I have some firewall rules that I try to (want to) disable with the 'Windows Firewall with Advanced Security' GUI. But when I select the rule and try to disable it, I am presented with a dialog box that says:
Question:
How do I disable/enable or block/unblock a rule AND preserve all other properties of said rule?
One or more rules in the current selection contains a property not supported through this interface.
[Name of firewall rule]
If you continue, these properties will be overwritten. Do you want to continue?
This means that if I just want to disable the rule for a while and enable it later, it wont be the same rule anymore.One or more rules in the current selection contains a property not supported through this interface.
Question:
