Solved Explorer not displaying optical drive letters in nav pane
desertdad
Win8.1/64, Dell XPS 8700, optical drive letters don't show up in the Explorer navigation pane (This PC) unless media in the drives (2). Drive letters do show up in the details pane even with no media. MS Fixit says problems found and fixed. Didn't fix the problem. Explorer++ shows drive letters in navigation pane with no media. Two optical drives, both Samsung, Both respond correctly to Samsung diagnostic. Both drives work as advertised with multiple CDs and DVDs. Both drives have drive letters in Drive Information. Only one user, admin. All Updates applied.
    windows 8.1Update build 9600
    Dell XPS 8700
    3.60 gigahertz Intel Core i74790
    Dell Inc. 0KWVT8 A03
    12G
    NVIDIA GeForce GT720
    onboard
    LG EW224
    (1) 1TB
    (1) 1TB
    tower
    air
    Logitech wired
    Logitech trackball M570, wireless
    40 down, 8 up
    Chrome - primary, IE11 - secondary
    Norton Security
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
desertdad
Unchecked the option to hide empty removable drives, cold start, did not fix the problem.
Did not download the registry fixes.
Checked the registry manually, entry already set to 0
Thanks for trying.
    Dell XPS 8700
    12G
    onboard
    LG EW224
    (1) 1TB
    (1) 1TB
    tower
    air
    Logitech wired
    40 down, 8 up
    Norton Security
Hmm, this does the same on my system as well. I'll look and see what else I may be able to find.
    Lumia 1520 phone
    Lumia 1520 phone
desertdad
Got it! Funny how little things like that are like a rock in your shoe. Thanks.
    Dell XPS 8700
    12G
    onboard
    LG EW224
    (1) 1TB
    (1) 1TB
    tower
    air
    Logitech wired
    40 down, 8 up
    Norton Security
You're most welcome. :)
    Lumia 1520 phone
