avidqtaqtx
guys i need your help
i am on windows 8
i am using HP laptop
this is my ccc version
i got 2 problems
well first one is that i can't update to windows 8.1 as the update always hang on 82% and after that my laptop
automatically shutsdown i don't know whats the reason is and that's why i am stuck at windows 8 till now although have 8.1 ISO but i don't want to install it as i have to erase my my windows 8 which came pres-installed so i will
loose my genuine windows 8 .now i want to know what if i open the 8.1 installer and install it from a virtual tool like
Deamon although it gives an option to keep files app setting safe but i fear that it would conflict with 8 and i would have to format my laptop then
ok now to the major problem
i just recently purchased Watch Dogs and installed it.I played the first mission and got busted so the mission failed and it began to reload and then a error pops up saying watch dogs have stopped working
upon googling i found out that this is due to DUAl AMD Graphics so they stated that i should disable it
but i cant find any option of disabling DUAL Grahics
so can you guys help me
i am on windows 8
i got 2 problems
- Windows 8
- Computer type
- Laptop
- System Manufacturer/Model
- HP Pavilion G6-2302AX
- CPU
- APU Dual Core A4 2.5 GHz with Turbo Core Technology Upto 3 GHz
- Motherboard
- AMD
- Memory
- 6GB
- Graphics Card(s)
- 512 MB AMD Radeon HD 7420G (Integrated) and 1 GB ATI Mobility Radeon HD 7670M (Dedicated)
- Sound Card
- HD Audio, Dolby Advanced Audio v2, Stereo Speakers
- Monitor(s) Displays
- HD Brightview Widescreen LED Backlit Display
- Screen Resolution
- 1366 x 768 Pixel
- Hard Drives
- 1TB
- Internet Speed
- 10MBps
- Browser
- Chrome
- Antivirus
- Windows Defender
