Ethernet not working while wifi does on clean 8.1 install
sfkickz
82579V gigabit controller
So, I recently did a fresh install of 8.1 on my custom rig. Hardware's all about 5 years old. Encountered some issues with memory (bad stick identified) and BSODs(Killer NIC seemed to be the cause). These issues are presented here: http://answers.microsoft.com/thread/dbe97ac1-e207-4b75-aa54-08727dfc2c10.
After removing the Killer NIC, i tried using the onboard Intel 82579V gigabit controller. Here's where i encountered this new issue. windows network diagnostics tells me "Ethernet" doesn't have a valid IP configuration. the built in diagnostics for the card say "This adapter is configured to obtain an
IP address automatically but no DHCP server
is present on the network. Windows selected
an IP address using Alternate Private
IP Addressing. "
I then bit the bullet and did another clean install. The first driver I then installed was the onboard NIC with the driver provided by Intel: https://downloadcenter.intel.com/download/23071/Network-Adapter-Driver-for-Windows-8-1-
same thing. I'm nearing the end of my rope and considering just upgrading my mobo and CPU.
recently installed 8.1 on my custom rig. Intel z68bc board with an i5 2500k and GTX570. Ran into some issues with memory (bad stick removed) and BSODs (Killer NIC identified as the culprit). most of my situation is outlined here: MULTIPLE IRP COMPLETE REQUESTS - Microsoft Community
I bit the bullet and did another clean install. first thing installed is the latest driver for my intel 82579V gigabit controller. encountered the same issues as before.
I am on comcast xfinity and connect through the ethernet to a router which is hooked up to the modem. the ethernet works perfectly when I hook it up to my laptop. seems the issue is with my PC itself and not the ISP/cable/router/modem. reflashed the BIOS for the board since I noticed it had been updated a lot since my version with some LAN updates. Reinstalled everything and Ethernet issue remains.
Windows IP Configuration
Host Name . . . . . . . . . . . . : Erik-PC
Wireless LAN adapter Local Area Connection* 3:
Physical Address. . . . . . . . . : 74-2F-68-64-EC-C2
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : 74-F0-6D-F3-1A-C0
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : 802.11bgn 1T1R Wireless Adapter
Physical Address. . . . . . . . . : 74-2F-68-64-EC-C0
Link-local IPv6 Address . . . . . : fe80::c4aa:d6b0:e9:52b%4(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.6(Preferred)
Lease Obtained. . . . . . . . . . : Monday, June 29, 2015 1:49:02 AM
Lease Expires . . . . . . . . . . : Tuesday, June 30, 2015 8:56:44 AM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 74723176
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1D-22-BD-13-38-60-77-60-A6-2D
DNS Servers . . . . . . . . . . . : 192.168.1.1
Ethernet adapter Ethernet:
Description . . . . . . . . . . . : Intel(R) 82579V Gigabit Network Connection
Physical Address. . . . . . . . . : 38-60-77-60-A6-2D
Link-local IPv6 Address . . . . . : fe80::2c7a:22c3:39eb:995f%3(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.153.95(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
DHCPv6 IAID . . . . . . . . . . . : 54026359
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Tunnel adapter isatap.{1B49BCAC-38D7-4709-A4B8-0976B42CB480}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Tunnel adapter isatap.{D35F878E-5CF0-41C5-AF85-A6663BFD96EA}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Description . . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
Pinging yahoo.com [98.139.183.24] with 32 bytes of data:
Reply from 98.139.183.24: bytes=32 time=379ms TTL=45
Reply from 98.139.183.24: bytes=32 time=406ms TTL=45
Reply from 98.139.183.24: bytes=32 time=236ms TTL=45
Reply from 98.139.183.24: bytes=32 time=437ms TTL=45
Ping statistics for 98.139.183.24:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 236ms, Maximum = 437ms, Average = 364ms
AutoConfigProxy REG_SZ wininet.dll
MigrateProxy REG_DWORD 0x1
ProxyEnable REG_DWORD 0x0
IPCONFIG /ALL disconnected from wifi
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
Ping request could not find host yahoo.com. Please check the name and try again.
If you go to the internet settings can you manually enter the settings?
IPv4 Address. . . . . . . . . . . : 192.168.1.6 (Preferred)
You may want to try using Googles' DNS servers. See https://developers.google.com/speed/public-dns/docs/using
DNS IPv4: 8.8.8.8 and/or 8.8.4.4
^will give that a go when I get home from work though i'm not optimistic. already tried basically that (IP was 192.168.1.13 instead) with no results.
AS Expected, no cigar on manually entering the addresses.
