Solved Driver_irql_not_less_or_equal
dartanqn
5
Windowa 8 on new Hdd
DRIVER_IRQL_NOT_LESS_OR_EQUAL 0x000000d1 00000000`00000300
    Windows 8 Pro
    Intel Core 2 Extreme CPU QX 9650
    Asus P5QLD Pro
    8GB DDR2 Corrsair Dominator
    XFX 8800 GTS 512MB
    Samsung SyncMaster 245b
    1900x1200
    Seagate 2 TB
    Thermaltake Toughpower 1200W
    Gigabyte 3D Aurora
    Thermaltake Contac 39
    Razer Lachesis
usasma
Mr. Cranky Pants
5,139
There are reports missing from the uploaded information. Please rerun the data collection application and let it run for at least 15 minutes (or until it says it's done).
You have the 2005 version of ASACPI.sys (the Asus ATK0110 ACPI Utility driver). Please visit the Asus webpage for your motherboard/system and download the latest version (it's from 2009). Install it using the compatibilty mode for Win7. If unable to locate it, please post back with the exact make and model of your motherboard/system.
Daemon Tools (and Alcohol % software) are known to cause BSOD's on some Windows systems (mostly due to the sptd.sys driver, although I have seen dtsoftbus01.sys blamed on several occasions).
Please un-install the program, then use the following free tool to ensure that the troublesome sptd.sys driver is removed from your system (pick the 32 or 64 bit system depending on your system's configuration): [DEL] DuplexSecure - FAQ [/DEL] Link broken as of 21 Jul 2012
New link (15 Aug 2012): DuplexSecure - Downloads (pick the appropriate version for your system and select "Un-install" when you run it).
Alternate link: Disc-Tools.com
Manual procedure here: Registry and SPTD problems | DAEMON Pro Help
Your Lachesis.sys dates from 2007. This is a driver for a Razer device (mouse or keyboard). The older versions are known to cause BSOD's. Please update the drivers to the latest, Win8 compatible version. If unable to find a Win8 version, please stop using the device (and remove it's software) while we're testing.
l1e51x64.sys Wed Aug 5 01:49:43 2009 (4A791D77)
Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller
l1e51x64.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
L1E62x64.sys Thu Sep 22 02:26:32 2011 (4E7AD518)
Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller (NDIS6.20)
http://www.carrona.org/drivers/driver.php?id=L1E62x64.sys
Analysis:
[FONT=lucida console]**************************Sat Mar  9 12:41:32.128 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030913-20529-01.dmp]
Built by: [B]9200[/B].16496.amd64fre.win8_gdr.130108-1504
System Uptime:[B]0 days 0:36:12.794[/B]
*** ERROR: Module load completed but symbols could not be loaded for tcpip.sys
Probably caused by :[B]hardware ( tcpip+9bbc5 )[/B]
BugCheck [B]D1, {300, 2, 1, fffff88001aa4bc5}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x000000D1"]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/URL]
Arguments:
Arg1: 0000000000000300, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, value 0 = read operation, 1 = write operation
Arg4: fffff88001aa4bc5, address which referenced memory
BUGCHECK_STR:  AV
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]IP_MISALIGNED[/B]
CPUID:        "Intel(R) Core(TM)2 Extreme CPU X9650  @ 3.00GHz"
MaxSpeed:     3000
CurrentSpeed: [B]2997[/B]
  BIOS Version                  0601
  BIOS Release Date             09/15/2010
  Manufacturer                  System manufacturer
  Product Name                  System Product Name
**************************Sat Mar  9 12:04:45.505 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030913-47954-01.dmp]
System Uptime:[B]0 days 5:46:50.145[/B]
Probably caused by :[B]tcpip.sys ( tcpip+9bc41 )[/B]
BugCheck [B]D1, {fffff88063207549, 2, 1, fffff88001b02c41}[/B]
Arguments:
Arg1: fffff88063207549, memory referenced
Arg4: fffff88001b02c41, address which referenced memory
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]AV_tcpip+9bc41[/B]
MaxSpeed:     3000
  BIOS Version                  0601
**************************Sat Mar  9 00:51:33.512 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030813-48173-01.dmp]
System Uptime:[B]0 days 1:24:25.177[/B]
*** WARNING: Unable to verify timestamp for L1E62x64.sys
*** ERROR: Module load completed but symbols could not be loaded for L1E62x64.sys
Probably caused by :[B]L1E62x64.sys ( L1E62x64+691f )[/B]
BugCheck [B]D1, {190, 2, 0, fffff88001b5558f}[/B]
Arguments:
Arg1: 0000000000000190, memory referenced
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff88001b5558f, address which referenced memory
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]AV_L1E62x64+691f[/B]
MaxSpeed:     3000
  BIOS Version                  0601
**************************Fri Mar  8 23:26:34.717 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030813-20872-01.dmp]
System Uptime:[B]0 days 0:14:36.383[/B]
Probably caused by :[B]tunnel.sys ( tunnel!TeredoWfpIndicationWorker+70 )[/B]
BugCheck [B]D1, {2000, 2, 1, fffff88001b0adc0}[/B]
Arguments:
Arg1: 0000000000002000, memory referenced
Arg4: fffff88001b0adc0, address which referenced memory
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]AV_tunnel!TeredoWfpIndicationWorker[/B]
MaxSpeed:     3000
  BIOS Version                  0601
**************************Fri Mar  8 21:51:33.225 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030813-17581-01.dmp]
System Uptime:[B]0 days 0:34:15.891[/B]
Probably caused by :[B]hardware ( dxgmms1+8e57 )[/B]
BugCheck [B]D1, {ffffffffffffffe0, 2, 1, fffff88006070e57}[/B]
Arguments:
Arg1: ffffffffffffffe0, memory referenced
Arg4: fffff88006070e57, address which referenced memory
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]IP_MISALIGNED_dxgmms1.sys[/B]
MaxSpeed:     3000
  BIOS Version                  0601
**************************Fri Mar  8 21:16:43.036 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030813-24304-01.dmp]
System Uptime:[B]0 days 5:41:25.701[/B]
BugCheck [B]D1, {2, 2, 1, fffff88001b22fc1}[/B]
Arguments:
Arg1: 0000000000000002, memory referenced
Arg4: fffff88001b22fc1, address which referenced memory
BUGCHECK_STR:  AV
MaxSpeed:     3000
  BIOS Version                  0601
**************************Fri Mar  8 15:34:35.422 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030813-15381-01.dmp]
System Uptime:[B]0 days 4:54:04.062[/B]
Probably caused by :[B]hardware ( tcpip+9bbc1 )[/B]
BugCheck [B]D1, {300, 2, 1, fffff88001ad7bc1}[/B]
Arguments:
Arg4: fffff88001ad7bc1, address which referenced memory
BUGCHECK_STR:  AV
MaxSpeed:     3000
  BIOS Version                  0601
**************************Fri Mar  8 10:39:50.604 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030813-43945-01.dmp]
System Uptime:[B]0 days 0:40:10.269[/B]
Probably caused by :[B]tcpip.sys ( tcpip+bf615 )[/B]
BugCheck [B]139, {2, fffff8800ddbd1c0, fffff8800ddbd118, 0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x00000139"]KERNEL_SECURITY_CHECK_FAILURE (139)[/URL]
Arguments:
Arg1: 0000000000000002, Stack cookie instrumentation code detected a stack-based
    buffer overrun.
Arg2: fffff8800ddbd1c0, Address of the trap frame for the exception that caused the bugcheck
Arg3: fffff8800ddbd118, Address of the exception record for the exception that caused the bugcheck
Arg4: 0000000000000000, Reserved
BUGCHECK_STR:  0x139
PROCESS_NAME:  uTorrent.exe
FAILURE_BUCKET_ID: [B]0x139_2_tcpip+bf615[/B]
MaxSpeed:     3000
  BIOS Version                  0601
**************************Fri Mar  8 09:58:59.318 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030813-18454-01.dmp]
System Uptime:[B]0 days 1:04:15.984[/B]
Probably caused by :[B]tcpip.sys ( tcpip+8b5ee )[/B]
BugCheck [B]1E, {ffffffffc000001d, fffff88001b675ee, fffff8800bfe1638, fffff8800bfe0e70}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000001E"]KMODE_EXCEPTION_NOT_HANDLED (1e)[/URL]
Arguments:
Arg1: ffffffffc000001d, The exception code that was not handled
Arg2: fffff88001b675ee, The address that the exception occurred at
Arg3: fffff8800bfe1638, Parameter 0 of the exception
Arg4: fffff8800bfe0e70, Parameter 1 of the exception
BUGCHECK_STR:  0x1E_c000001d
FAILURE_BUCKET_ID: [B]0x1E_c000001d_BAD_IP_tcpip+8b5ee[/B]
MaxSpeed:     3000
  BIOS Version                  0601
**************************Fri Mar  8 08:54:09.858 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030813-32807-01.dmp]
System Uptime:[B]0 days 1:19:15.523[/B]
*** ERROR: Module load completed but symbols could not be loaded for nsiproxy.sys
Probably caused by :[B]nsiproxy.sys ( nsiproxy+1cbb )[/B]
BugCheck [B]50, {fffff87fa4bf1970, 0, fffff88005d99cbb, 2}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x00000050"]PAGE_FAULT_IN_NONPAGED_AREA (50)[/URL]
Arguments:
Arg1: fffff87fa4bf1970, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff88005d99cbb, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000002, (reserved)
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]AV_nsiproxy+1cbb[/B]
MaxSpeed:     3000
  BIOS Version                  0601
**************************Fri Mar  8 07:31:09.153 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030813-50559-01.dmp]
System Uptime:[B]0 days 9:03:07.817[/B]
*** ERROR: Module load completed but symbols could not be loaded for Ntfs.sys
Probably caused by :[B]Ntfs.sys ( Ntfs+e1cc0 )[/B]
BugCheck [B]24, {b50019060b, fffff880112b88f8, fffff880112b8130, fffff8800170dcc0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x00000024"]NTFS_FILE_SYSTEM (24)[/URL]
Arguments:
Arg1: 000000b50019060b
Arg2: fffff880112b88f8
Arg3: fffff880112b8130
Arg4: fffff8800170dcc0
PROCESS_NAME:  MsMpEng.exe
BUGCHECK_STR:  0x24
FAILURE_BUCKET_ID: [B]0x24_Ntfs+e1cc0[/B]
MaxSpeed:     3000
  BIOS Version                  0601
**************************Thu Mar  7 22:27:26.535 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030713-48017-01.dmp]
System Uptime:[B]0 days 1:09:23.199[/B]
Probably caused by :[B]fltmgr.sys ( fltmgr!FltpPerformPreCallbacks+39e )[/B]
BugCheck [B]3B, {c0000005, fffff880014528be, fffff8800c1b2eb0, 0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000003B"]SYSTEM_SERVICE_EXCEPTION (3b)[/URL]
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff880014528be, Address of the instruction which caused the bugcheck
Arg3: fffff8800c1b2eb0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
BUGCHECK_STR:  0x3B
FAILURE_BUCKET_ID: [B]0x3B_fltmgr!FltpPerformPreCallbacks[/B]
MaxSpeed:     3000
  BIOS Version                  0601
**************************Thu Mar  7 21:17:30.096 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030713-18829-01.dmp]
System Uptime:[B]0 days 0:40:02.761[/B]
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by :[B]nvlddmkm.sys ( nvlddmkm+14835a )[/B]
BugCheck [B]1000007E, {ffffffffc0000005, fffff8800763335a, fffff88006c6ddb8, fffff88006c6d5f0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x1000007E"]SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e)[/URL]
Arguments:
Arg1: ffffffffc0000005, The exception code that was not handled
Arg2: fffff8800763335a, The address that the exception occurred at
Arg3: fffff88006c6ddb8, Exception Record Address
Arg4: fffff88006c6d5f0, Context Record Address
BUGCHECK_STR:  AV
DEFAULT_BUCKET_ID:  NULL_DEREFERENCE
FAILURE_BUCKET_ID: [B]AV_nvlddmkm+14835a[/B]
MaxSpeed:     3000
  BIOS Version                  0601
**************************Thu Mar  7 20:36:53.111 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\030713-30607-01.dmp]
System Uptime:[B]0 days 1:11:14.775[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!SepMandatoryIntegrityCheck+1f1 )[/B]
BugCheck [B]3B, {c0000005, fffff80313edabc1, fffff880043dac80, 0}[/B]
Arguments:
Arg2: fffff80313edabc1, Address of the instruction which caused the bugcheck
Arg3: fffff880043dac80, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
PROCESS_NAME:  dwm.exe
FAILURE_BUCKET_ID: [B]0x3B_nt!SepMandatoryIntegrityCheck[/B]
MaxSpeed:     3000
  BIOS Version                  0601
[/FONT]
3rd Party Drivers:
[COLOR=RED][B]ASACPI.sys                  Sun Mar 27 22:30:36 2005 (42476C4C)[/B][/COLOR]
[COLOR=RED][B]Lachesis.sys                Fri Aug 17 03:48:44 2007 (46C552DC)[/B][/COLOR]
[COLOR=RED][B]l1e51x64.sys                Wed Aug  5 01:49:43 2009 (4A791D77)[/B][/COLOR]
[COLOR=RED][B]dtsoftbus01.sys             Fri Jan 13 08:45:46 2012 (4F10358A)[/B][/COLOR]
AsIO.sys                    Wed Aug 22 05:54:47 2012 (5034AC67)
AVerA706_x64.sys            Tue Aug 28 01:59:14 2012 (503C5E32)
RTKVHD64.sys                Tue Dec 18 08:15:57 2012 (50D06C8D)
nvlddmkm.sys                Sat Feb  9 18:13:08 2013 (5116D804)
[COLOR=RED][B]L1E62x64.sys                Thu Sep 22 02:26:32 2011 (4E7AD518)[/B][/COLOR]
AVerA706_x64.sys            Wed Jun 10 06:21:54 2009 (4A2F8942)
RTKVHD64.sys                Tue Jun 19 04:50:56 2012 (4FE03D70)
lvrs64.sys                  Mon Oct 22 22:11:24 2012 (5085FCCC)
intelppm.sys                Wed Jul 25 22:26:48 2012 (5010AAE8)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=ASACPI.sys
http://www.carrona.org/drivers/driver.php?id=Lachesis.sys
http://www.carrona.org/drivers/driver.php?id=dtsoftbus01.sys
http://www.carrona.org/drivers/driver.php?id=AsIO.sys
AVerA706_x64.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=lvrs64.sys
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
dartanqn
5
Updated the drivers. Rerun SF_Diagnostic_Tool.
    Windows 8 Pro
    Asus P5QLD Pro
    XFX 8800 GTS 512MB
    1900x1200
    Seagate 2 TB
    Gigabyte 3D Aurora
    Razer Lachesis
usasma
Mr. Cranky Pants
5,139
Your BIOS dates from 2010. Please check at the manufacturer's website to see if there are any BIOS updates available for your system. Also check the readme file to see if they apply to the problems that you are having. Please be advised that flashing the BIOS is a very unforgiving process - and one mistake can physically damage your motherboard.
F: drive only has about 5% free space. Windows likes 15% free space in order to perform stuff "behind the scenes" without adversely affecting the system's performance. Please free up 15% on ALL hard drives (you can get away with 10% on larger drives and won't notice a large performance penalty)
Here's the results from the March 21 memory dumps:
In addition to the steps below, please update this driver to the latest, Win8 compatible version:
L1E62x64.sys Sun Mar 28 22:08:44 2010 (4BB00BAC)
Looks like a hardware problem (2 out of 3 memory dumps blame hardware).
First update Razer Lachesis and remove Daemon Tools (as suggested previously).
Hardware causes can be:
- borked (broken) hardware (several different procedures used to isolate the problem device)
- BIOS issues (check for updates at the motherboard manufacturer's website)
- overclocking - You'll know if you're overclocking or not. If uncertain we can suggest things to check.
- compatibility issues (3rd party hardware/drivers) - Older Razer drivers
- low-level driver problems - Daemon Tools drivers
- or even malware (scanned for when we ask for hardware diagnostics from Initial Hardware Diagnostics or Hardware Diagnostics ).
If the BSOD's remain after removing them, then we start with hardware diagnostics: Hardware Diagnostics
Analysis:
[FONT=lucida console]**************************Thu Mar 21 20:12:01.719 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032113-48500-01.dmp]
System Uptime:[B]0 days 2:10:21.967[/B]
Probably caused by :[B]L1E62x64.sys ( L1E62x64+7844 )[/B]
BugCheck [B]D1, {fffffa806f80b50a, 2, 0, fffff88006f99844}[/B]
Arguments:
Arg1: fffffa806f80b50a, memory referenced
Arg4: fffff88006f99844, address which referenced memory
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]AV_L1E62x64+7844[/B]
MaxSpeed:     3000
  BIOS Version                  0601
**************************Thu Mar 21 07:46:33.493 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032113-45131-01.dmp]
System Uptime:[B]0 days 1:00:23.158[/B]
Probably caused by :[B]hardware ( tcpip+889d1 )[/B]
BugCheck [B]3B, {c000001d, fffff88001d399d1, fffff88004ffd760, 0}[/B]
Arguments:
Arg1: 00000000c000001d, Exception code that caused the bugcheck
Arg2: fffff88001d399d1, Address of the instruction which caused the bugcheck
Arg3: fffff88004ffd760, Address of the context record for the exception that caused the bugcheck
BUGCHECK_STR:  0x3B
PROCESS_NAME:  iexplore.exe
MaxSpeed:     3000
  BIOS Version                  0601
**************************Thu Mar 21 06:45:24.304 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\032113-47268-01.dmp]
System Uptime:[B]10 days 0:47:37.452[/B]
Probably caused by :[B]hardware ( nvlddmkm+adcf1 )[/B]
BugCheck [B]D1, {9c, 6, 1, fffff88006775cf1}[/B]
Arguments:
Arg1: 000000000000009c, memory referenced
Arg2: 0000000000000006, IRQL
Arg4: fffff88006775cf1, address which referenced memory
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]IP_MISALIGNED_nvlddmkm.sys[/B]
MaxSpeed:     3000
  BIOS Version                  0601
[/FONT]
3rd Party Drivers:
ASACPI.sys                  Wed May 13 21:25:17 2009 (4A0B72FD)
[COLOR=RED][B]L1E62x64.sys                Sun Mar 28 22:08:44 2010 (4BB00BAC)[/B][/COLOR]
[/FONT]
    Samsung/NP780
    800x600
