Solved Help in removing rootkit
7
I just ran a rogue killer scan and it shows that I have a rootkit. I would appreciate any help in removing
this. See report:
Thanks,
Karen
RogueKiller V10.4.1.0 (x64) [Feb 19 2015] by Adlice Software
mail : Contact
Feedback : Adlice forum
Website : RogueKiller download
Blog : Adlice Software - malware analysis
Operating System : Windows 8.1 (6.3.9600 ) 64 bits version
Started in : Safe mode with network support
User : Karen [Administrator]
Mode : Delete -- Date : 02/22/2015 07:07:12
¤¤¤ Processes : 0 ¤¤¤
¤¤¤ Registry : 0 ¤¤¤
¤¤¤ Tasks : 0 ¤¤¤
¤¤¤ Files : 0 ¤¤¤
¤¤¤ Hosts File : 1 ¤¤¤
[C:\WINDOWS\System32\drivers\etc\hosts] 127.0.0.1 localhost
¤¤¤ Antirootkit : 1 (Driver: Not loaded [0xc000035f]) ¤¤¤
[IAT:Addr(Hook.IEAT)] (iexplore.exe @ wow64.dll) ntdll.dll - memcpy : C:\Program Files (x86)\Internet Explorer\IEXPLORE.EXE @ 0x11038d0
¤¤¤ Web browsers : 0 ¤¤¤
¤¤¤ MBR Check : ¤¤¤
+++++ PhysicalDrive0: ST500LM012 HN-M5 SATA Disk Device +++++
--- User ---
[MBR] 7ea2c00f60c9dbfb7304f609c967be1e
[BSP] 5246beb6805e95d217c41c2452eedadd : Empty MBR Code
Partition table:
0 - [SYSTEM][MAN-MOUNT] Basic data partition | Offset (sectors): 2048 | Size: 300 MB
1 - [MAN-MOUNT] EFI system partition | Offset (sectors): 616448 | Size: 100 MB
2 - [MAN-MOUNT] Microsoft reserved partition | Offset (sectors): 821248 | Size: 128 MB
3 - Basic data partition | Offset (sectors): 1083392 | Size: 475961 MB
4 - [SYSTEM][MAN-MOUNT] | Offset (sectors): 975851520 | Size: 450 MB
User = LL1 ... OK
User = LL2 ... OK
RKreport_DEL_02162015_124609.log - RKreport_DEL_02192015_034046.log - RKreport_DEL_02192015_035043.log - RKreport_DEL_02192015_114150.log
RKreport_SCN_02162015_124134.log - RKreport_SCN_02192015_033604.log - RKreport_SCN_02192015_034900.log - RKreport_SCN_02192015_113451.log
RKreport_SCN_02202015_213834.log - RKreport_SCN_02222015_070618.log
    windows 8.1
    samsung
Nuccii
Canada
1,950
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    NIVDIA GeForce GT 520
    Realtek ALC656GR CODEC
    Samsung SyncMaster S22B350
    1920X1080 32 bit color
    Samsung 850 EVO SSD 500GB
    Logitech M510
majulook
88
    Win 8 and Linux (MINT)
    Lenovo Win 8 & Toshiba Linux
    Samsung SyncMaster
Nuccii
Canada
1,950
If you are not getting any rootkit reports from all the scans you've tried it is possible that RogueKiller has already cleaned it out for you.
    Pavillion H8-1202
    I7-2600 @ 3.4 GHz
    PEGATRON
    8 GB
    Logitech M510
yu gnomi
Chicago suburbs
145
If you are still concerned about this, I recommend you go to bleeping computer, join that site and open a topic in the "Am I infected?" forum. People there will help you for free, and are quite knowledgeable about malware.
Am I infected? What do I do? Forum - BleepingComputer.com
    Win 8.1 Pro
    Intel i5-4590
    MSI h97 PC Mate
    Kingston Valu Ram 2 x 8 gb
    Radeon r7 265
    Viewsonic 22" flat display
    Samsung 250 gb 840 evo SSD,
    WD Blue 1 TB HD,
    Fantom 2 TB ext HD
    Corsair 600 W
    Antec 1
    stock CPU cooler, 4 x case fans, GPU fan and P/S fan
    HP ps/2 keyboard
    Logitech Trackman Marble
    50 mb/s
    Chrome
    Norton Security Suite
Borg 386
ADHD member
If you want to see if there is indeed a rootkit hiding on you drive, then you need to look at it with GParted. This is a bootable partition manager that will allow you to see the contents of your drive, including any hidden partitions.
Rootkits generally cloak themselves from Windows disk management. This application will show the entire contents of the disk.
GParted -- A free application for graphically managing disk device partitions
D/L GParted, select the medium you wish to use & run it at boot time. Any rootkit will show up, usually at the end of the drive, as a hidden boot partition between 1 to 10 MB depending on the variant. If such an item is present, you have confirmation & can take steps to remove it.
    Win 7 32, Win 7 64 Pro, Win 8.1 Pro
    It's a Dell, Dude.
    Intel Caffinated Core Duo
    Father is bored too.
    4 GB
    NVidia something-or-another
    24" HD TV/Monitor/Alternative Dimensional Viewing Portal
    Fuzzy after a couple drinks
    2 or 3, depending on if it's a night they're arguing about having a "split personality crisis" because I partitioned the drive.
    Don't get on my case....man
    Scotch on the rocks on the weekends..
    Mad Catz Cyborg V7. Or maybe Cyborg Catz Are Mad At V7's??? I know it lights up...far out.
    currently being stalked by the cat...
    Never fast enough...
    Defeated by Mario...wait...OH...BRowser...
    Various
