DVD-RW won't burn - Toshiba Satellite Pro C850
loubie32
4
Hi all :)
For some reason, neither my internal nor external DVD writers will burn DVDs. My internal DVD-RW is a tsstcorp cddvdw sn-208ab. Th external DVD-RW is a tsstcorp cddvdw se-208db.
For a while I could burn a DVD by using "Fix it", but then I'd have to reboot, use "Fix it" again, but now that doesn't work at all.
Sometimes there is one driver shown (C:\WINDOWS\system32\DRIVERS\cdrom.sys) and sometimes there is a 2nd driver (C:\WINDOWS\system32\DRIVERS\GEARAspiWDM.sys).
I've tried uninstalling the DVD-RW drives, and rebooting.
I installed the Gear driver update, but then I couldn't find it in its location.
About 6 months ago, I had similar problems and fixed it by deleting registry keys (upperfilters & lowerfilters), and that fixed the problem at the time.
Maybe I need those keys back? One site recommended adding an UpperFilter within the same folder, containing the text "GEARAspiWDM" & rebooting, which SOMETIMES allows me to burn ONE disc, then the reg key is gone.
I tried uninstalling the most recent Windows update, but it made no difference.
I have used a range of burning software- doesn't seem to make a difference.
Any suggestions would be appreciated :)
    AVG
popeye
United States
3,090
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
loubie32
4
Ok, thanks.
Here's a couple of clues to solve my riddle:
1. When I view the drive's properties, it labels it a "CD-ROM". Same with the external drive. But the icons both say DVD-RW.
2. When I open itunes, it alerts me that I won't be able to burn discs because of the registry settings.
Hmmm.
    AVG
popeye
United States
3,090
My point was I would get rid of Gear. That's all I got.
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    1600x900 pixels
    90 watt brick
    Bluetooth
    Comodo
CountMike
Belgrade , Serbia
4,664
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
loubie32
4
It's definitely a problem with the drivers or the registry - both the internal & external dvd-rw.
Both have C:\WINDOWS\system32\DRIVERS\cdrom.sys as their drivers, which can't be right since they're not cd-roms.
I've just realised neither drive will play DVDs :S
Thanks to those who suggested different burners, but I've tried the best & the rest already!
    AVG
CountMike
Belgrade , Serbia
4,664
#8
Mine shows the same and yet works just fine, both as DVD and CD reader and writer.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
loubie32
4
#9
I'm missing the second driver and your screen shot isn't clear enough for me to read!
Can you please type the name of the driver? Thanks :)
    AVG
CountMike
Belgrade , Serbia
4,664
#10
C:\windows\System32\Drivers\PxHlpa64.sys but I think it's proprietary for my Pioneer DVD-RW DVR-112D machine. The first one (cdrom.sys) is part of a driver ever since DOS days and it had to be included in Autorun,sys for CD to work.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
