? Some other member may answer to your request as well.
Good luck to you with your project.
    8.1 Pro X64
    Acer T690
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Acer Windows PS/2
    54mbp/s
    IE11
    Defender
WiFi Ed
146
#8
Windows 7 & 8 both recognize SSD's and use the "trim" function. In Windows 8 it's called "optimize" (under "Drive Tools")
    Windows 8.1 Pro x64
    Dell E520
    Intel Q6700 Core 2 Quad - 2.66 GHz
    Whatever Dell put in there...
    8 GB Mushkin 800 MHz DDR2
    NVIDIA GTX 650 - 2 GB GDDR5
    Integrated
    2 x 19" ViewSonic LCD's
    2560 x 1024
    1 Intel X25-M 120G SSD, 2 WD RE4 2TB HD's
    PCPower & Cooling Silencer 500 Watt
    100/10 Time Warner Cable
bobkn
Danbury
465
#9
One consideration: Your notebook can use 9.5mm thick drives. The Samsung 840 is a 7mm thick drive. Depending oh how the drive is mounted, there may be an issue with that.
    Window 8 Pro
    homebuilt
    I7-3930k
    Asus P9X79 Pro
    16 GB Gskill DDR3-2133
    eVGA GTX 680
    Soundblaster Zx
    Asus PA246Q
    1920X1200
    Corsair Force GT 120GB
    WD Cavair Black 1.5TB
    PC Power & cooling Silencer 750
    Silverstone FT02B-W
    Noctua NH-D14 w/ PWM fans
    cheap Logitech USB wired
    old 5 button Microsoft USB optical
    6Mb cable
azasadny
So, i have disabled defrag on my SSD... according to what I'm seeing here, I should enable defrag on the SSD to get the TRIM "optimization"? Correct? Thanks and sorry to hijack the thread!
    Win 10 Pro 64bit
    Corsair M65 wired
    85MBps DSL
    Chrome and Edge
bobkn
Danbury
465
#11
Nope. The functions are separate. Windows 7 will use TRIM automatically, although I'm unsure that you'd get it if you cloned a Windows installation from a spinner onto an SSD.
To check whether TRIM is enabled (stolen from another post):
run (as admin)
fsutil behavior query DisableDeleteNotify
If the result is '0' TRIM is enabled.
Oddly enough, it shows Trim as enabled under Win7 X64 on my old (2008) Compaq notebook. It has an AMD CPU and an NVidia chipset; no AHCI.
    Window 8 Pro
    homebuilt
    I7-3930k
    Asus P9X79 Pro
    eVGA GTX 680
    Soundblaster Zx
    Asus PA246Q
    1920X1200
    Silverstone FT02B-W
    6Mb cable
sandman
100
#12
    Home Built Antec P-180B Case
    Intel E8400
    Asus P5QPro Turbo
    Kingston PC6300 4 gig
    HD5670
