"driver state power failure"
1
I recently upgraded my system to windows 8 and I keep having error messages saying: "driver state power failure" and something to do with minidump files. Can anyone please help? I have attached my files:
mind you, I dont know very much about computers so go gentle please
    ASUS/UJ3CC
    Intel 5
    N.A
    4.0 Mb
    nVidia Gforce
usasma
Mr. Cranky Pants
5,139
MSINFO32 shows some STOP 0xA0 errors and some errors related to L1C63x64.sys (your networking drivers).
The first errors are suggestive of a possible hardware problem (most likely the hard drive). Please try these free diagnostics: Initial Hardware Diagnostics Please understand that this can also be a low-level driver problem, so post back if the tests don't find anything wrong.
The ATK64AMD.sys driver dates from 2006. It is the ATK0101 Hot Key driver (this is one of those low-level drivers that I mentioned earlier). Please uninstall the current version from your system and then install the latest, Win8 version from the system/mobo manufacturer's website.
ATK64AMD.sys Fri Oct 27 08:45:25 2006 (4541FF65)
ATK Hotkey ATK0101 ACPI UTILITY Driver
http://www.carrona.org/drivers/driver.php?id=ATK64AMD.sys
HECIx64.sys Thu Sep 17 15:54:16 2009 (4AB293E8)
Intel Management Engine Interface
NETwNs64.sys Thu Oct 6 10:45:03 2011 (4E8DBEEF)
Intel(R) Wireless WiFi Link 5000 Series Adapter Driver for Windows 7
http://www.carrona.org/drivers/driver.php?id=NETwNs64.sys
Analysis:
[font=lucida console]**************************Mon Dec 24 01:56:54.129 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\122412-18578-01.dmp]
Built by: [B]9200[/B].16461.amd64fre.win8_gdr.121119-1606
System Uptime:[B]0 days 4:27:00.789[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt!PopRequestRead+388 )[/B]
BugCheck [B]A0, {10a, a, fffffa8003b300d0, ffffffffc0000001}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x000000A0]INTERNAL_POWER_ERROR (a0)[/url]
Arguments:
Arg1: 000000000000010a, The disk subsystem failed to properly read or write part of the hibernation
    file.
Arg2: 000000000000000a
Arg3: fffffa8003b300d0, POP_HIBER_CONTEXT
Arg4: ffffffffc0000001, NTSTATUS failure code
BUGCHECK_STR:  0xA0
FAILURE_BUCKET_ID: [B]0xA0_nt!PopRequestRead[/B]
**************************Sun Dec 23 21:12:46.641 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\122312-20359-01.dmp]
System Uptime:[B]0 days 0:25:36.300[/B]
*** WARNING: Unable to verify timestamp for L1C63x64.sys
*** ERROR: Module load completed but symbols could not be loaded for L1C63x64.sys
Probably caused by :[B]L1C63x64.sys ( L1C63x64+cbfb )[/B]
BugCheck [B]50, {fffff88007befff8, 1, fffff88006db1bfb, 1}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000050]PAGE_FAULT_IN_NONPAGED_AREA (50)[/url]
Arguments:
Arg1: fffff88007befff8, memory referenced.
Arg2: 0000000000000001, value 0 = read operation, 1 = write operation.
Arg3: fffff88006db1bfb, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000001, (reserved)
BUGCHECK_STR:  AV
PROCESS_NAME: [B]System[/B]
FAILURE_BUCKET_ID: [B]AV_L1C63x64+cbfb[/B]
**************************Sun Dec 23 16:52:30.225 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\122312-56906-01.dmp]
System Uptime:[B]0 days 15:38:37.595[/B]
*** WARNING: Unable to verify timestamp for nvlddmkm.sys
*** ERROR: Module load completed but symbols could not be loaded for nvlddmkm.sys
Probably caused by :[B]pci.sys[/B]
BugCheck [B]9F, {3, fffffa800521a880, fffff8009d500b30, fffffa8007d5fd80}[/B]
Arguments:
Arg2: fffffa800521a880, Physical Device Object of the stack
Arg3: fffff8009d500b30, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa8007d5fd80, The blocked IRP
BUGCHECK_STR:  0x9F
FAILURE_BUCKET_ID: [B]0x9F_3_nvlddmkm_IMAGE_pci.sys[/B]
**************************Sat Dec 22 03:55:23.135 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\122212-19609-01.dmp]
Built by: [B]9200[/B].16384.amd64fre.win8_rtm.120725-1247
System Uptime:[B]0 days 7:14:47.355[/B]
BugCheck [B]A0, {10a, a, fffffa8006a06460, ffffffffc0000001}[/B]
Arguments:
    file.
Arg3: fffffa8006a06460, POP_HIBER_CONTEXT
BUGCHECK_STR:  0xA0
**************************Fri Dec 21 17:00:01.782 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\122112-40468-01.dmp]
System Uptime:[B]0 days 5:04:27.442[/B]
BugCheck [B]A0, {10a, a, fffffa8004c7be60, ffffffffc0000001}[/B]
Arguments:
    file.
Arg3: fffffa8004c7be60, POP_HIBER_CONTEXT
BUGCHECK_STR:  0xA0
**************************Thu Dec 20 18:27:33.310 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\122012-30125-01.dmp]
System Uptime:[B]0 days 1:55:35.970[/B]
BugCheck [B]50, {fffff88007bfdff8, 1, fffff88005f69bfb, 0}[/B]
Arguments:
Arg1: fffff88007bfdff8, memory referenced.
Arg3: fffff88005f69bfb, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000000, (reserved)
BUGCHECK_STR:  AV
**************************Thu Dec 20 16:10:26.102 2012 (UTC - 5:00)**************************
Loading Dump File [C:\Users\John\_jcgriff2_\dbug\__Kernel__\122012-55968-01.dmp]
System Uptime:[B]0 days 14:33:09.055[/B]
BugCheck [B]A0, {10a, a, fffffa80054d7520, ffffffffc0000001}[/B]
Arguments:
    file.
Arg3: fffffa80054d7520, POP_HIBER_CONTEXT
BUGCHECK_STR:  0xA0
[/font]
3rd Party Drivers:
[COLOR=RED][B]ATK64AMD.sys                Fri Oct 27 08:45:25 2006 (4541FF65)[/B][/COLOR]
[COLOR=RED][B]HECIx64.sys                 Thu Sep 17 15:54:16 2009 (4AB293E8)[/B][/COLOR]
[COLOR=RED][B]NETwNs64.sys                Thu Oct  6 10:45:03 2011 (4E8DBEEF)[/B][/COLOR]
L1C63x64.sys                Wed Feb 15 01:55:09 2012 (4F3B56CD)
GEARAspiWDM.sys             Thu May  3 15:56:17 2012 (4FA2E2E1)
kl1.sys                     Tue Jun 19 09:27:15 2012 (4FE07E33)
hiber_storport.sys          Wed Jul 25 22:29:58 2012 (5010ABA6)
dump_storahci.sys           Wed Jul 25 22:30:35 2012 (5010ABCB)
hiber_storahci.sys          Wed Jul 25 22:30:35 2012 (5010ABCB)
klim6.sys                   Thu Aug  2 07:08:40 2012 (501A5FB8)
klflt.sys                   Fri Aug  3 12:09:20 2012 (501BF7B0)
kneps.sys                   Mon Aug 13 08:45:42 2012 (5028F6F6)
klkbdflt.sys                Mon Sep  3 09:54:42 2012 (5044B6A2)
klmouflt.sys                Mon Sep  3 10:20:14 2012 (5044BC9E)
igdkmd64.sys                Fri Sep 14 19:09:01 2012 (5053B90D)
nvlddmkm.sys                Tue Oct  2 14:21:13 2012 (506B3099)
nvpciflt.sys                Tue Oct  2 14:21:40 2012 (506B30B4)
klwfp.sys                   Tue Oct 23 07:44:44 2012 (5086832C)
klif.sys                    Fri Nov  2 07:38:53 2012 (5093B0CD)
intelppm.sys                Wed Jul 25 22:26:48 2012 (5010AAE8)
klkbdflt.sys                Fri May 25 11:38:26 2012 (4FBFA772)
klmouflt.sys                Wed Jul 25 06:51:33 2012 (500FCFB5)
klwfp.sys                   Fri Aug  3 07:54:05 2012 (501BBBDD)
klif.sys                    Mon Aug 13 10:06:23 2012 (502909DF)
nvlddmkm.sys                Mon Jun 18 16:47:19 2012 (4FDF93D7)
[/font]
L1C63x64.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=GEARAspiWDM.sys
http://www.carrona.org/drivers/driver.php?id=kl1.sys
hiber_storport.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=dump_storahci.sys
http://www.carrona.org/drivers/driver.php?id=hiber_storahci.sys
http://www.carrona.org/drivers/driver.php?id=klim6.sys
http://www.carrona.org/drivers/driver.php?id=klflt.sys
http://www.carrona.org/drivers/driver.php?id=kneps.sys
http://www.carrona.org/drivers/driver.php?id=klkbdflt.sys
http://www.carrona.org/drivers/driver.php?id=klmouflt.sys
http://www.carrona.org/drivers/driver.php?id=igdkmd64.sys
http://www.carrona.org/drivers/driver.php?id=nvpciflt.sys
klwfp.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=klif.sys
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
