Hard drive won't open and ChkDsk fails
philnolan3d
The disk on my old computer where I keep all of my work files and well as other data, games, videos, etc. is not opening. When I double click the drive (S: ) in My Computer I get the error:
"S:\ is not accessible.
The file or directory is corrupted or unreadable"
So I ran ChkDsk on it. First with F/ then again with R/
Both times I get the same errors.
C:\WINDOWS\system32>chkdsk S: /F
The type of the file system is NTFS.
Volume label is SEAGATE.
Stage 1: Examining basic file system structure ...
File record segment 4 is unreadable.
File record segment 5 is unreadable.
File record segment 6 is unreadable.
File record segment 7 is unreadable.
239680 file records processed.
File verification completed.
888 large file records processed.
4 bad file records processed.
An unspecified error occurred (6e74667363686b2e 2d0).
Anyone have any other suggestions?
It's running Win 8.1, the drive is a 1TB Seagate barracuda.
    Win 8.1
    Core 2 Quad 2.4GHz
    Gigabyte
    8GB
    GeForce GTX 470
    Asus
    Win8 Pro x64, Core 2 Quad 2.4 GHz, , 8GB RAM
    Antec
    4 80mm fans
CountryBumkin
Gv me thumbs-up if I help
    Win8.1
    HTPC: Custom built
    intel i5-2400
    Gigabyte GA-Z68MX-DS2H
    16GB Corsair DDR3-1600
    on-board HD3000
    On-board
    Samsung 32" LED
    eight HGTS Deskstar NAS, 3TB
    seven WD Red NAS, 3TB
    one Seagate ES.2, 1TB
    one 64GB SSD
    Corsair 750W
    Li-Lian case with SuperMicro hotswap backplane
    Case 4 6" fans, stock CPU cooler
    Two 3-Ware (LSI) model 9650SE-8LPML RAID cards.
philnolan3d
I'm trying that now but it seems it's not free. It's a trial and will only recover 100MB of data without paying. it also talks about the drive being RAW and converting it to NTFS, but my drive is already NTFS.
    Win 8.1
    Core 2 Quad 2.4GHz
    Gigabyte
    8GB
    GeForce GTX 470
    Asus
    Antec
    4 80mm fans
Mark Phelps
There is a free Windows data recovery app known as "recuva". You could try that.
The best data recovery app I've used is Active@File Recovery Pro. It's not free but the trial version will let you search the drive and you will then be able to see what it finds -- before purchasing it.
philnolan3d
Thanks Mark. I'm trying stuff but I basically have no money right now. If nothing else I should get paid in a couple weeks so I can buy something
    Win 8.1
    Core 2 Quad 2.4GHz
    Gigabyte
    8GB
    GeForce GTX 470
    Asus
    Antec
    4 80mm fans
philnolan3d
Hmm I'm using Recuva now but I suspect that it's giving me files that have been deleted and it's just undeleting them. Most of them list their path as "Recycle Bin".
    Win 8.1
    Core 2 Quad 2.4GHz
    Gigabyte
    8GB
    GeForce GTX 470
    Asus
    Antec
    4 80mm fans
