Effectiveness of Using PC "Reset" to solve specific issue
CPWin8
I've had a problem discussed in depth here:
http://www.eightforums.com/general-...trol-panel-empty-my-docs-library-problem.html
A system restore did not work. PC "refresh" did not work (got me crazy). I've done a number of checks/scans (CHKDSK/ScanDisk, sfc /scannow, Windows Defender, TDSSKILLER, and Malwarebytes Anti-Rootkit) without any threats/errors occurring (I know it's not an exhaustive list.). I'm at my wits' end.
Simply, I understand that "reset" (http://www.eightforums.com/tutorials/2302-reset-windows-8-a.html) supposedly (and I'll get to why I say that) removes everything and reinstalls.
Assuming this is a copy of the Windows 8 that was originally activated the first day I used my computer, I should be by the above definition be able to go back and rebuild what had been a system without this problem for about five months (length of time since purchased, approx.). I also have burned recovery DVDs from the first day of use.
There must have been a reason that "Refresh" didn't help. It's beyond me.
To all of you, is this Reset as good as the old reinstallation from discs that I'd done, for example, on XP in the past?
Do I need to wipe everything or can I just do the quick (just remove files, not fully clean) reset?
I can't imagine anything outside of the OS causing my situation. Can anyone? Is there any way with "Reset" (assuming not an OS issue alone) that the problem can migrate to the new "installation?" I've never updated the BIOS or any such thing.
Any advice here? Thanks.
    Toshiba Satellite L855
    Intel Core i7
    6Gb
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
XweAponX
You should use Windows Easy Transfer to backup your Programs and Dos and Settings.
    AMD 4400+/4200+
    2 GB/3GB
    GeForce 8400 GS/GeForce 210
    Hitachi 40" LCD HDTV
    "1842 x 1036"
    WD My Book 1140 USB Device
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Microsoft Intellimouse
    Cable Medium Speed
    Chrome/IE 10
    Eset NOD32 6.x/Win Defend
