Driver_irql_not_less_or_equal
0080900
13
So this happened to me about 4 or 5 times today, screen flickered and BSOD after that.
This is what I got when checking BlueScreenView
DRIVER_IRQL_NOT_LESS_OR_EQUAL
If this is the first time you've seen this stop error screen,
restart your computer. If this screen appears again, follow
these steps:
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware or software manufacturer
for any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware
or software. Disable BIOS memory options such as caching or shadowing.
If you need to use safe mode to remove or disable components, restart
your computer, press F8 to select Advanced Startup Options, and then
select Safe Mode.
Technical Information:
*** STOP: 0x000000d1 (0x00200110, 0x00000006, 0x00000008, 0x00200110)
*** dxgmms1.sys - Address 0x8cd576cf base at 0x8cd51000 DateStamp 0x4fb71890
I have checked Event Viewer, but found nothing that relates to this error/crash at all.
I have attached my dump file.
I'm running 8 RP x86, I haven't purchased 8 retail yet, but I will next month, hence while I'm still on RP.
Any help is appreciated.
0080900
13
These files also appear to be culprits causing the BSOD.
dxgkrnl.sys
dxgmms1.sys
ntoskrnl.exe
HIDCLASS.SYS
Here's the HTML report of the files
