Solved External hard drive shell broke, salvaged internal drive
AiO
I have a 2TB Western Digital My Book Essentials, it's filled with tons of old photos, movies, docs, games, and I'm scared to think of what else. The SATA to USB connector broke on it, so I took the drive apart and put it inside my computer. I opened up device manager because it wasn't showing up automatically and the 2TB is showing up as unallocated, I'm freaking out now because I'm scared the data was somehow deleted.
What do I do?
edit: I realize also this isn't directly related to Windows 8 (besides the fact it's the OS I'm on), but I don't know where else to post it. I'd also like to say that I had a really deep feeling the drive was going to break continually for about two weeks before it happened, so if you have a similar feeling about something, don't ignore it!
topgundcp
As long as your hard disk is still spinning & recognized by Windows, the data in your hard disk is still there, just the File Allocation Table got corrupted, You'll have a good chance to recover your data. What you need is a data recovery program, I use this program in the past:
Data Recovery Software Products - Runtime Software Products
In the mean time, leave this hard disk alone, do not initialize or format it when Windows offers to do so.
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
znod
    ASUS P8P67 Deluxe Rev B3
    16 GB Corsair Vengeance
    EVGA 570 SC
    Gateway
    Dual Boot:
    Cooler Master 932 HAF
    Zalman CNPS9900MAX-B CPU Fan
Coke Robot
Gold Member
That is scary crap, as long as the drive is spinning and isn't clicking, data is recoverable. I'd check
out the data recovery tools others posted. You'll need a hard drive to copy over the recovered data. It's not too difficult, just time consuming.
I just recently lost my 500 gig hard drive that I'm still realizing what I lost...
    ASUS
    AMD FX 8320
    Crosshair V Formula-Z
    16 gig DDR3
    ASUS R9 270
    1440x900
    x2 3 TB Toshibas
    OCZ 500 watt
    Microsoft Touch Mouse
AiO
Thanks guys, I tried a different tool with no success, I'll try the ones posted here and report back. I have two 1TB HDD's that I'll be migrating my files over to, and I will then immediately get another 2TB HDD and use a RAID level, I'll never let this happen again.
Coke Robot
Gold Member
I would look into Storage Spaces if you're on Windows 8. It's like a RAID, but easier and better to use, as you can use external hard drives with it versus needing to have the exact same type of hard drive. Makes upgrading storage pools better.
    ASUS
    AMD FX 8320
    16 gig DDR3
    ASUS R9 270
    1440x900
    x2 3 TB Toshibas
    OCZ 500 watt
AiO
I'm using MiniTools, so far it's 7% done (took 2 hours, says 29 hours remaining, not a problem though) but what worries me is it says so far it's only found 21 files... now I had thousands of pictures, hundreds of movies, games, documents, etc.. And after 7% only finding 21 files..
Coke Robot
Gold Member
It'll take a LLOOONNNGG time for it to find everything. Just because it's at 7% and found 21 files, doesn't mean everything's lost.
Seeing as it's 2 TBs and it was pretty full, it'll take a good while to scan it all.
    ASUS
    AMD FX 8320
    16 gig DDR3
    ASUS R9 270
    1440x900
    x2 3 TB Toshibas
    OCZ 500 watt
AiO
Thank you for the reassurance, here's a screenshot I just took : imgur: the simple image sharer
I noticed it's saying it scanned FAT folders/files, my HDD was NTFS formatted, will this make a difference?
Coke Robot
Gold Member
No, it's not something to be concerned about. If you checked something like Scan Entire Drive or partition, it'll check EVERYTHING, there may be a small partition that is used up for something that is in the FAT system. So far, it's still at the outer edges of the disk and hasn't moved inwards yet.
Try to be patient. :)
    ASUS
    AMD FX 8320
    16 gig DDR3
    ASUS R9 270
    1440x900
    x2 3 TB Toshibas
    OCZ 500 watt
AiO
Just finished scanning, It discovered a whopping 271 files, and I've never even seen half of them, others are just stock windows photos (such as: http://i.imgur.com/5J9Aq.png ), please, you have no idea how much this is bothering me, I have irreplaceable files on that hard drive.. I know I should of made a backup, and I intend to as soon as I recover them, but what do I do now?
labeeman
What do I do?
Your best bet is to repair the old cable or purchase a new one if it is still made and install the drive in the new one. Recover the files to a different drive.
    Win7/8 Mint
    lenovo W530
    intell i7
    Lenovo
    16gb
    512 gb ssd
    Around 13 million employes
AiO
I'm gonna try one last scan, if that fails then I'm gonna take apart another WD drive and put this one in it.
this is nuts, there was nothing wrong with the drive,just the SATA to USB adapter.
Coke Robot
Gold Member
Have you tried putting a new enclosure for that hard drive? And did you use a freeware version of the data recovery tool, I noticed it only will allow 1 gig of free to recovery.
    ASUS
    AMD FX 8320
    16 gig DDR3
    ASUS R9 270
    1440x900
    x2 3 TB Toshibas
    OCZ 500 watt
Coke Robot
Gold Member
I would suggest then to use a different program for such.
I personally use EASEUS data recovery, haven't had really any problems with it.
    ASUS
    AMD FX 8320
    16 gig DDR3
    ASUS R9 270
    1440x900
    x2 3 TB Toshibas
    OCZ 500 watt
AiO
Well good old Windows updated and restarted during my scan, so I went ahead and tried repairing the sata to usb connector, I couldn't but I cracked open another wd drive and borrowed that part, it still showed up as unallocated.
What does that mean exactly? Unallocated I mean, does it mean there's not even a file system in place?
Now I'm running EaseUS partition scan and am going to bed. Goodnight!
Try Recuva from Piriform. I've used it with great success on drives that Windows says need to be formatted and in situations like yours. Plus it's FREE. It searches the entire drive for lost files and will even recreate the complete directory structure.
Recuva - Undelete, Unerase, File and Disk Recovery - Free Download
As a last resort, I'll try formatting the drive and I'll definitely give it a try, I've used it as well to recover some small important swf files that Ccleaner (ironically another of piriforms products (makers of recuva)) deleted.thanks!
Sent via tapatalk
Coke Robot
Gold Member
Sent via tapatalk
Unallocated... Huh. Usually if the file system got messed up, Windows detects the partition as RAW, not unallocated. Can you post a screenshot of Computer and from Disk Management?
    ASUS
    AMD FX 8320
    16 gig DDR3
    ASUS R9 270
    1440x900
    x2 3 TB Toshibas
    OCZ 500 watt
incognitus
STOP!
Sorry for shouting, but if you want to have a chance to get your data back, please stop what you are doing. I hate to say it, but most of the advice given here so far is dangerously clueless/wrong. Also, formatting your drive will NOT improve your situation, don't do it!
And whatever you do, never ever just randomly use "tools" on your original drive that you want to rescue, especially if you don't know exactly what you are doing. ALWAYS make a sector image (i.e. DD) of the HDD and only work on that copy!
In regards to your problem: Have a look here (which is a better place for data recovery question), this seems to adress exactly your problem:
Western Digital MyBook essential data recovery : Hard Disk Drives: data recovery and repair
Good luck!
    Windows 8 Pro x64
