Help!!! changing the window colour
pebble
1
I am slowing getting use to windows 8, however I haven't been able to change the window colour. As I am dyslexic I need my background colour for each application to be blue but I can't see how to do this with windows 8. I have followed the process on how to change it with windows 7 but there are no advance settings in the color option. Can anyone help.
thanks
Larrycleve
17
I would like to do this also. The bright white color is annoying. Also can the scrollbar color be changed?
    Home built
ecevit
153
    windows 8 pro x64
    Q9300
    Gigabyte P43 Es3g
    8 GB of ddr 2
    sapphire hd 6850
    sound blaster titanium x-fi pci-e
    22 inches
    1680x1050
    Seagate 2 TB st20001dm001
    Samsung 2 tb sata 2
    Hitachi 500 gb sata
    fatality 550 w
    spike
    air
    wired A4
    ADSL 8 MB / 1 MB
Larrycleve
17
I turned on high contrast through the charms menu. The options are there. Is there any way to have a picture on the desktop as opposed to a solid color? When using a theme from the windows store it reverts back to standard contrast.
    Home built
Larrycleve
17
    Home built
Larrycleve
17
Using high contrast, web pages show the window color rather than their normal background. Apparently it's an either or situation. Keep the normal web page and lose window customization or lose the way the web page is supposed to look.
    Home built
ecevit
153
#8
Yes, you can't get an optimal solution but can change some colors.
    windows 8 pro x64
    Q9300
    Gigabyte P43 Es3g
    8 GB of ddr 2
    sapphire hd 6850
    22 inches
    1680x1050
    Samsung 2 tb sata 2
    Hitachi 500 gb sata
    fatality 550 w
    spike
    air
    wired A4
    ADSL 8 MB / 1 MB
roban
8
#10
The only way to do this is by editing the registry:
HKEY_CURRENT_USER\Control Panel\Colors
HKEY_CURRENT_USER\Control Panel\Desktop\Colors
HKEY_CURRENT_USER\Control Panel\Desktop\WindowMetrics
Unfortunately these are in hex values and you'll have to reboot to make the changes.
The good news is the Registry keys are the same in Windows 7 and 8. So you can customize the advanced appearance settings in 7 and open the Registry Editor and make a back-up of the above mentioned registry keys. You can do this by right-clicking on each key and select Export option. This will create .REG files. Import these .REG files into Windows 8 Registry Editor and restart Windows 8 desktop.
    Windows 8 Professional
    MSI
    Intel Celeron 2.4 GH
    4 GB
    NVidia GeForce 9800GT
ecevit
153
#11
Thanks but how can colors be obtained ? RGB values ?
    windows 8 pro x64
    Q9300
    Gigabyte P43 Es3g
    8 GB of ddr 2
    sapphire hd 6850
    22 inches
    1680x1050
    Samsung 2 tb sata 2
    Hitachi 500 gb sata
    fatality 550 w
    spike
    air
    wired A4
    ADSL 8 MB / 1 MB
ecevit
153
#13
Thank you. I will try that when I'm home. I use xp at work .
    windows 8 pro x64
    Q9300
    Gigabyte P43 Es3g
    8 GB of ddr 2
    sapphire hd 6850
    22 inches
    1680x1050
    Samsung 2 tb sata 2
    Hitachi 500 gb sata
    fatality 550 w
    spike
    air
    wired A4
    ADSL 8 MB / 1 MB
ecevit
153
#14
It didn't work . Color options are only effective when high contrast themes are selected.
    windows 8 pro x64
    Q9300
    Gigabyte P43 Es3g
    8 GB of ddr 2
    sapphire hd 6850
    22 inches
    1680x1050
    Samsung 2 tb sata 2
    Hitachi 500 gb sata
    fatality 550 w
    spike
    air
    wired A4
    ADSL 8 MB / 1 MB
Hopachi
Polyhedric Stellation
Orbiting the Moon
2,975
#15
This can be obtained in an image editor like GIMP or Photoshop.
You're right.
The best solution is to select a hi-contrast theme, modify what we can, change background and then export it for further modifications.
I'm working on a AeroLite normal theme based on hi-contrast settings where we can modify most of the options.
See some results here:
http://www.eightforums.com/customiz...-ui-change-title-text-color-4.html#post152178
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    multiple resolutions
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
    That's basically it.
