Graphics Card settings lost on system boot.
theweav
Hi,
This problem has just started recently. I use my GeForce GT610 graphics card to adjust the Brightness and Contrast on my monitor. The monitor's controls are difficult to use. When I boot up the settings are lost. I have to go into the graphics card settings each time to reset Brightness and Contrast. I have been talking with NVIDIA, but we have not found a solution. It doesn't seem to be the card. It seems Win 8 is knocking it offline. Any ideas out there?
    Dell 660
    3.40GHz
    Intel Core i3-3240
    8.00GB
    GE Force GT 610 2GB
    NVIDIA High Definition Audio
    LG 23EA63 [Monitor] (23.1"vis, January 2012)
    1920 X1080
    WDC WD10EZEX-75ZF5A0
    1TB
    IE 10
    Norton
lmaneke
I have a GT 630, and just tried to duplicate the issue you are having, and I am not having that issue. The NVIDIA software retains its settings.
Does it do it on a system restart, Like a warm boot?
If it does it only during shutdown. You may want to turn off Fast Startup, if fast startup is enabled. There are known issues with fast startup.
    ASUS
    Intel Core 2 Quad Q6600 2.40 ghz
    ASUS P5K PRO
    2 GB DDR2
    PNY NVIDIA Geforce GT 630
theweav
Hi, Thanks for the response.
Yes this happens on warm and cold boots. It is intermittent. NVIDIA has been very helpful. After trying several possible fixes they have decided to replace the card. I hope this works.
Thanks
    Dell 660
    3.40GHz
    Intel Core i3-3240
    8.00GB
    GE Force GT 610 2GB
    1920 X1080
    1TB
    IE 10
    Norton
lmaneke
Good luck. Shocking its having that problem when there aren't other issues.
Cheers, hope it works for you.
    ASUS
    ASUS P5K PRO
    2 GB DDR2
