Solved Help with partition and multiboot
ujwalchhabra
19
guys i'm running windwos XP and windows 7 in a multiboot settings....
i downloaded windows 8 consumer preview 32bit iso...
first thing is i need a partition so i shirinked my existing and made a unallocated space of 17GB..but windows isn't making it a volume...its saying maximum partitions already exist....here's the screen of it...
I don't need that 9 mb and system reserved and want that 17 GB unallocated one to be a partition..! guide me the way..! that g: with 12 gb is xp and c: is windows 7 and d: is my data ..i shrinked that volume to gain space...
But suddenly i thought i can remove that 9 mb partition by shrinking g: and will extend it but reverse happened that 2 gb that i shrinked from G: added in 17 gb unallocated...
Now i want a 17 gb partition for windows 8 and 2 gb back in g:....
i also want to know how to multiboot those 2 Os with windwos 8..!
Guide me////
    7 and xp and windows 8 finally..!
DMHolt57
Austin, Texas
1,452
since the max number of primary partitions cannot exceed 4, and your hdd is a little on the small side, you will have to add the unallocated space back to the partition it is next to. I would jockey my data back to C and then use G or D for the 8 install....the system reserved is where your boot record is, you must keep it....you could do a virtual install of 8, but xp is kinda overkill...
My Computers
System One System Two
    17074 Pro
    HP dv7 3173nr
    M520
    5GB
    1600x900
    120Mb/s
  • PC2
    HP A12 R7 17074
ujwalchhabra
19
OMG no one knows here????how this come possible here????
and G: is xp drive...XP is installed in it..!i want win 8 and that 17gb part..!
and that 19gb to be furthur devided into a 17 gb which would be used for windows 8 and rest 2 gb would be addd to G:...!so can u help me to get this configuration?or with any 3rd party tool???
DMHolt57
Austin, Texas
1,452
Try right clik on G in Disk Management and select expand...no third party soft is going to give u what u want, u have to make a new plan that has a total of 4 partitions...
My Computers
    17074 Pro
    HP dv7 3173nr
    M520
    5GB
    1600x900
    120Mb/s
  • PC2
    HP A12 R7 17074
ujwalchhabra
19
nope it isn't showing
ujwalchhabra
19
#9
ok dude..problem solved now i can teach u hw to acomplish that w/o erasing etc work...i indeed that 19gb partition splited into 17gb and 2 gb and added 2gb to g: and created the 17g partiotion w/o any data loose..u wanna learn?
DMHolt57
Austin, Texas
1,452
#10
...so you now have a Dynamic Disk instead of a Primary/Logical partition?
My Computers
    17074 Pro
    HP dv7 3173nr
    M520
    5GB
    1600x900
    120Mb/s
  • PC2
    HP A12 R7 17074
DMHolt57
Austin, Texas
1,452
#13
Could you post a screenshot of your disk management, I'm very curious to see it. :geek:
My Computers
    17074 Pro
    HP dv7 3173nr
    M520
    5GB
    1600x900
    120Mb/s
  • PC2
    HP A12 R7 17074
ujwalchhabra
19
#14
u can see as that 19.53 gb unallocated was splitted in 2 parts one of 17gb and one of 2.53 and 2.53 was added in g: and 17 gb was created a new volume..!
