Dual Display Wallpaper Disappearing issue
bascotie
4
Hi guys,
I'm running Windows 8 pro with 2 screens.
The desktop wallpaper disappears quite often. Sometimes if I "refresh" on a certain screen, the desktop will come back temporarily.
Any idea on how to fix this?
    Windows 8 Pro
    Custom
    Athlon X3 445 (unlocked to 4 cores)
    M3A770DE
    8GB G-Skill DDR3 667MHz
    Radeon HD 6800 series
    N/A
    2 (1 @ 1680 x 1050 [email protected] 1980 x 1080)
    See monitor displays
    SSD + 2 storage SATA drives
    Earthwatts 380W
    Antec
    Avast + Malwarebytes
topgundcp
San Jose - California
2,847
You did not provide any information in your "My System Specs" so we don't know what kind of PC/Laptop you have. However, I am giving you some guess work here:
  1. Update your video driver to the latest
  2. Resize the wall paper to match exactly the same as your monitor resolution
  3. If the file size of the Wallpaper you use is huge then you might need to optimize it down to reasonable size so it will not take too much time to load/refresh. Normally the size of the wallpaper is 300-400K but I've seen cases where people use an image with 2-3 Meg in size.
Hope this helps !!!
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
Along with topgoundcp excellent advice, check your system for any malware and spyware along with Virus's. These are known to cause such issues your are experiencing.
    Custom build
    AMD Phenom II X 4 965 BE
    Gigabyte GA-MA790X-DS4
    G-Skill 8 GB PC 8500
    AMD XFX HD Radeon 6790D
    Realtek HD onboard
    2l Samsung SyncMaster S20B300
    1600 X 900
    Seagate Barracuda 320 GB w/OS
    Cooler Master Hyper212 120mm
    Logitech G510
    Razor DeathAdder 3.5
474
If you still have the same problem after following the 2 guys' advice above, check 2 more things:
1. Is your wallpaper in slideshow mode and you have "Shuffle" enabled? (See photo) Disable "Shuffle" mode.
and 2.) Wallpapers occassionaly disappears if you have an unactivated windows OS installed. You need to activate it if you haven't done so.
Cheers!
    Win 8 (64) : Win 7 (64) : Vista (64) : Android JB 4.2 : iOS 6
    Acer AX Series & HP i-5 2400s
    Main PC - 2x Sony PS3 3D LED Displays + 1x 22" Philips; HTPC - 47" HDTV w/ 17" LCD secondary display
    Internal- 1TB on each system; 1x120GB SSD on main PC
    External (network attached)- 1x2TB Seagate backup; 1x1TB ext. storage; 1x500GB,
    http://tinyurl.com/br4uxrk
    http://tinyurl.com/cwj93pj
bascotie
4
Thanks guys,
I'm updating my system specs right now in USER CP.
This is a fresh install of Windows and it started happening immediately, so I don't think it is malware.
I've tried the latest video driver, as well as the beta driver to no avail.
My screens are 1680 x 1050 and 1980 x 1080. If it is any help, I did not have this issue on Win 7 Pro.
Windows is activated.
Shuffling is off.
I tried setting the wallpaper again from my documents (location of picture) and it appeared, then disappeared after refreshing.
Image size is 574KB.
Thanks!
    Windows 8 Pro
    Custom
    M3A770DE
    N/A
    Earthwatts 380W
    Antec
topgundcp
2,847
Temporarily disable Avast + Malwarebytes, set both monitors to be the same resolution 1680X1050 to see if you still get the same behavior.
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
474
Do you have the same problem with only one monitor running? How about adjusting refresh rate?
bascotie
4
#8
Same issue with one monitor initially... after setting the wallpaper again it hasn't disappeared yet, though. Refresh rates are set to default
    Windows 8 Pro
    Custom
    M3A770DE
    N/A
    Earthwatts 380W
    Antec
bascotie
4
#9
Oddly enough, since changing my TV display to 59Hz (vs 60), i haven't had problems. Gonna wait and see how it plays out.
The TV model is X405BV-FHD
    Windows 8 Pro
    Custom
    M3A770DE
    N/A
    Earthwatts 380W
    Antec
474
#10
Actually, I came across that refresh rate setup when I first fire up may Win 8 system. I didn't pay attention to it but there was a prompt telling me to adjust the refresh rate when using a TV screen. Because I am using my Win 8 system as HTPC. But for regular computer displays, it's ok to leave it at default setting.
Lazure
149
#11
My laptop HDMI'd into an HDTV has this same problem. I use "show on monitor 2" setting (or what they used to call projection mode, where ONLY the HDTV displays content). Any time I unplug the HDMI or the power goes out and the HDTV turns off, the laptop switches to its own display. Any time this occurs, my wallpaper goes black. Also happens again when the HDTV is reconnected and the screen switches back to it.
If I right click desktop and pick 'next desktop wallpaper', the wallpaper does return, but it resets back at the first wallpaper in the list instead of remembering where it left off. :(
    Windows 8.1 Pro 64-Bit, Ubuntu 13.04 64-Bit
    Custom Built
    Intel Core i7 950 @ 3ghz
    Asus Sabertooth X58
    Crucial 6GB DDR3 1066mhz Triple Channel
    1GB EVGA GTX 460 SE (Nvidia)
    Dual LG Monitors
    1920x1080, 1280x1024
    80GB Intel 320 Series SSD
    640GB WD Caviar Blue
    320GB WD MyBook (converted to Internal SATA)
    1TB Seagate Barracuda
    Corsair 650TX 650w
    CoolerMaster HAF 922
    Logitech G110
    Logitech G500
    20mbps Down, 2mbps Up
dirtyvu
1,127
#12
also verify that none of the pictures are corrupt.
I had that problem. I download wallpapers regularly from InterfaceLift. But once I download them, I didn't bother to check them. Once I found out certain images weren't loading, I noticed they didn't have proper thumbnails (just the generic cartoon picture frame) and they wouldn't load in Photoshop.
