What unusual weather!
I need some suggestions/advice for my new case rebuild. For those that don't know, I have plans to hold 15 hard drives in my new tower, through the use of hard drive cages, specifically these ones...
Newegg.com - ICY DOCK MB453SPF-B 3 in 2 SATA I, II & III Hot-Swap Internal Backplane Raid Cage Module
I'm also planning on using some Western Digital Red series hard drives as well, since they're designed for 24/7/RAID/NAS usage which fits my needs better as I use my compilator pretty much 24/7 with some exceptions being at night when I go to bed or sleep it throughout the day when I'm not in the room or not at home when no tasks are being executed.
And this is the dilemma: cooling. My current case design has the cages so that the front and back of it will be facing or touching the sides of the case. There will be some acrylic sheets used on the outside of the case, and I've channeled out half an inch on the sides of said case. So if one were to look at the case from the top, there will be an air intake (0.5" x 5-3/4" for the intake dimensions) from the left and exhaust port on the right, as the air will flow from left to right as the cages allow. I'm thinking I might use a 120mm and a 90mm fan for that.
The question I'm having is do hard drives, in this scenario of mine, need such cooling? I'll be watercooling the CPU, and stock air cooling of the graphics card, that is at least if I decided on an uber purchase of an ASUS ROG Radeon 7990 that has watercooling. Will probably cost a child for that...
Thank you and good evening! I need coffee.
