Event ID 35 resulting in hard lock of system
"Performance power management features on processor 3 in group 0 are disabled due to a firmware problem. Check with the computer manufacturer for updated firmware."
I've had 180 of these since February! I've tried tonnes of malware cleaning / fixing, driver updates, and sfc fixes, but still getting these usually when gaming.
I've attached a zip of SF Diags folder.
Please help!
    Win 8.1
    Athlon II x4 645
    Sapphire Pure CrossFireX 890GX2
    EVGA GT 620
usasma
Mr. Cranky Pants
5,139
Don't be concerned about errors in the Event Viewer unless you are having problems (I said this without looking at the reports that you've uploaded).
This error in particular is saying that you may need a BIOS/UEFI update.
Once that's been updated to the latest version - don't worry about it anymore (again, unless you're having problems).
Your BIOS dates from 2011. Please check at the manufacturer's website to see if there are any BIOS updates available for your system. Also check the readme file to see if they apply to the problems that you are having. Please be advised that flashing the BIOS is a very unforgiving process - and one mistake can physically damage your motherboard.
You have a Realtek RTL8188SU Wireless LAN 802.11n USB 2.0 Network Adapter:
I do not recommend using wireless USB network devices. Especially in Win8/8.1 systems.
These wireless USB devices have many issues with Win7 and later - using Vista drivers with them is almost sure to cause a BSOD.
Should you want to keep using these devices, be sure to have Win8/8.1 drivers - DO NOT use Vista drivers!!!
An installable wireless PCI/PCIe card that's plugged into your motherboard is much more robust, reliable, and powerful.
These devices have problems in Device Manager:
Microsoft Network Adapter Multiplexor Default Miniport ROOT\NET\0000 This device is disabled.
Microsoft Hyper-V Network Switch Default Miniport ROOT\VMS_MP\0000 This device is disabled.
Please right click on each device and select "Uninstall". Reboot the system and see if these devices return. If they do, please post back for further suggestions.
Lot's of STOP 0x116 and 0x124 errors in the WER section of MSINFO32. This is suggestive of (IMO) hardware problems with your video card (although it can be other problems also). Please start with the diagnostics here (start with the video tests, but complete them all as they can all affect the video): Hardware Diagnostics
Also, here's a troubleshooting guide for STOP 0x116 errors: Video TDR Timeout - 0x116 + 0x117 - Sysnative Forums
MSI Afterburner (along with Riva Tuner and EVGA Precision) are known to cause BSOD's in some Windows systems (it's driver is usually RTCore64.sys). Please un-install them immediately!
If you're overclocking, please stop the overclock while we're troubleshooting. Feel free to resume the overclock once the system has been stabilized.
AMD OverDrive (AODDriver2.sys) is either a stand-alone application, or a component of the AMD VISION Engine Control Center. This driver is known to cause BSOD's on some Windows systems.
NOTE: these symptoms were from the previous release of OverDrive. The new release uses the same driver name, but is dated from 4 November 2013.
Please un-install all AMD/ATI video stuff from Control Panel...Programs...Un-install a program
Then, download (but DO NOT install) a fresh copy of the ATI drivers from Global Provider of Innovative Graphics, Processors and Media Solutions | AMD (in the upper right corner of the page)
Use this procedure to install the DRIVER ONLY: ATI video cards - DRIVER ONLY installation procedure - Sysnative Forums
If the device (AODDriver or AODDriver4.01) remains a problem, open Device Manager, select the "View" item.
Then select "Show hidden devices" and scroll down to the Non-Plug and Play Drivers section.
Locate the AODDriver entry, right click on it and select "Un-install". Reboot for changes to take affect.
Sometimes the driver remains and continues to cause BSOD's. If this is the case for you, post back and we'll give further instructions for safely removing it.
If overclocking, please stop. Remove the overclock and return the system to stock/standard values while we're troubleshooting. Once the system is stable again, feel free to resume the overclocking.
nm3.sys Wed Jun 9 20:05:51 2010 (4C102C5F)
Network Monitor 3 NDIS 6.0 Monitoring Filter Driver
http://www.carrona.org/drivers/driver.php?id=nm3.sys
AtihdW86.sys Tue Jun 7 06:34:39 2011 (4DEDFEBF)
AMD High Definition Audio Function Driver
http://www.carrona.org/drivers/driver.php?id=AtihdW86.sys
Please note the drivers below that date from before the release of Windows 8.1 (17 Oct 2013) - check to see that each and every one is compatible w/Windows 8.1 (at the manufacturer's website). If not, you must either remove the device and it's software - or locate a Windows 8.1 compatible update on the web. Removing some drivers may make the system unstable - so if you're unable to find updates, post back for info on the one's that can/cannot be safely removed.
Analysis:
[font=lucida console]**************************Thu Mar 13 20:11:30.153 2014 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\031414-24718-01.dmp]
Windows 8 Kernel Version 9600 MP (4 procs) Free x64
Built by: [B]9600[/B].16452.amd64fre.winblue_gdr.131030-1505
System Uptime:[B]1 days 14:21:17.877[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::OKHAJAOM::`string'+e30 )[/B]
BugCheck [B]C000021A, {ffffc00014048550, 0, 0, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#Example]WINLOGON_FATAL_ERROR (c000021a)[/url]
Arguments:
Arg1: ffffc00014048550, String that identifies the problem.
Arg2: 0000000000000000, Error Code.
Arg3: 0000000000000000
Arg4: 0000000000000000
BUGCHECK_STR:  0xc000021a_DCOM_Terminated
PROCESS_NAME:  services.exe
FAILURE_BUCKET_ID: [B]0xc000021a_DCOM_Terminated_nt!_??_::OKHAJAOM::_string_[/B]
  BIOS Version                  080015
  BIOS Release Date             01/27/2011
  Manufacturer                  To Be Filled By O.E.M.
  Product Name                  To Be Filled By O.E.M.
**************************Sat Mar  8 17:27:19.387 2014 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\030814-22906-01.dmp]
System Uptime:[B]0 days 0:02:15.110[/B]
*** WARNING: Unable to verify timestamp for atikmpag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmpag.sys
Probably caused by :[B]atikmpag.sys ( atikmpag+78c8 )[/B]
BugCheck [B]116, {ffffe000060c44d0, fffff800018258c8, 0, 2}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#Example]VIDEO_TDR_FAILURE (116)[/url]
Arguments:
Arg1: ffffe000060c44d0, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff800018258c8, The pointer into responsible device driver module (e.g. owner tag).
Arg3: 0000000000000000, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 0000000000000002, Optional internal context dependent data.
BUGCHECK_STR:  0x116
DEFAULT_BUCKET_ID:  GRAPHICS_DRIVER_TDR_FAULT
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]0x116_IMAGE_atikmpag.sys[/B]
  BIOS Version                  080015
**************************Sat Mar  8 16:47:09.221 2014 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\030814-20328-01.dmp]
System Uptime:[B]0 days 0:07:30.944[/B]
BugCheck [B]116, {ffffe0000064e010, fffff8000188f8c8, 0, 2}[/B]
Arguments:
Arg1: ffffe0000064e010, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff8000188f8c8, The pointer into responsible device driver module (e.g. owner tag).
BUGCHECK_STR:  0x116
  BIOS Version                  080015
**************************Sat Mar  8 16:39:06.052 2014 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\030814-21078-01.dmp]
System Uptime:[B]0 days 0:38:34.777[/B]
BugCheck [B]116, {ffffe00001268010, fffff800017808c8, 0, 2}[/B]
Arguments:
Arg1: ffffe00001268010, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff800017808c8, The pointer into responsible device driver module (e.g. owner tag).
BUGCHECK_STR:  0x116
  BIOS Version                  080015
**************************Sat Mar  8 16:00:01.185 2014 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\030814-20515-01.dmp]
System Uptime:[B]0 days 2:06:07.910[/B]
BugCheck [B]116, {ffffe00004dcc4d0, fffff80001a438c8, 0, 2}[/B]
Arguments:
Arg1: ffffe00004dcc4d0, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff80001a438c8, The pointer into responsible device driver module (e.g. owner tag).
BUGCHECK_STR:  0x116
  BIOS Version                  080015
**************************Wed Mar  5 06:58:32.856 2014 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\030514-57062-01.dmp]
System Uptime:[B]0 days 22:42:17.582[/B]
BugCheck [B]116, {ffffe00002a9c4d0, fffff80001a368c8, 0, 2}[/B]
Arguments:
Arg1: ffffe00002a9c4d0, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff80001a368c8, The pointer into responsible device driver module (e.g. owner tag).
BUGCHECK_STR:  0x116
  BIOS Version                  080015
**************************Sun Mar  2 09:44:31.623 2014 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\030214-29062-01.dmp]
System Uptime:[B]0 days 0:16:33.346[/B]
Probably caused by :[B]AuthenticAMD[/B]
BugCheck [B]124, {0, ffffe00001b07028, b4602000, 2a000135}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000124]WHEA_UNCORRECTABLE_ERROR (124)[/url]
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: ffffe00001b07028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000b4602000, High order 32-bits of the MCi_STATUS value.
Arg4: 000000002a000135, Low order 32-bits of the MCi_STATUS value.
BUGCHECK_STR:  0x124_AuthenticAMD
PROCESS_NAME:  dwm.exe
FAILURE_BUCKET_ID: [B]0x124_AuthenticAMD__UNKNOWN[/B]
  BIOS Version                  080015
**************************Sun Mar  2 09:27:22.593 2014 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\030214-41484-01.dmp]
System Uptime:[B]3 days 18:21:55.336[/B]
BugCheck [B]124, {0, ffffe00001abe028, b6004000, dc000135}[/B]
Arguments:
Arg2: ffffe00001abe028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000b6004000, High order 32-bits of the MCi_STATUS value.
Arg4: 00000000dc000135, Low order 32-bits of the MCi_STATUS value.
  BIOS Version                  080015
**************************Wed Feb 26 15:04:55.157 2014 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\022614-26343-01.dmp]
System Uptime:[B]3 days 2:22:03.883[/B]
BugCheck [B]116, {ffffe0000101a4d0, fffff80001ad58c8, 0, 2}[/B]
Arguments:
Arg1: ffffe0000101a4d0, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff80001ad58c8, The pointer into responsible device driver module (e.g. owner tag).
BUGCHECK_STR:  0x116
  BIOS Version                  080015
**************************Sun Feb 23 12:42:20.127 2014 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\022314-23578-01.dmp]
System Uptime:[B]0 days 3:51:07.070[/B]
BugCheck [B]124, {0, ffffe00001a65028, b6754000, 75000135}[/B]
Arguments:
Arg2: ffffe00001a65028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000b6754000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000075000135, Low order 32-bits of the MCi_STATUS value.
PROCESS_NAME:  DivXEngine.exe
  BIOS Version                  080015
[/font]
3rd Party Drivers:
[COLOR=RED][B]nm3.sys                     Wed Jun  9 20:05:51 2010 (4C102C5F)[/B][/COLOR]
[COLOR=RED][B]AtihdW86.sys                Tue Jun  7 06:34:39 2011 (4DEDFEBF)[/B][/COLOR]
[COLOR=RED][B]AODDriver2.sys              Tue Mar  6 04:55:00 2012 (4F55DEF4)[/B][/COLOR]
GEARAspiWDM.sys             Thu May  3 15:56:17 2012 (4FA2E2E1)
usbfilter.sys               Tue Aug 28 21:27:12 2012 (503D6FF0)
amd_sata.sys                Fri Nov 30 04:00:42 2012 (50B875BA)
amd_xata.sys                Fri Nov 30 04:00:46 2012 (50B875BE)
RTKVHD64.sys                Fri Mar 29 09:40:06 2013 (515599B6)
atikmpag.sys                Wed Apr 24 11:48:16 2013 (5177FEC0)
atikmdag.sys                Wed Apr 24 12:37:45 2013 (51780A59)
HWiNFO64A.SYS               Sat May 11 03:17:38 2013 (518DF092)
atikmpag.sys                Wed Nov  9 21:12:44 2011 (4EBB331C)
atikmdag.sys                Wed Nov  9 21:52:46 2011 (4EBB3C7E)
RTL8192su.sys               Thu Mar 28 03:41:32 2013 (5153F42C)
[COLOR=RED][B]RTCore64.sys                Mon Mar 11 01:32:06 2013 (513D6C56)[/B][/COLOR]
atikmpag.sys                Mon Jun 18 16:41:29 2012 (4FDF9279)
atikmdag.sys                Mon Jun 18 17:21:01 2012 (4FDF9BBD)
[/font]
http://www.carrona.org/drivers/driver.php?id=AODDriver2.sys
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
http://www.carrona.org/drivers/driver.php?id=usbfilter.sys
http://www.carrona.org/drivers/driver.php?id=amd_sata.sys
http://www.carrona.org/drivers/driver.php?id=amd_xata.sys
http://www.carrona.org/drivers/driver.php?id=HWiNFO64A.SYS
http://www.carrona.org/drivers/driver.php?id=RTL8192su.sys
http://www.carrona.org/drivers/driver.php?id=RTCore64.sys
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
Thanks for your reply. I'll run through any of the steps I havent tried and revert.
    Win 8.1
    Athlon II x4 645
    EVGA GT 620
mikeytg
Joisey
315
    Windows 8.1 consumer 64 bit
    Acer Aspire M5 481PT-6644
    Intel Core I5
    6 GB
    ELAN Trackpad
    18mbs/5mbs
    Chrome
    Win 8.1
    Athlon II x4 645
    EVGA GT 620
