Solved External hard drive has to be opened from bitlocker
jenieragav
Dear Friends,
I have a Toshiba external hard drive. When I viewed the photos on it accidentally my friend locked with bitlocker in my absence. He has no idea about the recovery key and password. He has given some hints for the password. But all failed. Can anyone help me out of this issue.
    windows 8.1
Hello Jenieragav, and welcome to Eight Forums.
I'm afraid that if you have do not have the password or recovery key, then about the only option is to format the drive to be able to use it again. That's what BitLocker is designed for. No access with password or key. :(
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
adamf
Banned
If you use a microsoft account you can get the key from here bitlocker recovery keys
Otherwise unless it is unlocking automatically there is nothing you can do except keep guessing.
    Windows 10 Pro Prieview x64
    MacBook Pro Core2Duo
    T7600
    ATI Radeon X1600
    Internal
    1440 x 800
    40GB
    Apple
    Apple
    Varies
    Various
    Defender
adamf
Banned
Is there any idea to recover the important data before formatting?
No chance at all. That is the whole point of it as Brink said.
    T7600
    ATI Radeon X1600
    Internal
    1440 x 800
    40GB
    Apple
    Apple
    Varies
    Various
    Defender
Check what Adam posted to see if you may get lucky.
If not, then sorry, but no since BitLocker is designed to prevent access with the password or key.
    Lumia 1520 phone
    Lumia 1520 phone
adamf
Banned
    T7600
    ATI Radeon X1600
    Internal
    1440 x 800
    40GB
    Apple
    Apple
    Varies
    Various
    Defender
ingber
I am curious about a similar context: We have Thinkpad Carbon X1 PCs with TPM running Windows 8.1.1 x64 Pro. Our C: drives and our external D: drives are bitlocked using the TPM. We run nightly Acronis backup images and weekly Windows backup images of our C: drives onto our D: drives. The most current D: backups also are rsync'd across D: drives.
Say a C: drive on one PC crashes. I would like to use the most current D:-drive backup to restore this drive to the SSD.
Somehow the D: drive has to be able to be accessed by the USB Acronis media, but only after the D: drive is decrypted. How? Can the PC boot with a blank or hosed C: drive at least by opening an decrypted D: drive? Or, do I need to first install some WIndows version on the C: drive to be able to boot; or will a USB Windows recovery stick be sufficient to boot the PC and access the backups on the bitlocked D: drive?
If the above fails, I guess I could use the 2nd PC to restore the 1st PC to a new C: drive temporarily placed into the 2nd PC, using the current Acronis backup of the 1st PC on the 2nd PC's D: drive, using the bitlocker recovery keys? However, it should be easiest to directly boot and restore the affected PC only?
P.S.:
I think http://www.eightforums.com/tutorials/21433-bitlocker-recovery-unlock-drive-windows-8-a.html answers my query.
    Windows 8.1 Pro x64
