Help With Remote Desktop Between Office and Home PCs.
lostindigital
Hi, I have three Win 8 PCs at my office and a Win 7 Pro PC at home. Does anyone have a clear set of instructions for how I can set up remotes access so I can work on my office PCs from home? These are all my PCs too, not a company I work for. Many thanks all.
    Win8
broe23
Retired from the grind
Download and install Teamviewer.
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
HippsieGypsie
It's Gururrrrrr8!
    8.1 Pro X64
    Acer T690
    Intel Pentium D Dual Core
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Dual case fans + CPU fan
    Acer Windows PS/2
    Wireless Microsoft Arc
    54mbp/s
    IE11
    Defender
lostindigital
Thanks Broe23b but Team Viewer's too expensive, at $600 - $2,500 for the moment. I also agree with Hippsie, MS has designed their Remote desktop to work perfectly with Windows. I'll try that but I wasn't sure about port designation from something I read. Apparently that's a little tricky.
    Win8
HippsieGypsie
It's Gururrrrrr8!
Wow! That is expensive!
I'm sure someone will come along to help. Just ask away to keep the thread going.
    8.1 Pro X64
    Acer T690
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Acer Windows PS/2
    54mbp/s
    IE11
    Defender
pparks1
You need 8 pro at work to get remote desktop option.
If you need free, you could try something like tight vnc.
So you have a VPN into the office already.
    Windows 7
    Self-Built in July 2009
    23" Acer x233H
    Intel X25-M 80GB Gen 2 SSD
    Corsair 620HX modular
    Antec P182
    stock
    ABS M1 Mechanical
    Logitech G9 Laser Mouse
    15/2 cable modem
lostindigital
Hi Guys, I'm almost there but just need a little more feedback and help. I'm sitting here at the work Win 8 Pro PC to allow RDC. When I look at the computer name, I see three things (I've substituted the real names): Computer Name - John, Full Computer Name - John.smith.local, and the Domain - smith.local. And I also have the IP Address.
When I try and remote in from my home Win 7 Ultimate PC, what do I type in for the Computer name and Username? I'm somewhat stumped.
An hour ago I tried typing in the IP address of the work PC from my home PC and couldn't make a connection. I'm missing something here.
Thanks to anyone who can help me solve this.
    Win8
HippsieGypsie
It's Gururrrrrr8!
Hi there glad to see you're making progress. :)
Is it allowing it to wake it if it's sleeping? If not, that setting would be in your Network adapters. Ethernet controller or wireless adapter, whatever you're using.
    8.1 Pro X64
    Acer T690
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Acer Windows PS/2
    54mbp/s
    IE11
    Defender
lostindigital
Hi Hippsie, sleep mode has been turned off.
Hmmm, ?? I'm still stumped. I might have to bite the bullet and get the local IT company out to take a look with me.
I'm installing Spiceworks to help me map and identify all the hardware on our network. Then I might be able to start unraveling.
    Win8
adamf
Banned
TeamViewer is free for non commercial use but anyway...
You can put in the computer name or the ip. However unless you are on the same network the system will not be able to map your computer name (John) to the ip address 123.456.789.012 (or whatever) unless you add a mapping in your host file (which is found in C:\Windows\System32\Drivers\etc\hosts) You can update this using notepad as administrator.
To start with try the following - from a command prompt try pinging the pc - I made up the IP address - you will probably see something like this:
PS C:\Windows\system32> ping john
Ping request could not find host john. Please check the name and try again.
PS C:\Windows\system32> ping 192.168.1.82
Pinging 192.168.1.82 with 32 bytes of data:
Reply from 192.168.1.82: bytes=32 time<1ms TTL=64
Reply from 192.168.1.82: bytes=32 time=1ms TTL=64
Ping statistics for 192.168.1.82:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
Let us know how that goes. Once you can ping it you can use RDP. If you can't ping it it could be asleep (as HypsieGypsie said) or the route could be blocked. Lets try that first.
Incidentally I normally use the IP - it should tell you if it can't connect. Something like this - note I can't connect to this computer but can ping it as it is a linux machine not supporting RDP. It is only an example :)
    Windows 10 Pro Prieview x64
    MacBook Pro Core2Duo
    T7600
    ATI Radeon X1600
    Internal
    1440 x 800
    40GB
    Apple
    Apple
    Varies
    Various
    Defender
lostindigital
Hi Adam, the "unable to connect" window screenshot is exactly what I got when at home. I'll head back there and try to ping this work PC from there. Many thanks.
    Win8
lostindigital
Hi Adam, the ping result said Destination Host unreachable, several times. I used the IP address.
Packets: sent = 4, Received = 4, Lost = 0.
Cheers.
    Win8
adamf
Banned
So you can ping the IP from home OK? What happens if you try to use RDP using that same IP?
And is that IP the external IP of the computer at work or is it the router? You may need to look at this Allow Remote Desktop connections from outside your home network
I've only used RDP on the same network but that guide looks fairly easy to follow (I hope).
    T7600
    ATI Radeon X1600
    Internal
    1440 x 800
    40GB
    Apple
    Apple
    Varies
    Various
    Defender
lostindigital
No, the ping didn't work. Destination host was unreachable. No joy.
The external IP was the computer, not the router. I need to identify the router's IP tomorrow.
    Win8
lostindigital
Hi Adam, thanks for your assistance. I had an IT guy come look at the setup and he though the issues might lie somewhere within the registry that's preventing a connection. So we decided to reinstall Windows to this PC, creating a new user profile and workgroup network connection. I've done that this week but not tried a remote connection yet. I will tonight. Right now I'm having trouble deleting some previously created folders from the previous profile and server. Cheers.
    Win8
