Solved Force "metro" to second monitor
zucram
Hi!
Anyone know of a hack or software to make sure that metro (start screen) always opens on my second monitor? This would make life with windows eight a whole lot easier.
/Zucram
    Windows 7
mdmd
Closed as requested
Hello Zucram. Welcome to Eight Forums.
Maybe this would help a little, Winkey Page/Up or Winkey Page/Down switches the screen to the other monitor. And you could drag a program or window to the other monitor. A window can be dragged back and forth and metro apps or start screen can be moved to the other monitor using the Win/PUp or Win/PDown. I do not know of any way to dedicate the start screen to 1 monitor in an extended set up.
    Server 2012 / 8.0
    Intel i7 QuadCore 3770k
    Asrock Extreme 4
    16GB Crucial Ballistix
    intel embedded gpu
    Sound Blaster Z
    AOC / Westinghouse
    Plextor pcie msata
    Rosewill Silent Night 500W Fanless / PicoPSU
    open bench - no case enclosure
    Silverstone HEO2 Passive Silent
    logitech washable K310
    logitech wired
    ie / maxthon
    Totally silent. No fans at all.
zucram
Thanks! I found that using DisplayFusion i can force a program unto a specific screen. If i have the location of "metro", basically what happenes when i press the win key this might work. Anyone know that location?
    Windows 7
moinmoin
    Win 8 x64
    intel i 7 2600k @4300
    gigabyte ga-p67a-ud3-b3
    16 gb
    nvidia geforce 460 gtx
    2x samsung syncmaster 205bw
    2x 1680x1050
    adata ssd s511 120gb
    and 2x samsung hd501lj a 500gb
Hello zacram,
By default, when you press the Windows key, the Start screen will open on whatever display it was last opened from using the start button when you hover over the left corner of the taskbar.
Hope this helps, :)
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
stijnkraft
Any new ideas on this?
Not willing to install any software to do this, like to keep my system as clean as possible.
Thanks for the
+ PgUp/PgDown idea, that's something to start with :)
    Windows 8/7/XP/2000/Ubuntu/MacOS
    Homebrew with Esi [email protected] soundcard and Dell 2007FP dualhead setup
    Intel Core2Duo E8400 (2x3ghz)
    Gigabyte EP41-UD3L
    4GB DDR2
    Nvidia Geforce 9600GT
