Solved Going mad Browse studio Malware ?
Have a new Asus ROG G750JM and have finlly after two days got all the updates and stuff I want on it but now I ma bing innunufdted with rotten pop ups like Browser Studio and ad pages when I click on a seven or eight forum links.
Have Googled a fix but come up with a heap of PC cleaner ads and suchlike and it is driving me nuts. Nothing in the reg entries that stickout or I would galdly delete them so anyone??
If I cannot fix tis I ma slipping an SSD in and installing 7 again as this version of 8.1 is really crap compared to the ther two machines with it on and the hard drive I cannot believe Asus would install a 5400rpm drive in a achine in this day and age:sarc:
    8 Pro desk 1 (SB) 7 Home desk 2 (IB) 8 Pro Lap 1
    Own build X 2 Desk X 1 Lap X 2
    i5 2500 & i5 3570K
    Gigabyte GA_H67UD3H-B3 & Asus P8Z77-V
    8GB (1333) 8GB 2400 set 1866
    NVidia GTX 650 X 2
    Xonar DG X 2
    Philips 24" (SB) Benq 24" (IB)
    Samsung 840 X 2 830 X 1
    Corsair HX 650 & HX 1050
    Coolermaster Centurion 2 & HAF XM
    Air (SB) LC (IB)
    M6980X X 2 (laser)M$ Sidewinder X4 & Sidewinder X6 (IB)
    Gigabyte M6980 X X 2 (laser)
    ADSL2
    Google
    Kaspersky ISS
    Two other machines Toshiba L550 Sat i5 CPU running 8GB RAM and Windows 8 Pro 64bit OS.
    Toshiba A200Celeron 4GB Win7 64bit
jds63
N.Y.
2,214
Sounds like adware or spyware. Least try scanning system ? Which browser ? Know not Windows 8.1. We would all have your issues.
MRT.EXE at run command too. Try Malwarebytes Anti- Malware very good.
innunufdted ? huh ?
    Windows 10 Pro 64bit
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    AZZA Cosmas Black Gaming Case
    84mbps /94mbps
    Norton Security 2015
Yes jds I just explained to someone else I am under attack and have scanned with MBAM SAS Avira and avast free but had to remove them because the never ending pop ups drove me mad
If I could find who makes this Browser Studio crap I would delete it from the registry anything for a bit of peace.
I am going to try and install 7 on this machine using a SSD as this version of 8.1 (6.3.9600 Build 9600) is total rubbish compared to the other two machines.
    i5 2500 & i5 3570K
    NVidia GTX 650 X 2
    Xonar DG X 2
    Air (SB) LC (IB)
    ADSL2
    Google
    Kaspersky ISS
    i5 2500 & i5 3570K
    NVidia GTX 650 X 2
    Xonar DG X 2
    Air (SB) LC (IB)
    ADSL2
    Google
    Kaspersky ISS
amoled
Windows OS Stylist
93
This will do Downloading ComboFix
Make sure all antivirus soft is disabled or uninstalled and then run it.
If you find complications boot in safe mode, uninstall A/V soft and then reboot into normal mode then run combofix.
Afterwards download Chrome or firefox and install ABP ad block plus, then head to SpyBot search and Destroy, download, UPDATE (make sure you uncheck Tea Timer) from the update list.
Immunize after all updates are complete and finally run a scan with SpyBot.
Post results.
    W8 Pro 9200
    Y460
    Intel core i3 M350 2.27Ghz
    4 GB
    Intel HD graphics
    1366 x 768
amoled
Windows OS Stylist
93
After you remove all infections with Combofix and Spybot perform the following command
Press Windows Key + R and type sfc /scannow
When done reboot.
    W8 Pro 9200
    Y460
    4 GB
    Intel HD graphics
    1366 x 768
CountMike
Belgrade , Serbia
4,664
#8
I'm, afraid Win7 is no less immune to "Crap" than 8/8.1 no use blaming OS for that.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
Barman58
Super Moderator
Super Moderators
#9
Thread moved to allow malware investigation ;)
    Windows 10 Pro x64 x2 Windows 10 Enterprise x64, Ubuntu
    Real World Computing
    AMD FX8350 8 Core @4GHz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Asus nVidia GTX750TI-OC-2GD5 (2GB DDR5)
    ASUS Xoner DG + SPDIF to 5.1 System + HDMI
    Acer G276HL 27", (DVi) + Samsung 39" HDTV (HDMI)
    1920 x 1080 @60Hz + 1920 x 1080 @60Hz
    Internal
    Crucial 256GB SSD,
    WDC WD30EZRX-00D8PB0 3TB,
    Toshiba HDWD130 3TB
    Seagate ST2000DM001-1CH1 2TB,
    External (USB3)
    Seagate Backup+ Hub BK SCSI Disk 8TB
    2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs)
    NAS
    Seagate ST4000DM000
    Aerocool Templarius Imperator 750W 80+ Silver
    AeroCool X-Warrior Devil Red Tower
    Stock CPU, Rear 120mm, Front 2x120mm, Side 2x120mm
    Logitech Wireless K710 & K270
    Logitech Wireless M710 M185 & M570 Trackball
    37Mb/s Down - 9.5Mb/s Up
    Chrome
    BitDefender Total Security 2017
    Also run...
    Desktop - 6Core 8GB - Windows 10 Enterprise x64,
    Laptop - Quad 8GB - Windows 10 Pro x64
    Netbook - Ubuntu
    2 x Nexus 7 Android tablets
    Samsung 10.2" tablet
    Sony Z3 Android Smartphone
    HTC One Android Smartphone
#10
Well I guess you are right Mike but my other two 8.1 machine's never had the problems this 8.1 set up had and I certainly have not seen so much included rubbish on an install. Mind you it could have ben the original installers method I don't know but I still prefer the clean layout of 7 although I do use 8.
    i5 2500 & i5 3570K
    NVidia GTX 650 X 2
    Xonar DG X 2
    Air (SB) LC (IB)
    ADSL2
    Google
    Kaspersky ISS
jds63
N.Y.
2,214
#11
Wait where did this Browser Studio come from what is it, came on system ? Sounds more like might of went somewhere on net and took in this adware to me, unless this was an installed program.
Combofix is a good idea. Know guys here that are good at virus removal Geeks to Go - Free help from tech experts
Have all tools to fix it!
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
jds63
N.Y.
2,214
#12
True on that Mike !! Although i did like Win 7 too, always want new stuff too.
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
#14
Well I got it removed and I think it was ADW but not 100% sure.
In any case I have flipped in a SSD and an OEM 7 after configuring the BIOS and the machine runs like a cat with its' tail on fire.
What I don't get is the other machines (one laptop and one desktop) with 8.1 didn't have all the problems I had with this one and are at last 20 times faster in booting and flipping between tabs etc and now with 7 on it plus my usual programs the machine knocks spots off the other machines I have both 7 & 8 ones.
Now I put most of that down to the wretched 5400rpm spinner the machine comes with and to me to put something like that in a machine that is capable of running at very high speeds makes the manufacturers / builders look like ruddy fools. There were options for SSD's (expensive in extremis) and I cannot for the life of me understand why they didn't put a boot SSD in and a second spinner to take up the slack. Plus the version of 8 seemed to me to be more convoluted than the others but that could be just my perception.
So the boot time to login has gone from around 2 minutes to less than 32 seconds. I am not totally against 8 just I think it is for the folks who like "apps" which I do but only on my phone.
Anyway rant over and thanks to you all for the help and I think that 8 does have a place in the world who like it but not in mine except for curiosity.
    i5 2500 & i5 3570K
    NVidia GTX 650 X 2
    Xonar DG X 2
    Air (SB) LC (IB)
    ADSL2
    Google
    Kaspersky ISS
jds63
N.Y.
2,214
#15
For one having the SSD instead of a 5400RPM HD of course, even if put Win 8.1 back on sure it would still be better as notice startup times on Win8 will be.
Sometimes may just be the way it was setup by manufacturer when put in,OS.
True not right for ASUS put slow HDD for a gaming Laptop, is strange.
As for Browser Studio an Adware program somehow was downloaded or part of an existing software.
Well, your welcome from me, but i guess you needed to research more on this buy then.
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
#16
Ah well I got the 7 running now and my older Toshiba has the 8.1 on it (and it has an SSD) and now the Asus is running at close to the speed of sound ;) so I am going to leave it as is.
Asus I suppose really doesn't have that much say over what the stores put in as drives as they did have SSD's as an option but a pretty expensive one I have to say and why I slipped my own in.
Now for anyone reading this the problem is that to download any drivers for 7 that has had the 8.1 on the board one has to update the BIOS - it states this when you open support. But my only problem one was the wifi which was thankfully 8 & 7 orientated so I didn't have to run the risk of bricking the BIOS. I don't know why that had to be done but I suppose Asus have their quirky reasons.
What happens when Windows 10 comes along well it will be interesting to say the least.
    i5 2500 & i5 3570K
    NVidia GTX 650 X 2
    Xonar DG X 2
    Air (SB) LC (IB)
    ADSL2
    Google
    Kaspersky ISS
jds63
N.Y.
2,214
#17
Glad you worked things out to your satisfaction i just hope this laptop wasn't under warranty anymore because now will be voided.
Just a thought.
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    84mbps /94mbps
