Solved Help! laptop stuck at 28% charging
laptop wont boot until the charger is plug in what should i do?
    windows 8 single language
    Sony Vaio/SVE11126CAW
    AMD E2 1800
    4GB DDR3
    Avast Free
Nuccii
Canada
1,950
If it only boots with the AC adapter plugged it chances are that the battery needs to be changed.
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    NIVDIA GeForce GT 520
    Realtek ALC656GR CODEC
    Samsung SyncMaster S22B350
    1920X1080 32 bit color
    Samsung 850 EVO SSD 500GB
    Logitech M510
i dont think so man. the battery indicator says its still at "Good" condition this happens when i remove the battery pack is it stil safe to use it? Ive tried removing the battery pack hold down the power button for 30 seconds then plug the charger many times any other solution or diagnostics?
    AMD E2 1800
    4GB DDR3
    Avast Free
alphanumeric
slightly off center
Gold Member
I find your last post very confusing. So it won't boot with just the battery plugged in? Does the battery reach 100 % fully charged state? How old is this battery/laptop? It is safe to remove the battery and just run on the power pack.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
Laptop wont boot until the charger is plugged in and it its stuck at 28% charging and when you pull the charger out the laptop goes off too.
    AMD E2 1800
    4GB DDR3
    Avast Free
alphanumeric
slightly off center
Gold Member
You need to replace the battery with a new one.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
seriously man? any other troubleshooting tips? i am currently using my laptop now there's no other option sir? :(
    AMD E2 1800
    4GB DDR3
    Avast Free
alphanumeric
slightly off center
Gold Member
#8
Using it as in, its plugged into the power pack? Go through the facts, the battery won't fully charge and the laptop will not run on just battery power. The battery doesn't last forever you know. They degrade as you use them. That's why they are easy to remove and replace. How old is this laptop/battery?
    Asus
    Thermaltake TR 620
    Stock heatsink fan
#9
ive been usin these for 2 years. im just hoping man that there's any other fix. if it's doesent have then i just go buy another one then
    AMD E2 1800
    4GB DDR3
    Avast Free
alphanumeric
slightly off center
Gold Member
#10
I don't know of any other fix.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
brummyfan
Birmingham
1,487
#11
Go to Device manager, right click Disk drives, Properties, then in Policy tab, untick "Enable Write caching on the device", it may work or may not work, I have done this on a SSD but not sure about HDD. If it doesn't work, tick the caching.
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    High Definiton Audio Device
    Generic
    1366x768
    Samsung 850 Pro 256GB
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
did not work. maybe its time to get a new battery thanks for all your help really appreciate it!
    AMD E2 1800
    4GB DDR3
    Avast Free
