Gateway won't boot from CD-drive or flash drive
I forgot my password to login to Windows. I always use the number keypad password when logging on, but now the only option is the password, which I forgot. IMy Gateway won't boot from the CDdrive or a flassh drive. I have changed the boot order in BIOS, but it goes from the hard drive anyway.
My metro apps were minimizing after 10 seconds or so. I saw a post that it could be amtivirus related, so I downloaded tools to remove the ones I had used the past year. Malwarebytes' uninstaller clean up progrm told me it needed to reboot in safe mode. I let it do so.
I only can press DEL for BIOS setup or F12. I don't have a way to change it out of safe mode.
The Metro app issue could be from a recent Windows update.
    Gateway
