DVD Burning problems
kingrollo
39
This seems a common problem in all early releases of windows. I basically open up the dvd drive in windows - past the files I want to burn to dvd - then I get that folder shortcut 'you have have files waiting to be burned' - but I don't get an option burn on right click.
I was in a hurry tonight - so just fired up power2go - burnt disc no problems ?
Any idea wots wrong with with Windows burning
23,532
    3 x 27" Asus VE278Q
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
XweAponX
Usually all you need to do is double click on the DVD burner icon in Windows File Explorer and the Burn Window will pop up, it will ask you if you wanna burn them as a USB drive or as a DVD/CD. Just open My Computer and double click the DVD drive.
    AMD 4400+/4200+
    2 GB/3GB
    GeForce 8400 GS/GeForce 210
    Hitachi 40" LCD HDTV
    "1842 x 1036"
    WD My Book 1140 USB Device
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Microsoft Intellimouse
    Cable Medium Speed
    Chrome/IE 10
    Eset NOD32 6.x/Win Defend
kingrollo
39
Thats the crux of the problem - I don't get the DVD burner ICON.
23,532
Did you already do what I posted above to clear this? :)
    3 x 27" Asus VE278Q
    256GB OCZ Vector,
    Logitech MX Master
    Lumia 1520 phone
pedro38
West Sussex, UK
29
Burn to DVD failure.
I d/l win 8.1iso and burnt to DVD on my win 8 desktop with no problem.
On my wife's Samsung win 8 laptop I also d/l win 8.1 iso ok but burn to DVD failed twice, firstly with windows burn and secondly with PowertoGo. For the latter I got an error code 0xeb020ba0 which could indicate either an incomplete, faulty file or faulty media (all DVDs used were Verbatim).
Anyway, I copied the iso file from the laptop to a USB pen drive which I then plugged into my desktop and then burnt the iso file directly and successfully from the USB drive to DVD with Windows burn.
In light of this might there be a hardware/software issue on the laptop that caused the burn fails?
Any thoughts will be appreciated.
Pedro
    Windows 8.1 Pro 64 bit w/Media Center
    Home build
    Core i7-3770
    Gigabyte Z77X -UD5H LG1155 (V. 1.0)
    Crucial 32Gb DDR3 1600mHz
    Gigabyte AMD Radeon GV-R785OC-2GB
    on board
    Lenovo L220 xwC ThinkVision
    1920 x 1200
    2 x Crucial M4 512Gb SSD
    1 x Samsung 1TB USB3 Ext HDD
    OCZ ZS 650W
    Corsair Carbide 400R
    Noctua - C12P SE14
    Microsoft Wireless 5000 Series
    35Mbs down 8Mbs up
    2 x Samsung SH-224 24x SATA ReWriter Optical Drives
    1 x NZXT 5.25" Internal Card Reader / 2 x USB3 ports
    Logitech C615 Webcam
    Hauppage WinTV 7 HD
XweAponX
So, Windows is not detecting a Blank DVD in there, but other programs do, is that right?
Something got whacked during install, I'd do an In-Place Install, re-install your OS right over the top of the one that's doing this, do it from within Windows 8, choose "Upgrade" and it will re-install Windows 8 and repair anything that is missing or messed up. You should be able to use your license key, you may have to do a Phone Activation with it.
    AMD 4400+/4200+
    2 GB/3GB
    "1842 x 1036"
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Cable Medium Speed
    Chrome/IE 10
pedro38
West Sussex, UK
29
#8
That's not quite correct. In both Windows burn and Power2Go burn, the laptop 'saw' the blank DVDs, and asked me whether to be a re-writable or mastered finish. In both cases, the files wrote to the media and it was only in the final stages of verification that I got the 'burn failed' message. But as I said, I transferred the files to my desktop PC where I was able to successfully burn a Windows 8.1 ISO DVD for the laptop. However, thanks for your suggestion. I will do a repair and see if that cures what might be problem with the optical drive and its drivers.
Pedro
    Home build
    Core i7-3770
    on board
    1920 x 1200
    OCZ ZS 650W
    Noctua - C12P SE14
    35Mbs down 8Mbs up
    Hauppage WinTV 7 HD
XweAponX
Ok, it won't finalize then.
How about Firmware Revisions for your Optical Drive. You can use Speccy or some other program to identify your Optical Drive Hardware make and model number. Sometimes you can pull this from Device Manager.
Check at
The Firmware Page ? Index page
For firmware revisions for the drive, if you can't find the OEM website. Just google "Firmware for (Make and Model of Drive)" - Sometimes, someone at RPC1 will have a file backed up you can use.
    AMD 4400+/4200+
    2 GB/3GB
    "1842 x 1036"
    Works 550w
    MSI "M-Box"
    Water Cooled
    Dell Keyboard
    Cable Medium Speed
    Chrome/IE 10
