failed restore from system image, and disk format issues
shmu
I had some software issues, and I decided to restore my SSD from a system image I had made a few days before, with Easeus.
But after restore, windows could not access the boot file.
I tried a bunch of recovery disks and command lines, but nothing worked.
when I tried to reinstall windows, once again 8.1 (but this time 64 bit), it said that my disk was not formatted with NTFS, and so I can't reinstall. (I have an older mobo, from before the windows 8 era. maybe that's related).
after messing around a little in gparted, and then going back to windows install, I was able to successfully reinstall.
question: is the format issue the reason why I couldn't boot up after restoring from a system image?
If so, how was I able to boot up until then?
And what can I do to avoid this problem in the future? I always thought that you could rely on restoring from a system image in a pinch, but this time, it let me down big time. I would have been better off wrestling a little more with the software issue. (it involved a conflict between two versions of Office that I unwisely installed on the same system. Now I learned my lesson, and I installed the alternative version of Office on a virtual machine.)
    windows 8.1 pro
AddRAM
R.I.P. Gary
We recommend using Macrium Reflect for images or windows built in imaging. I like to use both.
Macrium Reflect FREE Edition - Information and download
Who knows if EaseUS copied all the necessary partitions when you made the image. If it didn`t and you used that image, that`s why windows wouldn`t boot.
    Windows 7 Pro x64 Windows 10 Pro x64 Build 9926
    Gateway GT5404
    Intel Core 2 Duo E6700 @ 2.66 GHz
    Intel D945GCL
    4GB PC2 6400 @ 800 MHz CL 6-6-6-18
    MSI GTX660 TF3 2GB
    Realtek HD
    Gateway FPD1975W
    1440 x 900
    Samsung 850 EVO 120GB SSD / WD 500GB
    Corsair HX750
    OEM
    OEM
    Gateway KB-0401
    Gateway MOAKUO
    Verizon Quantum Gateway 60 / 60
    Chrome / IE11
    MSE / Defender / MBAM
SIW2
Team Member
I doubt that is the issue. All of the poular imaging prgrams work well - including Easeus.
    7/8/ubuntu/Linux Deepin
shmu
yes, easeus has served me well many times in the past.
I did have other issues on my computer, problems with permissions and networking. but I can't see why that would mess up the boot.
    windows 8.1 pro
AddRAM
R.I.P. Gary
Did you have a SR partition and a windows partition ?
Did you image both of them ?
    Gateway GT5404
    Intel D945GCL
    MSI GTX660 TF3 2GB
    Realtek HD
    Gateway FPD1975W
    1440 x 900
    Corsair HX750
    OEM
    OEM
    Gateway KB-0401
    Gateway MOAKUO
    Chrome / IE11
shmu
yes, I imaged both of them.
does anybody out there understand this disk format issue?
It kind of has me puzzled. I had windows 8.1 installed on my machine. then I want to reinstall it, and all of the sudden I don't have the right disk format.
I mean, what was going on until now?
    windows 8.1 pro
shmu
after doing a little research, it seems that it is possible to clone a windows installation onto a disk with the wrong format, but it will have boot problems. Probably that is what I did a year ago, but I was lucky and got it to boot somehow.
in this case, I probably could have solved my problem by going through the initial stages of a fresh windows installation, and then restoring onto it only the C drive from my system image, without the boot partition.
then, I would have a fresh boot, with my old windows installation.
    windows 8.1 pro
