Solved file compression for flash drive
ckw369
8
I tried to save 4 movies on a 4GB flash drive but only had room for 3. I then started over and compressed them to 4 zip files but the flash drive will still only hold 3. Am I missing something?
    windows 8.1
OldGuyGeek
216
What are your movies file format? Most are already compressed formats that zipping will not compress further. Only changing their resolution, frame rates, etc will result in a significant file size difference. Run them through a utility like Movie Maker and target the device that you are going to be displaying on. If you are going for a large screen TV, then you're stuck. If you are going to display on a smaller, portable device, choose the format best for it.
    Self Built
    Intel I-7 860
    Asus P7B
    8GB
    Nvidia 580
    Acer (Primary), Asus (secondary), Sony TV (third)
    Kingston 128GB SSD Windows 8 Boot Drive
    WD Black 1 TB (2 ea)
    WD Red 3 TB
    WD Black 500GB
    MS 1000
    MS Flip
    Verizon FIOS 35/35
    IE 11, Google Chrome, Firefox, Opera, Safari
    Windows 8 Defender (MS Security Essentials)
ckw369
8
They are .avi but I have a converter utility if something else would be better. If I did run them through Movie Maker what would be your best estimate as to how many I could get on 4GB flash drive?
    windows 8.1
Ztruker
Wouldn't be easier to buy a larger flash drive? 4GB is pretty small now days.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    [email protected]
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
OldGuyGeek
216
It depends on what your target system is. Load up your video in Movie Maker and select File/Save Movie. You'll see a selection of target devices. Choose one. If you hove you will see the size per minute of video. So it will depend on the total size of your file.
Ztruker has a good point, though. Why not buy a bigger flash drive? You can get a 16gb for really cheap. Then you won't have to reduce the display resolution of your file.
    Self Built
    Intel I-7 860
    Asus P7B
    8GB
    Nvidia 580
    WD Red 3 TB
    WD Black 500GB
    MS 1000
    MS Flip
    Verizon FIOS 35/35
ckw369
8
it was my nieces. she asked me to do it for her and obviously i'm new at this. she was happy with the three but my not knowing why was killing me. thanks for the info.
    windows 8.1
jimbo45
Hafnarfjörður IS
4,373
Hi there
Even a Hi res movie (blu ray rip) can produce an EXCELLENT output on a full 1080p monitor from an MKV (or even MP4) rip from around 1.88 GB. These also play excellently on laptops where the max resolution is less than the mkv rip will give you (typical laptop screens 768 X 1366).
So you should be able to get around 3 HD movies on your 4GB stick -- but quite honestly why not get a 16 GB one or even a 32 GB one or put them on a small external USB HDD.
Another idea is to have them stored on a micro SDHC card on a smartphone -- then you can play them on the phone or on the computer (the computer reads the phone sdhc card as an external drive). Play with VLC.
For ripping movies HANDBRAKE does a good job. (And it's free).
BTW I ripped a Blu Ray copy of HERCULES REBORN and added some Icelandic subtitles -- file size 1.80GB and it still plays beautifully on my TV (full HD) - far better than a "Bog standard" DVD (not Blu Ray). - Pity about the movie though it's junk !!!!
(Before transcoding / ripping a Blu ray disc you have to "de-encrypt it" - there's google references all over the web on how to do that - can't discuss here as it's against Forum rules).
HandBrake: Open Source Video Transcoder
Cheers
jimbo
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
