Ethernet connection going through wireless router
ThatOneSix
Hello, friends,
So, I have a weird issue. The other day, I was playing League and my connection started dropping. I spent a couple of days troubleshooting everything I could think of - using multiple PCs, swapping ethernet ports, messing with my router, etc. After a lot of frustration, I had an idea.
Now, on my roommate's PC, he could play League with no issue. On my laptop and my desktop, I couldn't do anything without my connection failing. Bear in mind, I'm hard wired and he's on wifi. Now, our router has a 2.4 ghz band and a 5 ghz band. His wifi connection is on the 5 band, and, as I mentioned, he had no issues. I asked him to swap over to the 2.4 connection, and all of a sudden, lag spikes everywhere.
So, from that we managed to deduce that the 2.4 ghz band on our router is dying. That's all well and good, but now we have another issue - why is our network connection trying to force its way through the wireless router? We tried hardwiring 4 different PCs, and 3 of them are defaulting to the wireless router networks, even when the wireless adapters are turned off. My laptop and desktop are defaulting to 2.4, my roommate's desktop is defaulting to 5, and our last desktop is connection just to "Network". Below is a screenshot of my network connections.
I tried doing an ipconfig /release, /renew, /flushdns, but I got the following error - "The operation failed as no adapter is in the state permissible for this operation." I'm completely lost as to what to do, now. Any and all help would be greatly appreciated. Please let me know if there's any more information I can provide.
Here are the spec for our network set-up:
Main Router: PFSense virtualized on top of ESXI 5.5
PFSense is the only DHCP lease distributor.
Wireless Router: ASUS Black Diamond (wifi passthrough only)
Switch: Unmanaged ASUS 24 port gigabit
Welcome to the forum!
Choose to "forget" the wireless network. Turn off wireless SSID broadcast on the router. Unselect "connect automatically" for the wireless network. Select "connect automatically" for the wired network.
Thank you for the welcome.
That's the thing - I don't actually have a wireless adapter in my PC, so I don't have the option to forget a network available to me. Should I connect a wireless adapter?
Your System Specs show nothing about your computer. Most Notebooks do have a Wi-Fi adapter as well as an Ethernet port. I have seen some Desktops that have a built-in Wi-Fi adapter as well as the Ethernet port. If a desktop has a Wi-Fi adapter there's usually an antenna on the back of the computer but I have seen a couple of newer Desktops that had no antenna, seem to be a feature borrowed from Notebooks. Device Manager should show what the machine has.
I am hard-wired to the gigabit switch, and I do not have a wireless adapter plugged in right now. That's the weird thing - even though I don't even have a wireless adapter, my connection is going through the wireless router's 2.4 ghz band, when it should be going through the switch right into the modem.
Like Berton said, you most likely have a wireless adapter in your laptop that is enabled. Hard to help without make/model of laptop and other specs.
Three of those adapters you show are not working, disabled.
This is actually my desktop, not my laptop. I only ever use the laptop for troubleshooting or when I'm away from home, so it's not a huge deal if that doesn't work. I've attached my dxdiag below. I put it in a code box so that it doesn't look super ugly. I can also upload the .txt, if it would help.
Edit: Yeah, I manually disabled them when I was troubleshooting. I can re-enable them, but I really doubt it will make any difference.
------------------System Information
Time of this report: 2/1/2015, 20:00:07
       Machine name: SIXIUSPRIME
   Operating System: Windows 8.1 Pro 64-bit (6.3, Build 9600) (9600.winblue_r5.141029-1500)
           Language: English (Regional Setting: English)
System Manufacturer: INTEL
       System Model: DZ77GA
               BIOS: Default System BIOS
          Processor: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz (8 CPUs), ~3.5GHz
             Memory: 16384MB RAM
Available OS Memory: 16354MB RAM
          Page File: 3577MB used, 15207MB available
        Windows Dir: C:\Windows
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
   User DPI Setting: Using System DPI
 System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
     DxDiag Version: 6.03.9600.17415 64bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
      Display Tab 2: No problems found.
      Display Tab 3: No problems found.
        Sound Tab 1: No problems found.
        Sound Tab 2: No problems found.
        Sound Tab 3: No problems found.
        Sound Tab 4: No problems found.
        Sound Tab 5: No problems found.
        Sound Tab 6: No problems found.
        Sound Tab 7: No problems found.
        Sound Tab 8: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
          Card name: NVIDIA GeForce GTX 680
       Manufacturer: NVIDIA
          Chip type: GeForce GTX 680
           DAC type: Integrated RAMDAC
        Device Type: Full Device
         Device Key: Enum\PCI\VEN_10DE&DEV_1180&SUBSYS_36883842&REV_A1
     Display Memory: 12172 MB
   Dedicated Memory: 3995 MB
      Shared Memory: 8176 MB
       Current Mode: 1920 x 1080 (32 bit) (60Hz)
       Monitor Name: Generic PnP Monitor
      Monitor Model: ASUS VH236H
         Monitor Id: ACI23F2
        Native Mode: 1920 x 1080(p) (60.000Hz)
        Output Type: HD15
        Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 9.18.0013.4052 (English)
     Driver Version: 9.18.13.4052
        DDI Version: 11
     Feature Levels: 11.0,10.1,10.0,9.3,9.2,9.1
       Driver Model: WDDM 1.3
Graphics Preemption: DMA
 Compute Preemption: DMA
           Miracast: Not Supported
Hybrid Graphics GPU: Not Supported
     Power P-states: Not Supported
  Driver Attributes: Final Retail
   Driver Date/Size: 7/2/2014 15:48:32, 17555104 bytes
        WHQL Logo'd: n/a
    WHQL Date Stamp: n/a
  Device Identifier: {D7B71E3E-52C0-11CF-2654-85161CC2C435}
          Vendor ID: 0x10DE
          Device ID: 0x1180
          SubSys ID: 0x36883842
        Revision ID: 0x00A1
 Driver Strong Name: oem1.inf:0f066de34a918dd5:Section095:9.18.13.4052:pci\ven_10de&dev_1180
     Rank Of Driver: 00DA2001
        Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
        DXVA2 Modes: DXVA2_ModeMPEG2_IDCT  DXVA2_ModeMPEG2_VLD  DXVA2_ModeVC1_VLD  DXVA2_ModeVC1_IDCT  DXVA2_ModeWMV9_IDCT  DXVA2_ModeH264_VLD_NoFGT
   Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
       D3D9 Overlay: Supported
            DXVA-HD: Supported
       DDraw Status: Enabled
         D3D Status: Enabled
         AGP Status: Enabled
      Monitor Model: TOSHIBA-TV
         Monitor Id: TSB0206
        Output Type: HDMI
        DDI Version: 11
        WHQL Logo'd: n/a
          Vendor ID: 0x10DE
          Device ID: 0x1180
        Revision ID: 0x00A1
            DXVA-HD: Supported
         D3D Status: Enabled
         AGP Status: Enabled
      Monitor Model: SAMSUNG
         Monitor Id: SAM094F
        Output Type: HDMI
        DDI Version: 11
        WHQL Logo'd: n/a
          Vendor ID: 0x10DE
          Device ID: 0x1180
        Revision ID: 0x00A1
            DXVA-HD: Supported
         D3D Status: Enabled
         AGP Status: Enabled
Sound Devices
            Description: Speakers (Sound Blaster Z)
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: HDAUDIO\FUNC_01&VEN_1102&DEV_0011&SUBSYS_11020023&REV_1009
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: cthda.sys
         Driver Version: 6.00.0102.0023 (English)
            WHQL Logo'd: n/a
          Date and Size: 7/3/2013 15:52:16, 1060632 bytes
            Other Files:
        Driver Provider: CREATIVE
         HW Accel Level: Basic
              Cap Flags: 0x0
    Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
            Description: Digital Audio (S/PDIF) (High Definition Audio Device)
 Default Sound Playback: No
 Default Voice Playback: No
            Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0899&SUBSYS_80862037&REV_1000
        Manufacturer ID: 1
             Product ID: 65535
                   Type: WDM
            Driver Name: HdAudio.sys
         Driver Version: 6.03.9600.16384 (English)
            WHQL Logo'd: n/a
          Date and Size: 8/22/2013 06:38:21, 395776 bytes
            Other Files:
        Driver Provider: Microsoft
              Cap Flags: 0x0
              HW Memory: 0
            Description: SPDIF-Out (Sound Blaster Z)
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            WHQL Logo'd: n/a
            Other Files:
              Cap Flags: 0x0
              HW Memory: 0
            Description: TOSHIBA-TV-8 (NVIDIA High Definition Audio)
            Hardware ID: HDAUDIO\FUNC_01&VEN_10DE&DEV_0040&SUBSYS_38423688&REV_1001
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: nvhda64v.sys
         Driver Version: 1.03.0030.0001 (English)
            WHQL Logo'd: n/a
          Date and Size: 8/11/2014 15:31:46, 197408 bytes
            Other Files:
        Driver Provider: NVIDIA Corporation
              Cap Flags: 0x0
              HW Memory: 0
        Manufacturer ID: 1
             Product ID: 65535
                   Type: WDM
            WHQL Logo'd: n/a
            Other Files:
              Cap Flags: 0x0
              HW Memory: 0
            Description: SAMSUNG-4 (NVIDIA High Definition Audio)
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            WHQL Logo'd: n/a
            Other Files:
              Cap Flags: 0x0
              HW Memory: 0
            Description: Headphones (High Definition Audio Device)
        Manufacturer ID: 1
             Product ID: 65535
                   Type: WDM
            WHQL Logo'd: n/a
            Other Files:
              Cap Flags: 0x0
              HW Memory: 0
            Description: Speakers (High Definition Audio Device)
        Manufacturer ID: 1
             Product ID: 65535
                   Type: WDM
            WHQL Logo'd: n/a
            Other Files:
              Cap Flags: 0x0
              HW Memory: 0
Sound Capture Devices
            Description: Microphone (USB Audio Device)
  Default Sound Capture: Yes
  Default Voice Capture: Yes
            Driver Name: USBAUDIO.sys
         Driver Version: 6.03.9600.16490 (English)
          Date and Size: 12/13/2013 02:24:20, 121088 bytes
              Cap Flags: 0x0
           Format Flags: 0x0
            Description: Microphone (High Definition Audio Device)
  Default Sound Capture: No
  Default Voice Capture: No
              Cap Flags: 0x0
           Format Flags: 0x0
            Description: Line In (High Definition Audio Device)
              Cap Flags: 0x0
           Format Flags: 0x0
            Description: Digital-In (Sound Blaster Z)
              Cap Flags: 0x0
           Format Flags: 0x0
            Description: What U Hear (Sound Blaster Z)
              Cap Flags: 0x0
           Format Flags: 0x0
              Cap Flags: 0x0
           Format Flags: 0x0
Video Capture Devices
Number of Devices: 0
DirectInput Devices
      Device Name: Mouse
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Keyboard
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: G110 G-keys
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC22B
        FF Driver: n/a
      Device Name: Gaming Mouse G502
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC07D
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
      Device Name: Gaming Keyboard G110
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC22A
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x1E26
| Matching Device ID: USB\ROOT_HUB20
| Service: usbhub
| Driver: usbhub.sys, 7/24/2014 10:28:38, 419648 bytes
| Driver: usbd.sys, 5/31/2014 05:07:07, 27480 bytes
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0024
| | Matching Device ID: USB\Class_09
| | Service: usbhub
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| Service: kbdhid
| Driver: kbdhid.sys, 11/4/2014 01:54:47, 32256 bytes
| Driver: kbdclass.sys, 11/4/2014 14:25:09, 59712 bytes
| Service: kbdhid
| Service: kbdhid
+ HID-compliant mouse
| Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| Service: mouhid
| Driver: mouhid.sys, 11/4/2014 01:54:47, 30208 bytes
| Driver: mouclass.sys, 11/4/2014 14:25:09, 51008 bytes
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 325.4 GB
Total Space: 476.6 GB
File System: NTFS
      Model: Samsung SSD 840 EVO 500GB
      Drive: E:
 Free Space: 745.8 GB
Total Space: 1907.6 GB
File System: NTFS
      Model: WDC WD2002FAEX-007BA0
      Drive: K:
      Model: ATAPI iHAS424   B
     Driver: c:\windows\system32\drivers\cdrom.sys, 6.03.9600.16384 (English), 8/22/2013 03:46:35, 164352 bytes
      Drive: L:
      Model: ASUS DRW-24B1ST   a
System Devices
     Name: NVIDIA GeForce GTX 680
Device ID: PCI\VEN_10DE&DEV_1180&SUBSYS_36883842&REV_A1\4&3613A165&0&0008
   Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 9.18.0013.4052 (English), 7/2/2014 15:48:32, 441120 bytes
   Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 7/2/2014 15:48:32, 1192732 bytes
   Driver: C:\Windows\System32\DriverStore\FileRepository\nv_disp.inf_amd64_4e98351181b80fc5\NvCplSetupEng.exe, 1.00.0001.0000 (English), 7/2/2014 15:48:32, 33568328 bytes
   Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\Nvd3d9wrap.dll, 9.18.0013.4052 (English), 7/2/2014 15:48:32, 164496 bytes
   Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\detoured.dll, 7/2/2014 15:48:32, 13272 bytes
   Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvdxgiwrap.dll, 9.18.0013.4052 (English), 7/2/2014 15:48:32, 113008 bytes
   Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\Nvd3d9wrapx.dll, 9.18.0013.4052 (English), 7/2/2014 15:48:32, 191264 bytes
   Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\detoured.dll, 7/2/2014 15:48:32, 13088 bytes
   Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvdxgiwrapx.dll, 9.18.0013.4052 (English), 7/2/2014 15:48:32, 130488 bytes
   Driver: C:\Program Files\NVIDIA Corporation\license.txt, 7/2/2014 15:48:32, 21904 bytes
   Driver: C:\Program Files\NVIDIA Corporation\NVSMI\MCU.exe, 1.01.5204.20580 (English), 7/2/2014 15:48:32, 842528 bytes
   Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvdebugdump.exe, 6.14.0013.4052 (English), 7/2/2014 15:48:32, 229320 bytes
   Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.1.pdf, 7/2/2014 15:48:32, 56700 bytes
   Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe, 8.17.0013.4052 (English), 7/2/2014 15:48:32, 338776 bytes
   Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvml.dll, 8.17.0013.4052 (English), 7/2/2014 15:48:32, 649160 bytes
   Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll, 1.00.0000.0000 (English), 7/2/2014 15:48:32, 61912 bytes
   Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL64.dll, 1.00.0000.0000 (English), 7/2/2014 15:48:32, 75040 bytes
   Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 9.18.0013.4052 (English), 7/2/2014 15:48:32, 12866008 bytes
   Driver: C:\Windows\system32\NvFBC64.dll, 6.14.0013.4052 (English), 7/2/2014 15:48:32, 903624 bytes
   Driver: C:\Windows\system32\NvIFR64.dll, 6.14.0013.4052 (English), 7/2/2014 15:48:32, 944928 bytes
   Driver: C:\Windows\system32\NvIFROpenGL.dll, 9.18.0013.4052 (English), 7/2/2014 15:48:32, 391640 bytes
   Driver: C:\Windows\system32\nvEncodeAPI64.dll, 6.14.0013.4052 (English), 7/2/2014 15:48:32, 502232 bytes
   Driver: C:\Windows\system32\nvapi64.dll, 9.18.0013.4052 (English), 7/2/2014 15:48:32, 3196816 bytes
   Driver: C:\Windows\system32\nvcompiler.dll, 8.17.0013.4052 (English), 7/2/2014 15:48:32, 22994208 bytes
   Driver: C:\Windows\system32\nvcuda.dll, 8.17.0013.4052 (English), 7/2/2014 15:48:32, 13835208 bytes
   Driver: C:\Windows\system32\nvcuvid.dll, 7.17.0013.4052 (English), 7/2/2014 15:48:32, 4247000 bytes
   Driver: C:\Windows\system32\nvd3dumx.dll, 9.18.0013.4052 (English), 7/2/2014 15:48:32, 17555104 bytes
   Driver: C:\Windows\system32\nvinfo.pb, 7/2/2014 15:48:32, 26353 bytes
   Driver: C:\Windows\system32\nvinitx.dll, 9.18.0013.4052 (English), 7/2/2014 15:48:32, 166568 bytes
   Driver: C:\Windows\system32\nvmcumd.dll, 7/2/2014 15:48:32, 835032 bytes
   Driver: C:\Windows\system32\nvoglshim64.dll, 9.18.0013.4052 (English), 7/2/2014 15:48:32, 354016 bytes
   Driver: C:\Windows\system32\nvoglv64.dll, 9.18.0013.4052 (English), 7/2/2014 15:48:32, 31512520 bytes
   Driver: C:\Windows\system32\nvopencl.dll, 8.17.0013.4052 (English), 7/2/2014 15:48:32, 13922752 bytes
   Driver: C:\Windows\system32\nvumdshimx.dll, 9.18.0013.4052 (English), 7/2/2014 15:48:32, 965312 bytes
   Driver: C:\Windows\system32\nvwgf2umx.dll, 9.18.0013.4052 (English), 7/2/2014 15:48:32, 18626304 bytes
   Driver: C:\Windows\SysWow64\NvFBC.dll, 6.14.0013.4052 (English), 7/2/2014 15:48:32, 869152 bytes
   Driver: C:\Windows\SysWow64\NvIFR.dll, 6.14.0013.4052 (English), 7/2/2014 15:48:32, 907096 bytes
   Driver: C:\Windows\SysWow64\NvIFROpenGL.dll, 9.18.0013.4052 (English), 7/2/2014 15:48:32, 348120 bytes
   Driver: C:\Windows\SysWow64\nvEncodeAPI.dll, 6.14.0013.4052 (English), 7/2/2014 15:48:32, 418760 bytes
   Driver: C:\Windows\SysWow64\nvapi.dll, 9.18.0013.4052 (English), 7/2/2014 15:48:32, 2814656 bytes
   Driver: C:\Windows\SysWow64\nvcompiler.dll, 8.17.0013.4052 (English), 7/2/2014 15:48:32, 15294296 bytes
   Driver: C:\Windows\SysWow64\nvcuda.dll, 8.17.0013.4052 (English), 7/2/2014 15:48:32, 11222048 bytes
   Driver: C:\Windows\SysWow64\nvcuvid.dll, 7.17.0013.4052 (English), 7/2/2014 15:48:32, 3989960 bytes
   Driver: C:\Windows\SysWow64\nvd3dum.dll, 9.18.0013.4052 (English), 7/2/2014 15:48:32, 14498552 bytes
   Driver: C:\Windows\SysWow64\nvinit.dll, 9.18.0013.4052 (English), 7/2/2014 15:48:32, 146480 bytes
   Driver: C:\Windows\SysWow64\nvoglshim32.dll, 9.18.0013.4052 (English), 7/2/2014 15:48:32, 305600 bytes
   Driver: C:\Windows\SysWow64\nvoglv32.dll, 9.18.0013.4052 (English), 7/2/2014 15:48:32, 24196896 bytes
   Driver: C:\Windows\SysWow64\nvopencl.dll, 8.17.0013.4052 (English), 7/2/2014 15:48:32, 11283344 bytes
   Driver: C:\Windows\SysWow64\nvumdshim.dll, 9.18.0013.4052 (English), 7/2/2014 15:48:32, 846832 bytes
   Driver: C:\Windows\SysWow64\nvwgf2um.dll, 9.18.0013.4052 (English), 7/2/2014 15:48:32, 16122344 bytes
   Driver: C:\Windows\system32\nvdispco6434052.dll, 2.00.0040.0004 (English), 7/2/2014 15:48:32, 1890080 bytes
   Driver: C:\Windows\system32\nvdispgenco6434052.dll, 2.00.0019.0002 (English), 7/2/2014 15:48:32, 1539928 bytes
     Name: Intel(R) 82579V Gigabit Network Connection
Device ID: PCI\VEN_8086&DEV_1503&SUBSYS_20378086&REV_04\3&11583659&0&C8
   Driver: C:\Windows\system32\DRIVERS\e1c64x64.sys, 12.10.0029.0000 (English), 5/2/2014 12:35:24, 468752 bytes
   Driver: C:\Windows\system32\e1c64x64.din, 3/25/2013 14:21:28, 3114 bytes
   Driver: C:\Windows\system32\NicCo36.dll, 2.01.0002.0000 (English), 4/30/2013 02:15:58, 36472 bytes
   Driver: C:\Windows\system32\NicInstC.dll, 9.11.0002.0000 (English), 7/11/2013 03:27:30, 89888 bytes
   Driver: C:\Windows\system32\e1cmsg.dll, 10.00.0159.0000 (English), 7/25/2013 03:08:50, 73480 bytes
     Name: Sound Blaster Audio Controller
Device ID: PCI\VEN_1102&DEV_0012&SUBSYS_00231102&REV_01\4&31F0305E&0&00E0
   Driver: C:\Windows\system32\drivers\cthdb.sys, 6.00.0102.0023 (English), 7/3/2013 15:52:38, 34072 bytes
   Driver: C:\Windows\system32\drivers\hdaudbus.sys, 6.03.9600.17238 (English), 7/24/2014 06:45:39, 76800 bytes
     Name: Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E2D
Device ID: PCI\VEN_8086&DEV_1E2D&SUBSYS_20378086&REV_04\3&11583659&0&D0
   Driver: C:\Windows\system32\drivers\usbehci.sys, 6.03.9600.17195 (English), 5/31/2014 05:07:08, 89944 bytes
   Driver: C:\Windows\system32\drivers\usbport.sys, 6.03.9600.17195 (English), 5/31/2014 05:07:07, 440664 bytes
   Driver: C:\Windows\system32\drivers\usbhub.sys, 6.03.9600.17238 (English), 7/24/2014 10:28:38, 419648 bytes
     Name: Standard SATA AHCI Controller
Device ID: PCI\VEN_1B4B&DEV_9172&SUBSYS_20378086&REV_11\6&1E6FB528&0&002000E5
   Driver: C:\Windows\system32\DRIVERS\storahci.sys, 6.03.9600.16384 (English), 8/22/2013 07:43:31, 107872 bytes
     Name: Xeon(R) processor E3-1200 v2/3rd Gen Core processor PCI Express Root Port - 0151
Device ID: PCI\VEN_8086&DEV_0151&SUBSYS_20378086&REV_09\3&11583659&0&08
   Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.03.9600.17238 (English), 7/24/2014 10:28:35, 280384 bytes
     Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10B5&DEV_8606&SUBSYS_860610B5&REV_BA\5&125C39B8&0&4800E5
Device ID: PCI\VEN_8086&DEV_1E02&SUBSYS_20378086&REV_04\3&11583659&0&FA
     Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 8 - 1E1E
Device ID: PCI\VEN_8086&DEV_1E1E&SUBSYS_20378086&REV_C4\3&11583659&0&E7
Device ID: PCI\VEN_10B5&DEV_8606&SUBSYS_860610B5&REV_BA\5&125C39B8&0&3800E5
     Name: Intel(R) Z77 Express Chipset LPC Controller - 1E44
Device ID: PCI\VEN_8086&DEV_1E44&SUBSYS_20378086&REV_04\3&11583659&0&F8
   Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.03.9600.16384 (English), 8/22/2013 07:43:49, 17248 bytes
Device ID: PCI\VEN_1B4B&DEV_9172&SUBSYS_20378086&REV_11\4&2D5689C&0&00E7
Device ID: PCI\VEN_10B5&DEV_8606&SUBSYS_860610B5&REV_BA\5&125C39B8&0&2800E5
     Name: Intel(R) 7 Series/C216 Chipset Family SMBus Host Controller - 1E22
Device ID: PCI\VEN_8086&DEV_1E22&SUBSYS_20378086&REV_04\3&11583659&0&FB
   Driver: n/a
     Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 5 - 1E18
Device ID: PCI\VEN_8086&DEV_1E18&SUBSYS_20378086&REV_C4\3&11583659&0&E4
     Name: High Definition Audio Controller
Device ID: PCI\VEN_10DE&DEV_0E0A&SUBSYS_36883842&REV_A1\4&3613A165&0&0108
   Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.03.9600.17238 (English), 7/24/2014 06:45:39, 76800 bytes
     Name: Texas Instruments 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_104C&DEV_8023&SUBSYS_20378086&REV_00\7&26AEE1BA&0&10004800E5
   Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.03.9600.16384 (English), 8/22/2013 06:38:15, 231424 bytes
     Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 1 - 1E10
Device ID: PCI\VEN_8086&DEV_1E10&SUBSYS_20378086&REV_C4\3&11583659&0&E0
Device ID: PCI\VEN_10B5&DEV_8606&SUBSYS_860610B5&REV_BA\5&125C39B8&0&2000E5
     Name: Intel(R) 82574L Gigabit Network Connection
Device ID: PCI\VEN_8086&DEV_10D3&SUBSYS_20378086&REV_00\4&231E0FF3&0&00E4
   Driver: C:\Windows\system32\DRIVERS\e1i63x64.sys, 12.06.0047.0000 (English), 6/18/2013 09:45:26, 460288 bytes
     Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_1E3A&SUBSYS_20378086&REV_04\3&11583659&0&B0
   Driver: C:\Windows\system32\DRIVERS\HECIx64.sys, 8.01.0000.1263 (English), 7/17/2012 20:12:08, 62784 bytes
Device ID: PCI\VEN_10B5&DEV_8606&SUBSYS_860610B5&REV_BA\5&125C39B8&0&0800E5
     Name: Intel(R) USB 3.0 eXtensible Host Controller - 0100 (Microsoft)
Device ID: PCI\VEN_8086&DEV_1E31&SUBSYS_20378086&REV_04\3&11583659&0&A0
   Driver: C:\Windows\system32\DRIVERS\UCX01000.SYS, 6.03.9600.17393 (English), 10/7/2014 01:54:45, 189248 bytes
   Driver: C:\Windows\system32\DRIVERS\USBXHCI.SYS, 6.03.9600.17393 (English), 10/7/2014 01:54:45, 324928 bytes
Device ID: PCI\VEN_8086&DEV_1E20&SUBSYS_20378086&REV_04\3&11583659&0&D8
Device ID: PCI\VEN_10B5&DEV_8606&SUBSYS_860610B5&REV_BA\4&106F5178&0&00E5
     Name: Intel(R) Gigabit CT Desktop Adapter
Device ID: ROOT\NET\0000
   Driver: C:\Windows\system32\DRIVERS\e1q63x64.sys, 12.07.0027.0000 (English), 4/30/2013 02:15:58, 467216 bytes
   Driver: C:\Windows\system32\e1q63x64.din, 4/30/2013 02:15:58, 3097 bytes
   Driver: C:\Windows\system32\NicInstQ.dll, 9.11.0000.0000 (English), 4/30/2013 02:15:58, 101152 bytes
   Driver: C:\Windows\system32\e1qmsg.dll, 10.00.0152.0000 (English), 4/30/2013 02:15:58, 73480 bytes
     Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 6 - 1E1A
Device ID: PCI\VEN_8086&DEV_1E1A&SUBSYS_20378086&REV_C4\3&11583659&0&E5
Device ID: PCI\VEN_1283&DEV_8892&SUBSYS_202F8086&REV_30\6&1355EF97&0&004800E5
     Name: Xeon(R) processor E3-1200 v2/3rd Gen Core processor DRAM Controller - 0150
Device ID: PCI\VEN_8086&DEV_0150&SUBSYS_20378086&REV_09\3&11583659&0&00
   Driver: n/a
     Name: Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E26
Device ID: PCI\VEN_8086&DEV_1E26&SUBSYS_20378086&REV_04\3&11583659&0&E8
     Name: Intel(R) Gigabit CT Desktop Adapter #2
Device ID: PCI\VEN_8086&DEV_10D3&SUBSYS_A01F8086&REV_00\6&33F2345&0&000800E5
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.03.9600.17415
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.03.9600.17415
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.03.9600.17415
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.03.9600.17415
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.03.9600.17415
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.03.9600.17415
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.03.9600.17415
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.03.9600.17415
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.03.9600.17415
DV Muxer,0x00400000,0,0,qdv.dll,6.06.9600.17415
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.9600.17415
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.9600.17415
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.9600.17415
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.9600.17415
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.9600.17415
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.9600.17374
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.9600.17415
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.9600.17415
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.9600.17415
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.9600.17415
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.9600.17415
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.9600.17415
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.9600.17415
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.9600.17415
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.9600.17415
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,12.00.9600.17415
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.9600.17415
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.9600.17415
DV Splitter,0x00600000,1,2,qdv.dll,6.06.9600.17415
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.9600.17415
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,12.00.9600.17415
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.9600.17415
Video Renderer,0x00800001,1,0,quartz.dll,6.06.9600.17415
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.9600.17415
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.9600.17415
Video Renderer,0x00400000,1,0,quartz.dll,6.06.9600.17415
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.9600.17415
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.9600.17415
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.03.9600.17415
File writer,0x00200000,1,0,qcap.dll,6.06.9600.16384
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.9600.17415
Overlay Mixer2,0x00200000,1,1,,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,12.00.9600.17415
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.9600.17415
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.9600.17415
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.9600.17415
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.9600.17415
Null Renderer,0x00200000,1,0,qedit.dll,6.06.9600.17415
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.9600.17415
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.03.9600.17415
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.9600.17415
Smart Tee,0x00200000,1,2,qcap.dll,6.06.9600.16384
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.9600.17415
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.9600.17415
Wave Parser,0x00400000,1,1,quartz.dll,6.06.9600.17415
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.9600.17415
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.9600.17415
File stream renderer,0x00400000,1,1,quartz.dll,6.06.9600.17415
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,12.00.9477.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.9600.17415
AVI Mux,0x00200000,1,0,qcap.dll,6.06.9600.16384
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.9600.17415
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.9600.17415
File Source (URL),0x00400000,0,1,quartz.dll,6.06.9600.17415
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.9600.16384
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.03.9600.17415
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.9600.17415
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.9600.17415
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.03.9600.17415
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.03.9600.17415
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.03.9600.17415
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.03.9600.17415
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.9600.17415
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.9600.17415
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.03.9600.17415
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.03.9600.17415
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.9600.17415
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.9600.17415
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.9600.17415
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.9600.17415
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.9600.17415
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.9600.17415
Audio Capture Sources:
Microphone (USB Audio Device),0x00200000,0,0,qcap.dll,6.06.9600.16384
Microphone (High Definition Audio Device),0x00200000,0,0,qcap.dll,6.06.9600.16384
Line In (High Definition Audio Device),0x00200000,0,0,qcap.dll,6.06.9600.16384
Digital-In (Sound Blaster Z),0x00200000,0,0,qcap.dll,6.06.9600.16384
What U Hear (Sound Blaster Z),0x00200000,0,0,qcap.dll,6.06.9600.16384
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.9600.17415
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.9600.17415
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.9600.17415
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.9600.17415
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.9600.17415
WDM Streaming Capture Devices:
Sound Blaster What U Hear,0x00200000,1,1,ksproxy.ax,6.03.9600.17415
Sound Blaster Digital-In,0x00200000,1,1,ksproxy.ax,6.03.9600.17415
Sound Blaster Microphone,0x00200000,1,1,ksproxy.ax,6.03.9600.17415
HD Audio Mixed capture,0x00200000,1,1,ksproxy.ax,6.03.9600.17415
,0x00000000,0,0,,
,0x00000000,0,0,,
USB Audio Device,0x00200000,1,1,ksproxy.ax,6.03.9600.17415
WDM Streaming Rendering Devices:
HD Audio Speaker,0x00200000,1,1,ksproxy.ax,6.03.9600.17415
HD Audio SPDIF out 2,0x00200000,1,1,ksproxy.ax,6.03.9600.17415
HD Audio SPDIF out,0x00200000,1,1,ksproxy.ax,6.03.9600.17415
HD Audio Headphone,0x00200000,1,1,ksproxy.ax,6.03.9600.17415
Sound Blaster SPDIF-Out,0x00200000,1,1,ksproxy.ax,6.03.9600.17415
Sound Blaster Speaker/Headphone,0x00200000,1,1,ksproxy.ax,6.03.9600.17415
,0x00000000,0,0,,
,0x00000000,0,0,,
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.9600.17415
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.9600.17415
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.9600.17415
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.9600.17415
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.9600.17415
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.9600.17415
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.9600.17415
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.9600.17415
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.9600.17415
PTFilter,0x00200000,0,0,EncDec.dll,6.06.9600.17415
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.9600.17415
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (Sound Blaster Z),0x00200000,1,0,quartz.dll,6.06.9600.17415
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.9600.17415
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.9600.17415
DirectSound: Digital Audio (S/PDIF) (High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.9600.17415
DirectSound: SPDIF-Out (Sound Blaster Z),0x00200000,1,0,quartz.dll,6.06.9600.17415
DirectSound: TOSHIBA-TV-8 (NVIDIA High Definition Audio),0x00200000,1,0,quartz.dll,6.06.9600.17415
DirectSound: SAMSUNG-4 (NVIDIA High Definition Audio),0x00200000,1,0,quartz.dll,6.06.9600.17415
DirectSound: Headphones (High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.9600.17415
DirectSound: Speakers (High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.9600.17415
DirectSound: Speakers (Sound Blaster Z),0x00200000,1,0,quartz.dll,6.06.9600.17415
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
  <transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
  Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 12.00.9600.17374
  DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 6.03.9600.17415
  Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 6.03.9600.17415
  Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 12.00.9600.17374
  WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 6.03.9600.17415
  WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 6.03.9600.17415
  MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 6.03.9600.17415
  Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 6.03.9600.17415
  Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 6.03.9600.17415
Video Encoders:
  H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 6.03.9600.17415
  WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 6.03.9600.17415
  WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 6.03.9600.17415
  Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 12.00.9600.17415
Video Effects:
  Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 6.03.9600.17415
  Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 6.03.9600.17415
  VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 6.03.9600.17415
  Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 6.03.9600.17415
  Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 6.03.9600.17415
Video Processor:
  Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 12.00.9600.17415
Audio Decoders:
  Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, MSAudDecMFT.dll, 6.03.9600.17415
  WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 6.03.9600.17415
  Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 6.03.9600.17415
  A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 12.00.9600.17415
  GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 12.00.9600.17415
  WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 6.03.9600.17415
  Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 6.03.9600.17415
  WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 6.03.9600.17415
  G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 12.00.9600.17415
  IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 12.00.9600.17415
  MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 6.03.9600.17415
  ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 12.00.9600.17415
Audio Encoders:
  MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 12.00.9600.17415
  WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 6.03.9600.17415
  Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 12.00.9600.17415
  WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 6.03.9600.17415
  Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 6.03.9600.17415
  Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 6.03.9600.17415
Audio Effects:
  AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 6.03.9600.17415
  Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 6.03.9600.17415
Multiplexers:
  Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 12.00.9600.17415
Others:
  Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 12.00.9600.17374
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableDecoders = 0
EnableEncoders = 1
EnableVideoProcessors = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
httpnd:, {2EEEED04-0908-4CDB-AF8F-AC5B768A34C9}, Drm Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
  Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
  Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
  PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Fault bucket , type 0
Event Name: MpTelemetry
Response: Not available
Cab Id: 0
Problem signature:
P1: 2152759308
P2: unspecified
P3: ScanFile
P4: 4.6.305.0
P5: Windows Defender (77BDAF73-B396-481F-9042-AD358843EC24)
P6: unspecified
P7: unspecified
P8:
P9:
P10:
+++ WER1 +++:
Cab Id: 0
Problem signature:
P1: 2152759308
P2: unspecified
P3: ScanFile
P4: 4.6.305.0
P6: unspecified
P7: unspecified
P8:
P9:
P10:
+++ WER2 +++:
Fault bucket 90805954716, type 5
Event Name: WindowsUpdateFailure2
Cab Id: 0
Problem signature:
P1: 7.9.9600.17489
P2: 8024000e
P3: 00000000-0000-0000-0000-000000000000
P4: Scan
P5: 101
P6: Unmanaged {855E8A7C-ECB4-4CA3-B045-1DFA50104289}
P7: 0
P8:
P9:
P10:
+++ WER3 +++:
Cab Id: 0
Problem signature:
P1: 7.9.9600.17489
P2: 8024000e
P4: Scan
P5: 101
P7: 0
P8:
P9:
P10:
+++ WER4 +++:
Cab Id: 0
Problem signature:
P1: 7.9.9600.17489
P2: 8024000e
P4: Scan
P5: 101
P7: 0
P8:
P9:
P10:
+++ WER5 +++:
Cab Id: 0
Problem signature:
P1: 2152759308
P2: unspecified
P3: ScanFile
P4: 4.6.305.0
P6: unspecified
P7: unspecified
P8:
P9:
P10:
+++ WER6 +++:
Cab Id: 0
Problem signature:
P1: 2152759308
P2: unspecified
P3: ScanFile
P4: 4.6.305.0
P6: unspecified
P7: unspecified
P8:
P9:
P10:
+++ WER7 +++:
Fault bucket 94556099069, type 5
Event Name: AppHangB1
Cab Id: 0
Problem signature:
P1: rads_user_kernel.exe
P2: 0.0.0.0
P3: 4e65c1ac
P4: da45
P5: 134217728
P6:
P7:
P8:
P9:
P10:
+++ WER8 +++:
Event Name: APPCRASH
Cab Id: 0
Problem signature:
P1: NCS2Prov.exe
P2: 19.5.302.0
P3: 54403589
P4: CoreAgnt.dll
P5: 19.5.302.0
P6: 54403448
P7: c0000005
P8: 00000000000147f8
P9:
P10:
+++ WER9 +++:
Cab Id: 0
Problem signature:
P1: NCS2Prov.exe
P2: 19.5.302.0
P3: 54403589
P4: CoreAgnt.dll
P5: 19.5.302.0
P6: 54403448
P7: c0000005
P9:
P10:
I dont think it actually means that, It might just be selecting the first name on your router for what to call the connection on your pc, my wifi is disabled and my ethernet connection is called "... 2.4"
