I just tried to restart my laptop and it took like really long to restart .. basically it was stuck at the "Restarting blue'ish screen" and after a while displayed some texts like "collecting info ....... Driver_Power_State_Failure"
After googleing a bit, it seems lots of people suggests its likely being caused by a damaged/outdated driver or something similar but I checked the device manager and I don't have any errors/yellow sigh anywhere and also tried checking updates for Ethernet/wifi adapters etc .. it just says I already have the latest version.
I've installed a few new softwares on pc recently but I'm don't think these can actually cause this issue, itunes latest version and a virtual wifi router: this one: https://virtualrouter.codeplex.com/ (don't know if I should link it here but incase it helps)
Also I don't think I've any virus issues, running comodo + maleware bytes ... so far no detection's.
Any advise how to fix it?
OS: Win 8.1 64bit
System config
Asus X555LF
Intel® Core™ i3 5010U Processor
DDR3L 1600 MHz SDRAM 8GB
NVIDIA® GeForce® 930M with 2GB DDR3 VRAM
1TB HDD
OS: Win 8.1 64bit
System config
Asus X555LF
1TB HDD
