[Flash Player] "enable hardware acceleration" missing !
Orphydian
Closed as requested
I cant see that option anymore when right-clicking a video -on both IE and chrome and going to setings !
    Windows 8 64 bits
    Intel® Core™ i5-3350P Processor (6M Cache, up to 3.30 GHz)
    Gigabyte Intel Socket 1155 P-61-S3/rev 2.0
    4 gb ddr3
    Gigabyte GeForce gtx 660 OC 2GB
    Packard Bell Maestro 220Wdv
    1680X1050
topgundcp
Still available in Firefox
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
Orphydian
Closed as requested
    Windows 8 64 bits
    4 gb ddr3
    1680X1050
Orphydian
Closed as requested
well we had that option in the contextual menu of any flash video. Where exactly is it located now in browsers settings?
    Windows 8 64 bits
    4 gb ddr3
    1680X1050
startas
Banned
Chrome - settings -> advanced settings -> "use hardware acceleration..." down the bottom.
IE - internet options -> [tab] advanced -> THE FIRST OPTION - select to disable HA, deselect to enable.
Why are you looking for it ? its enabled by default anyway.
    ljkhlj
Orphydian
Closed as requested
I cant find it ..the last item is background aplications
    Windows 8 64 bits
    4 gb ddr3
    1680X1050
startas
Banned
Old chrome version ? or maybe try beta/dev versions, those are "as stable as chrome can be", but with newer features and have that option, cause i use it myself for now.
    ljkhlj
Orphydian
Closed as requested
I have the 26.0.1410. 64 version? isn this the latest one?. Are u sure do you have the option? Chrome has change some things recently
    Windows 8 64 bits
    4 gb ddr3
    1680X1050
Orphydian
Closed as requested
    Windows 8 64 bits
    4 gb ddr3
    1680X1050
