Solved External DVD Drive keeps disconnecting/reconnecting
MetalGuru
14
Like the title states: my external dvd drive keeps disconnecting and reconnecting from both the front and rear USB ports of my PC. It appears in Device Manager for a second and then disappears. The drive is connected via a SATA/USB converter and plugged directly into an electrical socket.
It also makes loading and ejecting sounds.
This is really frustrating at this point...
Thanks for your input! :)
    HP
    Eset Smart Security 6
Brooklyn567
Maryland USA
758
Is this a laptop?
How often does it connect/disconnect?
Does it do it while in use or after being left alone?
Is your computer putting it to sleep?
Change your power plan to max performance and see if the problem goes away.
If it does we can tweak the settings and go bacvk to your normal power plan
    HP G60
    3 GB
    Nvidia GeForce 8200M G
    1366 x 768
    Chrome and Chromium
    Avast Free & Malwarebytes
MetalGuru
14
It's a brand-new HP Desktop which I baught in December and had to a system recovery on the weekend due to a complication with the registry filters - my PC wouldn't boot.
It connects/disconnects every second or so.
It does it pretty much all the time it's plugged in.
I doubt my computer is putting it to sleep.
Just changed my power settings to high performance...was on balanced before.
    HP
MetalGuru
14
Edit: Same issue on laptop computer so I power-cycled the drive, unplugged all the cables then re-plugged the power cable and it's not making strange loading/ejecting noises anymore. Will try to connect it to my PC and possible burn a disk!
    HP
MetalGuru
14
Everything was going fine but the dang thing disconnected when my burning program (Imgburn) was finalizing the disk! :mad:
any help would be appreciated...
    HP
Brooklyn567
Maryland USA
758
It really looks like your computer is making it go to sleep..
lets refresh your power plan...
at elevated command prompt type powercfg -restoredefaultschemes
disable screen saver for now, see how that runs...
    HP G60
    3 GB
    1366 x 768
    Chrome and Chromium
