Solved Excel 2013 Help needed with a Conditional Format
pcRat
Maybe this can't be done.
Column D is my bank balance and I don't want everyone seeing it. Especially my wife who tends to spend more at the store if she sees it while I figure how much she can spend.
What I'm trying to do is to keep only the last 4 digits visible. 549.67 would only show 549.67 until I drag the mouse over it with left button down.
My wife only has one allergy. Money
    i7-3770K
    ASRock Z77 Extreme4
    16 GB
    onboard
    17" 24"
    1 TB WD
    550w
pcRat
Is this anywhere close?
font color=Automatic
=If>4 digits(left digits=White)
or smaybe something like
font color=White(last 4 digits=Automatic) ?
    i7-3770K
    ASRock Z77 Extreme4
    16 GB
    onboard
    17" 24"
    1 TB WD
    550w
pcRat
It's important that this acct shows a balance of $9.99 max even if there is $99999.99 in it.
This lame solution works in way but not really the method I'm looking for. Column D is Balance.
I filled in cells A1:d1 with med blue
Made font in column D White
Except for D1 which font is light blue
D1=D* (whatever the last Balance is) shows lightly
Why does A1: D1 without a space produce A1:D1?
    i7-3770K
    ASRock Z77 Extreme4
    16 GB
    onboard
    17" 24"
    1 TB WD
    550w
pcRat
Possible or Impossible ? To show the last 4 places of a cell's number in a different color. -Bump Up Arrow.png
    i7-3770K
    ASRock Z77 Extreme4
    16 GB
    onboard
    17" 24"
    1 TB WD
    550w
DaddyG
54
Is this solution acceptable ? You hide the column that shows your real bank balance. Let's say that column is AK. You have another column which pretends to be your bank balance. Let's say that column is AD. In each cell in column AD you have a formula such as .... =RIGHT($AK1,4). The number 1 in this example refers to the line of the first entry in the AK column and the number 4 refers to the figures to be shown (which includes the decimal point). Obviously the next entry below will be ... =RIGHT($AK2,4) and so on.
Maybe you even then password protect your spreadsheet so the hidden column can't be revealed.
I'm no expert but managed to get it working satisfactorily.
    Windows 7 Pro plus Windows 8.1 Pro VM
    Custom
    i7-3770K
    Gigabyte GA-Z77X-UD3H
    16 GB x G.SKILL Ripjaws
    GeForce GTX560
    Main - OCZ Vertex4 128 GB Solid Drive
    Sec - Hitachi Deskstar 7K1000D 1TB
    Seasonic X-760
    Coolermaster HAF912 ATX Mid Tower
    Corsair Hydro Series H80 CPU water cooler
    Eset
pcRat
=RIGHT($AK1,4) That's the ticket and it's so simple.
Thank you for the formula and simple explanation. I understand it but ... it was beyond me.
Thank you
Ron
    i7-3770K
    ASRock Z77 Extreme4
    16 GB
    onboard
    17" 24"
    1 TB WD
    550w
