Driver Power State Failure on wake from sleep
Gotama
1
Hi,
I've been getting persistent BSOD's when attempting to wake up my computer (Lenovo Twist u230) from sleep. I am also sporadically getting Kernal Data Inpage Error BSOD while using my computer.
My machine is Windows 8, installed from factory with a recent refresh done. SFC /SCANNOW and DISM both come up clean. All of my hardware diagnostics are also clean.
Help!
    Windows 8 64 bit
usasma
Mr. Cranky Pants
5,139
Which hardware diagnostics have you done?
Please run Driver Verifier according to these instructions: Driver Verifier Settings
Just a guess at this point, but try removing Diskeeper to see if that helps.
If not that, then try removing the Citrix software to see if it helps.
Analysis:
[font=lucida console]**************************Fri Oct 11 09:56:37.534 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\101113-15578-01.dmp]
Built by: [B]9200[/B].16628.amd64fre.win8_gdr.130531-1504
System Uptime:[B]0 days 20:21:57.335[/B]
Probably caused by :[B]Unknown_Image ( ANALYSIS_INCONCLUSIVE )[/B]
BugCheck [B]9F, {3, fffffa80036b7890, fffff800c68d07f0, fffffa800de92610}[/B]
Arguments:
Arg2: fffffa80036b7890, Physical Device Object of the stack
Arg3: fffff800c68d07f0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa800de92610, The blocked IRP
BUGCHECK_STR:  0x9F
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]0x9F_3_ACPI_ANALYSIS_INCONCLUSIVE[/B]
CPUID:        "Intel(R) Core(TM) i5-3317U CPU @ 1.70GHz"
MaxSpeed:     1700
CurrentSpeed: [B]1696[/B]
  BIOS Version                  GDETA1WW (1.61 )
  BIOS Release Date             09/14/2013
  Manufacturer                  LENOVO
  Product Name                  33474HU
**************************Thu Oct 10 13:34:12.511 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\101013-15500-01.dmp]
System Uptime:[B]0 days 12:40:24.318[/B]
BugCheck [B]9F, {3, fffffa8003633cf0, fffff880014ab7f0, fffffa8003e13600}[/B]
Arguments:
Arg2: fffffa8003633cf0, Physical Device Object of the stack
Arg3: fffff880014ab7f0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa8003e13600, The blocked IRP
BUGCHECK_STR:  0x9F
MaxSpeed:     1700
  Manufacturer                  LENOVO
**************************Wed Oct  9 18:46:14.742 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\100913-12375-01.dmp]
System Uptime:[B]0 days 13:00:04.549[/B]
Probably caused by :[B]ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+24cc6 )[/B]
BugCheck [B]7A, {4, 0, fffffa800aff4010, 60b1f1088a}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x0000007A]KERNEL_DATA_INPAGE_ERROR (7a)[/url]
Arguments:
Arg1: 0000000000000004, lock type that was held (value 1,2,3, or PTE address)
Arg2: 0000000000000000, error status (normally i/o status code)
Arg3: fffffa800aff4010, current process (virtual address for lock type 3, or PTE)
Arg4: 00000060b1f1088a, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
BUGCHECK_STR:  0x7a_0
PROCESS_NAME:  svchost.exe
FAILURE_BUCKET_ID: [B]0x7a_0_nt!_??_::FNODOBFM::_string_[/B]
MaxSpeed:     1700
  Manufacturer                  LENOVO
**************************Tue Oct  8 19:05:57.013 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\100813-13078-01.dmp]
System Uptime:[B]0 days 4:44:24.821[/B]
BugCheck [B]7A, {4, 0, fffffa8004ce2c00, fd3d6f6028}[/B]
Arguments:
Arg3: fffffa8004ce2c00, current process (virtual address for lock type 3, or PTE)
Arg4: 000000fd3d6f6028, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
PROCESS_NAME:  MsMpEng.exe
MaxSpeed:     1700
  Manufacturer                  LENOVO
**************************Tue Oct  8 08:23:34.504 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\100813-15250-01.dmp]
System Uptime:[B]0 days 15:22:30.311[/B]
BugCheck [B]9F, {3, fffffa800368e060, fffff803ad2cf7f0, fffffa8004827010}[/B]
Arguments:
Arg2: fffffa800368e060, Physical Device Object of the stack
Arg3: fffff803ad2cf7f0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa8004827010, The blocked IRP
BUGCHECK_STR:  0x9F
MaxSpeed:     1700
  Manufacturer                  LENOVO
**************************Mon Oct  7 16:06:43.600 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\100713-11968-01.dmp]
System Uptime:[B]0 days 5:35:11.380[/B]
BugCheck [B]7A, {4, 0, fffffa800414b090, 7b42004}[/B]
Arguments:
Arg3: fffffa800414b090, current process (virtual address for lock type 3, or PTE)
Arg4: 0000000007b42004, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
PROCESS_NAME:  chrome.exe
MaxSpeed:     1700
  Manufacturer                  LENOVO
**************************Mon Oct  7 10:30:54.522 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\100713-14281-01.dmp]
System Uptime:[B]2 days 19:30:48.294[/B]
BugCheck [B]9F, {3, fffffa80036be740, fffff8004f91e7f0, fffffa8028f9de10}[/B]
Arguments:
Arg2: fffffa80036be740, Physical Device Object of the stack
Arg3: fffff8004f91e7f0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa8028f9de10, The blocked IRP
BUGCHECK_STR:  0x9F
MaxSpeed:     1700
  Manufacturer                  LENOVO
**************************Thu Oct  3 22:37:13.296 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\100313-13046-01.dmp]
System Uptime:[B]0 days 6:56:53.104[/B]
BugCheck [B]7A, {4, 0, fffffa800b97c520, 4d994cdda}[/B]
Arguments:
Arg3: fffffa800b97c520, current process (virtual address for lock type 3, or PTE)
Arg4: 00000004d994cdda, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
PROCESS_NAME:  dwm.exe
MaxSpeed:     1700
  Manufacturer                  LENOVO
**************************Thu Oct  3 13:45:32.128 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\100313-20453-01.dmp]
System Uptime:[B]0 days 3:01:11.938[/B]
*** ERROR: Module load completed but symbols could not be loaded for Ntfs.sys
Probably caused by :[B]Ntfs.sys ( Ntfs+e7679 )[/B]
BugCheck [B]24, {b50019060b, fffff880172e0908, fffff880172e0140, fffff88001bba679}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000024]NTFS_FILE_SYSTEM (24)[/url]
Arguments:
Arg1: 000000b50019060b
Arg2: fffff880172e0908
Arg3: fffff880172e0140
Arg4: fffff88001bba679
PROCESS_NAME:  TiWorker.exe
BUGCHECK_STR:  0x24
FAILURE_BUCKET_ID: [B]0x24_Ntfs+e7679[/B]
MaxSpeed:     1700
  Manufacturer                  LENOVO
**************************Thu Oct  3 10:43:54.506 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\100313-13250-01.dmp]
System Uptime:[B]0 days 10:43:19.313[/B]
BugCheck [B]9F, {3, fffffa8003633cf0, fffff880012ab7f0, fffffa8003754670}[/B]
Arguments:
Arg3: fffff880012ab7f0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa8003754670, The blocked IRP
BUGCHECK_STR:  0x9F
MaxSpeed:     1700
  Manufacturer                  LENOVO
**************************Wed Oct  2 10:53:01.027 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\100213-21359-01.dmp]
System Uptime:[B]0 days 8:18:30.834[/B]
BugCheck [B]7A, {4, 0, fffffa8009ec2ce0, fad73d8dc8}[/B]
Arguments:
Arg3: fffffa8009ec2ce0, current process (virtual address for lock type 3, or PTE)
Arg4: 000000fad73d8dc8, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
PROCESS_NAME:  services.exe
MaxSpeed:     1700
  Manufacturer                  LENOVO
**************************Wed Oct  2 02:33:46.448 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\100213-12390-01.dmp]
System Uptime:[B]0 days 10:16:19.257[/B]
BugCheck [B]7A, {4, 0, fffffa8004c0d490, fffff6800000b000}[/B]
Arguments:
Arg3: fffffa8004c0d490, current process (virtual address for lock type 3, or PTE)
Arg4: fffff6800000b000, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
PROCESS_NAME:  GoogleCrashHan
MaxSpeed:     1700
  Manufacturer                  LENOVO
**************************Tue Oct  1 04:32:15.045 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\100113-15031-01.dmp]
System Uptime:[B]0 days 17:32:11.845[/B]
Probably caused by :[B]memory_corruption ( nt!MiDispatchFault+120 )[/B]
BugCheck [B]50, {fffff690219037b0, 0, fffff800c9aa8fe0, 2}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000050]PAGE_FAULT_IN_NONPAGED_AREA (50)[/url]
Arguments:
Arg1: fffff690219037b0, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff800c9aa8fe0, If non-zero, the instruction address which referenced the bad memory
    address.
Arg4: 0000000000000002, (reserved)
BUGCHECK_STR:  AV
PROCESS_NAME:  msiexec.exe
FAILURE_BUCKET_ID: [B]AV_nt!MiDispatchFault[/B]
MaxSpeed:     1700
  Manufacturer                  LENOVO
**************************Mon Sep 30 10:59:38.537 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\093013-10906-01.dmp]
System Uptime:[B]0 days 14:05:40.339[/B]
BugCheck [B]9F, {3, fffffa80036b7890, fffff880009f17f0, fffffa800c022010}[/B]
Arguments:
Arg3: fffff880009f17f0, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa800c022010, The blocked IRP
BUGCHECK_STR:  0x9F
MaxSpeed:     1700
  Manufacturer                  LENOVO
**************************Fri Sep 27 22:50:47.939 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\092713-16265-01.dmp]
System Uptime:[B]2 days 4:19:04.739[/B]
BugCheck [B]7A, {4, 0, fffffa8039b542e0, fffff88018ebc000}[/B]
Arguments:
Arg3: fffffa8039b542e0, current process (virtual address for lock type 3, or PTE)
Arg4: fffff88018ebc000, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
MaxSpeed:     1700
  Manufacturer                  LENOVO
**************************Wed Sep 25 18:30:37.386 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\092513-14734-01.dmp]
System Uptime:[B]0 days 5:04:38.188[/B]
BugCheck [B]7A, {4, 0, fffffa80040c2c80, cef3a9ef70}[/B]
Arguments:
Arg3: fffffa80040c2c80, current process (virtual address for lock type 3, or PTE)
Arg4: 000000cef3a9ef70, virtual address that could not be in-paged (or PTE contents if arg1 is a PTE address)
MaxSpeed:     1700
  Manufacturer                  LENOVO
**************************Wed Sep 25 13:25:19.527 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\092513-26140-01.dmp]
System Uptime:[B]0 days 18:10:29.324[/B]
BugCheck [B]9F, {3, fffffa800369f4d0, fffff880009f17f0, fffffa80269a8810}[/B]
Arguments:
Arg2: fffffa800369f4d0, Physical Device Object of the stack
Arg4: fffffa80269a8810, The blocked IRP
BUGCHECK_STR:  0x9F
MaxSpeed:     1700
  Manufacturer                  LENOVO
[/font]
3rd Party Drivers:
excsd.sys                   Fri Mar 30 15:52:41 2012 (4F760F09)
excfs.sys                   Fri Mar 30 15:53:05 2012 (4F760F21)
Rt630x64.sys                Tue Jun 12 09:37:53 2012 (4FD74631)
IntcDAud.sys                Tue Jun 19 10:40:51 2012 (4FE08F73)
dump_iaStorA.sys            Mon Jul  9 16:42:33 2012 (4FFB4239)
Apsx64.sys                  Sat Jul 21 03:30:07 2012 (500A5A7F)
btwl2cap.sys                Thu Jul 26 11:14:41 2012 (50115EE1)
RtsP2Stor.sys               Wed Aug  8 05:55:36 2012 (50223798)
ApsHM64.sys                 Fri Aug 10 22:24:57 2012 (5025C279)
Smb_driver_Intel.sys        Fri Aug 24 19:22:13 2012 (50380CA5)
RTKVHD64.sys                Tue Sep 11 09:57:45 2012 (504F4359)
bcmwl63a.sys                Wed Oct 24 22:37:27 2012 (5088A5E7)
ctxusbm.sys                 Fri Nov 30 11:09:56 2012 (50B8DA54)
HECIx64.sys                 Mon Dec 17 14:32:21 2012 (50CF7345)
btwpanfl.sys                Mon Dec 31 16:42:33 2012 (50E206C9)
btwavdt.sys                 Fri Mar  8 18:23:34 2013 (513A72F6)
btwaudio.sys                Fri Mar  8 18:24:25 2013 (513A7329)
btwrchid.sys                Fri Mar  8 18:24:34 2013 (513A7332)
SPUVCbv_x64.sys             Fri Mar 15 04:58:15 2013 (5142E2A7)
Tppwr64v.sys                Wed Apr 17 08:14:17 2013 (516E9219)
SynTP.sys                   Wed Apr 17 23:55:17 2013 (516F6EA5)
igdkmd64.sys                Mon May 20 13:19:47 2013 (519A5B33)
bcbtums.sys                 Wed Aug  7 11:11:22 2013 (5202639A)
ibmpmdrv.sys                Tue Aug 27 04:20:26 2013 (521C614A)
btwampfl.sys                Fri Aug 30 14:32:26 2013 (5220E53A)
btwampfl.sys                Thu Feb 21 16:30:13 2013 (512691E5)
bcbtums.sys                 Mon Mar 25 20:41:02 2013 (5150EE9E)
[/font]
http://www.carrona.org/drivers/driver.php?id=excsd.sys
http://www.carrona.org/drivers/driver.php?id=excfs.sys
http://www.carrona.org/drivers/driver.php?id=IntcDAud.sys
http://www.carrona.org/drivers/driver.php?id=Apsx64.sys
http://www.carrona.org/drivers/driver.php?id=btwl2cap.sys
http://www.carrona.org/drivers/driver.php?id=RtsP2Stor.sys
http://www.carrona.org/drivers/driver.php?id=ApsHM64.sys
http://www.carrona.org/drivers/driver.php?id=Smb_driver_Intel.sys
http://www.carrona.org/drivers/driver.php?id=bcmwl63a.sys
http://www.carrona.org/drivers/driver.php?id=ctxusbm.sys
btwpanfl.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=btwavdt.sys
http://www.carrona.org/drivers/driver.php?id=btwaudio.sys
http://www.carrona.org/drivers/driver.php?id=btwrchid.sys
http://www.carrona.org/drivers/driver.php?id=SPUVCbv_x64.sys
http://www.carrona.org/drivers/driver.php?id=Tppwr64v.sys
http://www.carrona.org/drivers/driver.php?id=SynTP.sys
http://www.carrona.org/drivers/driver.php?id=igdkmd64.sys
http://www.carrona.org/drivers/driver.php?id=bcbtums.sys
http://www.carrona.org/drivers/driver.php?id=ibmpmdrv.sys
http://www.carrona.org/drivers/driver.php?id=btwampfl.sys
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
