Help with Ntuser error
RedBatman
Okay so sometimes on my gaming laptop I notice this error
{Registry Hive Recovered} Registry hive (file): '\??\C:\Users\Ron\ntuser.dat' was corrupted and it has been recovered. Some data might have been lost.
I did find articles how to fix this by deleting user or replacing it with a new user file and well they are kinda of confusing so could someone please so me a good walkthrough or explain in good detail what should I do or how to take ntuser.dat and replace it with my default profile.
lgordon225
Hi,
For the reg import part, try to specify the file path of taskband.reg.
Then check if issue could be solved.
Tested on my side, if no file path, will receive the same error.
EDIT:Do remember to backup your registry settings before you doing any changes.
Best regards
    NDVIA
    Avira
