Solved gateway MX6422 audio driver
lucky r
2
Just upgraded my wife's Gateway MX6422 laptop from XP to 8, but there's no sound. The speaker icon on the bottom right of the screen says "No audio device is installed." I looked on the Gateway website, but I couldn't find any windows 8 audio drivers. And since the laptop's out of warranty, Gateway won't provide any phone, chat, or email support. (!!!) Any ideas on finding this driver, or should I just try installing older ones?? Thanks for helping this noobie.
bobkn
Danbury
465
Start with the Vista drivers. You may have to resort to the compatibility troubleshooting mode.
    Window 8 Pro
    homebuilt
    I7-3930k
    Asus P9X79 Pro
    16 GB Gskill DDR3-2133
    eVGA GTX 680
    Soundblaster Zx
    Asus PA246Q
    1920X1200
    Corsair Force GT 120GB
    WD Cavair Black 1.5TB
    PC Power & cooling Silencer 750
    Silverstone FT02B-W
    Noctua NH-D14 w/ PWM fans
    cheap Logitech USB wired
    old 5 button Microsoft USB optical
    6Mb cable
lucky r
2
Thanks, bobkn. The Vista driver worked. The strange thing is that Windows said it failed to install, but it started working OK during System Maintenance. Anyway, the speakers work now!
