Solved Driver power state failure - Windows 8 Pro 64-bit
Jack0171
Cake.
Hello,
I was just watching YouTube videos when I got a driver power state failure BSOD, my computer is set to never sleep (because I sometimes render videos over night)
I have attached my files from SF diagnostic tool.
Thanks a lot
-Jack
    Windows 8.1 Pro (64-Bit)
    Intel Core i7 4790K
    Asus Hero VII
    16GB DDR3 2133MHz
    Asus Strix GTX 980
    BenQ XL2720Z & HP 2311x
    128GB Samsung SM951 M.2
    256GB SanDisk UltraPlus
    2x 2TB WD Red
    Be Quiet L8 730w
    Fractal Design R5 Windowed
    2x 140mm intake + 1x 140mm exhaust
    Corsair K95 RGB (Cherry MX Red)
    Razer DeathAdder Chroma
    Chrome
    Panda Global Protection 2016
Jack0171
Cake.
*bump* :)
    Intel Core i7 4790K
    Asus Hero VII
    16GB DDR3 2133MHz
    Asus Strix GTX 980
    2x 2TB WD Red
    Be Quiet L8 730w
    Chrome
usasma
Mr. Cranky Pants
All the reports aren't in the uploaded info - Please re-run the data collection app and let it run for at least 15 minutes (or until the app itself says it's done).
This appears to be a power transition event and may be associated with a USB device. Please remove all USB devices to see if any of them are at fault (FYI - HP has started to put USB wireless cards in the back of some of their systems - and they're not obviously USB).
MSI Afterburner (along with Riva Tuner and EVGA Precision) are known to cause BSOD's in some Windows systems (it's driver is usually RTCore64.sys). Please un-install it immediately!
If you're overclocking, please stop the overclock while we're troubleshooting. Feel free to resume the overclock once the system has been stabilized.
AMD OverDrive (AODDriver2.sys) is either a stand-alone application, or a component of the AMD VISION Engine Control Center. This driver is known to cause BSOD's on some Windows systems.
Please un-install all AMD/ATI video stuff from Control Panel...Programs...Un-install a program
Then, download (but DO NOT install) a fresh copy of the ATI drivers from Global Provider of Innovative Graphics, Processors and Media Solutions | AMD (in the upper right corner of the page)
Use this procedure to install the DRIVER ONLY: ATI video cards - DRIVER ONLY installation procedure - Sysnative Forums
If the device (AODDriver or AODDriver4.01) remains a problem, open Device Manager, select the "View" item.
Then select "Show hidden devices" and scroll down to the Non-Plug and Play Drivers section.
Locate the AODDriver entry, right click on it and select "Un-install". Reboot for changes to take affect.
Sometimes the driver remains and continues to cause BSOD's. If this is the case for you, post back and we'll give further instructions for safely removing it.
If overclocking, please stop. Remove the overclock and return the system to stock/standard values while we're troubleshooting. Once the system is stable again, feel free to resume the overclocking.
usbfilter.sys Tue Dec 22 03:26:22 2009 (4B3082AE)
AMD USB Filter Driver (likely part of the chipset drivers)
http://www.carrona.org/drivers/driver.php?id=usbfilter.sys
AtiPcie64.sys Wed Mar 10 09:33:45 2010 (4B97ADC9)
AMD PCIE Filter Driver[br]Found in my ATI video drivers (I have an Intel chipset)
http://www.carrona.org/drivers/driver.php?id=AtiPcie64.sys
nbdrv.sys Fri May 14 07:47:10 2010 (4BED383E)
SeriousBit NetBalancer Internet traffic control and monitoring tool driver
http://www.carrona.org/drivers/driver.php?id=nbdrv.sys
hcwD3bda64.sys Tue Jun 29 09:26:05 2010 (4C29F46D)
Mirics FlexiTV Msi2500 Device Driver[br]
http://www.carrona.org/drivers/driver.php?id=hcwD3bda64.sys
VKbms.sys Thu Sep 30 12:16:33 2010 (4CA4B7E1)
HID mini driver for USB Fx2 Device (Razer driver)
http://www.carrona.org/drivers/driver.php?id=VKbms.sys
ALSysIO64.sys Sat Jul 9 20:27:45 2011 (4E18F201)
Core Temp - CPU temperature monitor
http://www.carrona.org/drivers/driver.php?id=ALSysIO64.sys
PxHlpa64.sys Mon Oct 17 10:29:34 2011 (4E9C3BCE)
Sonic CD/DVD driver (used by many different CD/DVD programs)
http://www.carrona.org/drivers/driver.php?id=PxHlpa64.sys
If all of this doesn't stop the BSOD's, please run Driver Verifier according to these instructions: Driver Verifier Settings
Analysis:
[font=lucida console]**************************Sun May  5 14:27:04.928 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\050513-44569-01.dmp]
Windows 8 Kernel Version 9200 MP (6 procs) Free x64
Built by: [B]9200[/B].16551.amd64fre.win8_gdr.130306-1502
System Uptime:[B]2 days 2:37:47.759[/B]
*** WARNING: Unable to verify timestamp for hcwD3bda64.sys
*** ERROR: Module load completed but symbols could not be loaded for hcwD3bda64.sys
Probably caused by :[B]usbhub.sys[/B]
BugCheck [B]9F, {3, fffffa8006dcf060, fffff80169f9f930, fffffa8009c3fb80}[/B]
Arguments:
Arg2: fffffa8006dcf060, Physical Device Object of the stack
Arg3: fffff80169f9f930, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa8009c3fb80, The blocked IRP
BUGCHECK_STR:  0x9F
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]0x9F_3_IMAGE_usbhub.sys[/B]
  BIOS Version                  6.10
  BIOS Release Date             09/07/2010
  Manufacturer                  Hewlett-Packard
  Product Name                  p6792uk
[/font]
3rd Party Drivers:
[COLOR=RED][B]usbfilter.sys             Tue Dec 22 03:26:22 2009 (4B3082AE)[/B][/COLOR]
[COLOR=RED][B]AtiPcie64.sys             Wed Mar 10 09:33:45 2010 (4B97ADC9)[/B][/COLOR]
[COLOR=RED][B]nbdrv.sys                 Fri May 14 07:47:10 2010 (4BED383E)[/B][/COLOR]
[COLOR=RED][B]hcwD3bda64.sys            Tue Jun 29 09:26:05 2010 (4C29F46D)[/B][/COLOR]
[COLOR=RED][B]VKbms.sys                 Thu Sep 30 12:16:33 2010 (4CA4B7E1)[/B][/COLOR]
[COLOR=RED][B]ALSysIO64.sys             Sat Jul  9 20:27:45 2011 (4E18F201)[/B][/COLOR]
[COLOR=RED][B]RTCore64.sys              Tue Sep  6 08:24:50 2011 (4E661112)[/B][/COLOR]
[COLOR=RED][B]PxHlpa64.sys              Mon Oct 17 10:29:34 2011 (4E9C3BCE)[/B][/COLOR]
SCDEmu.SYS                Thu Feb  9 00:59:50 2012 (4F3360D6)
[COLOR=RED][B]AODDriver2.sys            Thu Apr  5 05:23:37 2012 (4F7D6499)[/B][/COLOR]
cbfs3.sys                 Mon Apr  9 09:21:46 2012 (4F82E26A)
SYMEVENT64x86.SYS         Wed May 23 20:52:24 2012 (4FBD8648)
scmndisp.sys              Mon May 28 03:51:48 2012 (4FC32E94)
Rt630x64.sys              Tue Jun 12 09:37:53 2012 (4FD74631)
RTKVHD64.sys              Tue Jun 19 04:50:56 2012 (4FE03D70)
SYMNETS.SYS               Fri Jul 20 22:07:07 2012 (500A0ECB)
Ironx64.SYS               Mon Jul 23 20:34:50 2012 (500DEDAA)
EraserUtilRebootDrv.sys   Tue Jul 31 19:36:50 2012 (50186C12)
eeCtrl64.sys              Tue Jul 31 19:36:51 2012 (50186C13)
ccSetx64.sys              Thu Aug 16 17:18:11 2012 (502D6393)
IDSvia64.sys              Tue Aug 28 22:48:40 2012 (503D8308)
atikmpag.sys              Tue Sep 18 02:12:40 2012 (505810D8)
atikmdag.sys              Tue Sep 18 03:18:26 2012 (50582042)
amd_sata.sys              Fri Nov 30 04:00:42 2012 (50B875BA)
amd_xata.sys              Fri Nov 30 04:00:46 2012 (50B875BE)
AtihdW86.sys              Wed Dec 12 12:20:30 2012 (50C8BCDE)
EX64.SYS                  Thu Dec 20 04:22:39 2012 (50D2D8DF)
ENG64.SYS                 Thu Dec 20 04:24:21 2012 (50D2D945)
speedfan.sys              Sat Dec 29 15:59:35 2012 (50DF59B7)
SYMDS64.SYS               Wed Jan 16 20:56:45 2013 (50F75A5D)
SYMEFA64.SYS              Fri Jan 18 19:31:37 2013 (50F9E969)
SRTSP64.SYS               Fri Jan 25 16:26:16 2013 (5102F878)
SRTSPX64.SYS              Fri Jan 25 16:30:05 2013 (5102F95D)
netr28x.sys               Mon Feb 18 17:48:30 2013 (5122AFBE)
rzudd.sys                 Mon Mar  4 01:48:31 2013 (513443BF)
rzvkeyboard.sys           Mon Mar  4 01:48:38 2013 (513443C6)
RzFilter.sys              Tue Apr  9 14:23:47 2013 (51645CB3)
RzDxgk.sys                Tue Apr  9 14:23:50 2013 (51645CB6)
BHDrvx64.sys              Wed Apr 10 01:39:03 2013 (5164FAF7)
rzdaendpt.sys             Thu Apr 18 22:00:17 2013 (5170A531)
[/font]
http://www.carrona.org/drivers/driver.php?id=RTCore64.sys
http://www.carrona.org/drivers/driver.php?id=SCDEmu.SYS
http://www.carrona.org/drivers/driver.php?id=AODDriver2.sys
http://www.carrona.org/drivers/driver.php?id=cbfs3.sys
http://www.carrona.org/drivers/driver.php?id=SYMEVENT64x86.SYS
http://www.carrona.org/drivers/driver.php?id=scmndisp.sys
http://www.carrona.org/drivers/driver.php?id=SYMNETS.SYS
http://www.carrona.org/drivers/driver.php?id=Ironx64.SYS
http://www.carrona.org/drivers/driver.php?id=EraserUtilRebootDrv.sys
http://www.carrona.org/drivers/driver.php?id=eeCtrl64.sys
http://www.carrona.org/drivers/driver.php?id=ccSetx64.sys
http://www.carrona.org/drivers/driver.php?id=IDSvia64.sys
http://www.carrona.org/drivers/driver.php?id=amd_sata.sys
http://www.carrona.org/drivers/driver.php?id=amd_xata.sys
http://www.carrona.org/drivers/driver.php?id=AtihdW86.sys
http://www.carrona.org/drivers/driver.php?id=EX64.SYS
http://www.carrona.org/drivers/driver.php?id=ENG64.SYS
http://www.carrona.org/drivers/driver.php?id=speedfan.sys
http://www.carrona.org/drivers/driver.php?id=SYMDS64.SYS
http://www.carrona.org/drivers/driver.php?id=SYMEFA64.SYS
http://www.carrona.org/drivers/driver.php?id=SRTSP64.SYS
http://www.carrona.org/drivers/driver.php?id=SRTSPX64.SYS
http://www.carrona.org/drivers/driver.php?id=netr28x.sys
http://www.carrona.org/drivers/driver.php?id=rzudd.sys
http://www.carrona.org/drivers/driver.php?id=rzvkeyboard.sys
RzFilter.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
RzDxgk.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=BHDrvx64.sys
http://www.carrona.org/drivers/driver.php?id=rzdaendpt.sys
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
Jack0171
Cake.
Alright thanks a lot.
I have updated my graphics driver & uninstalled catalyst control centre, MSI Afterburner (which I used to control fan speed), NetBalancer, and SpeedFan (to change CPU fan speed)
I have also installed updates for all drivers, I just ran Prime95 for about thirty minutes on blend mode and there where no BSODs or crashes.
I'm going to make my thread as SOLVED, but if I have any more issues with this BSOD I will open the thread again and let you know.
Thanks again
Jack
    Intel Core i7 4790K
    Asus Hero VII
    16GB DDR3 2133MHz
    Asus Strix GTX 980
    2x 2TB WD Red
    Be Quiet L8 730w
    Chrome
