Dual Monitor - Secondary Monitor Flashing Issues
Justin121
I recently purchased another monitor so I can run dual-monitors on my newly upgraded-to Windows 8 desktop. I set the monitor up last night, and I haven't had any major issues so far... One issue that I've run into, though, is the secondary monitor (regardless whether it's the monitor I owned first or the one I just bought) flashes randomly. Last night, a restart fixed the issue, so I didn't think anything of it. Today when I started it up, it was fine again for about 5-10 minutes. Then it began to flash randomly. It's not a constant steady flash, it only happens once every 3-10 minutes, but it shouldn't be happening. Does anyone else have the same problem and/or have suggestions on how to fix it?
Add'l info:
Monitors (both connected via HDMI, primary to primary gfx card, secondary to secondary gfx card)
1x Asus VW246H 24"
1x Asus VE248H 24"
Both set to 1920x1080p resolution, left as primary, right as secondary.
GFX:
2x EVGA Nvidia GTX 560 Ti's in SLI Configuration
Most recent stable Nvidia drivers are installed. I'll test the beta ones later and update this if anything changes.
    Windows 8 Pro
    Home-Built
    Intel i7-2700k
    Asus SABERTOOTH Z77
    16 Gb Corsair Vengeance LP (2x8GB, 2 more on the way)
    2x NVidia GTX 560 Ti Fermi in SLI Configuration
