Driver power state failure - Kernel event 41
chimcuttho
Hello everyone , I recently install Win8 Pro and my laptop has been crashing when I shutdown. It restarts and I got the BSOD Driver_power_state_failure ! I reinstall OS three times but useless :(. I hope you guys solve this problem.
Thank you in advance !
usasma
Mr. Cranky Pants
Your BIOS dates from 2010. Please check at the manufacturer's website to see if there are any BIOS updates available for your system. Also check the readme file to see if they apply to the problems that you are having. Please be advised that flashing the BIOS is a very unforgiving process - and one mistake can physically damage your motherboard.
D: drive only has about 5% free space. Windows likes 15% free space in order to perform stuff "behind the scenes" without adversely affecting the system's performance. Please free up 15% on all hard drives (you can get away with 10% on larger drives and won't notice a large performance penalty)
Please install the drivers for this device:
Not Available ACPI\SMO8800\1 The drivers for this device are not installed.
This is most likely the Dell Free Fall sensor - a shock sensing device for the hard drive.
The memory dumps blame your wireless networking drivers. Please:
- download a fresh set of the wireless drivers
- uninstall the current wireless drivers
- install the freshly downloaded drivers
- monitor for further BSOD's
Since this is a networking error, there are other possibilities as to what's causing the problem.
If the BSOD's continue after updating the wireless drivers, then try this:
Anti-Virus Removal:
Please do the following:
- download a free anti-virus for testing purposes: Free AntiVirus If using Windows 8, enable Windows Defender and the Windows Firewall instead.
- un-install the Norton from your system (you can reinstall it, if so desired, when we're done troubleshooting)
- remove any remnants of Norton using this free tool: http://us.norton.com/support/kb/web_view.jsp?wv_type=public_web&docurl=20080710133834EN
- IMMEDIATELY install and update the free anti-virus (if using Win8, enable Windows Defender), then check to ensure that the Windows Firewall is turned on.
- perform a full system scan to ensure that no malware has snuck onto your system while the anti-virus was malfunctioning.
- check to see if this fixes the BSOD's
NOTE: NEVER run more than 1 anti-virus, firewall, Internet Security/Security Center application at the same time.
Also try removing Connectify.
k57nd60a.sys Thu Aug 6 07:44:32 2009 (4A7AC220)
Broadcom NetLink Gigabit Ethernet NDIS6.x Unified Driver
http://www.carrona.org/drivers/driver.php?id=k57nd60a.sys
RTKVHD64.sys Mon Aug 31 06:19:33 2009 (4A9BA3B5)
Realtek High Definition Audio Function Driver
HECIx64.sys Thu Sep 17 15:54:16 2009 (4AB293E8)
Intel Management Engine Interface
cnnctfy2.sys Fri Jun 24 11:29:01 2011 (4E04AD3D)
Connectify NDIS Driver
http://www.carrona.org/drivers/driver.php?id=cnnctfy2.sys
SRTSPX64.SYS Tue Nov 15 17:30:55 2011 (4EC2E81F)
Symantec Real Time Storage Protection (PEL) x64
http://www.carrona.org/drivers/driver.php?id=SRTSPX64.SYS
Analysis:
[font=lucida console]**************************Sat Feb  9 18:12:35.520 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\020913-41531-01.dmp]
Built by: [B]9200[/B].16461.amd64fre.win8_gdr.121119-1606
System Uptime:[B]0 days 4:05:47.224[/B]
Probably caused by :[B]pci.sys[/B]
BugCheck [B]9F, {4, 12c, fffffa8007bf4b00, fffff80121cba940}[/B]
Arguments:
Arg1: 0000000000000004, The power transition timed out waiting to synchronize with the Pnp
    subsystem.
Arg2: 000000000000012c, Timeout in seconds.
Arg3: fffffa8007bf4b00, The thread currently holding on to the Pnp lock.
Arg4: fffff80121cba940, nt!TRIAGE_9F_PNP on Win7
BUGCHECK_STR:  0x9F
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]0x9F_4_bcmwl63a_IMAGE_pci.sys[/B]
CPUID:        "Intel(R) Core(TM) i3 CPU       M 330  @ 2.13GHz"
MaxSpeed:     2130
CurrentSpeed: [B]2128[/B]
  BIOS Version                  A06
  BIOS Release Date             07/27/2010
  Manufacturer                  Dell Inc.
  Product Name                  Studio 1458
**************************Sat Feb  9 13:37:57.443 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\020913-32359-01.dmp]
System Uptime:[B]0 days 7:59:09.564[/B]
BugCheck [B]9F, {4, 12c, fffffa80052a0a00, fffff80140dfa940}[/B]
Arguments:
    subsystem.
Arg3: fffffa80052a0a00, The thread currently holding on to the Pnp lock.
Arg4: fffff80140dfa940, nt!TRIAGE_9F_PNP on Win7
BUGCHECK_STR:  0x9F
MaxSpeed:     2130
  BIOS Version                  A06
[/font]
3rd Party Drivers:
[COLOR=RED][B]k57nd60a.sys                Thu Aug  6 07:44:32 2009 (4A7AC220)[/B][/COLOR]
[COLOR=RED][B]RTKVHD64.sys                Mon Aug 31 06:19:33 2009 (4A9BA3B5)[/B][/COLOR]
[COLOR=RED][B]HECIx64.sys                 Thu Sep 17 15:54:16 2009 (4AB293E8)[/B][/COLOR]
[COLOR=RED][B]cnnctfy2.sys                Fri Jun 24 11:29:01 2011 (4E04AD3D)[/B][/COLOR]
[COLOR=RED][B]SRTSPX64.SYS                Tue Nov 15 17:30:55 2011 (4EC2E81F)[/B][/COLOR]
bcmwl63a.sys                Tue Mar 13 20:31:05 2012 (4F5FE6C9)
SYMEVENT64x86.SYS           Wed May 23 20:52:24 2012 (4FBD8648)
atikmpag.sys                Mon Jun 18 16:41:29 2012 (4FDF9279)
atikmdag.sys                Mon Jun 18 17:21:01 2012 (4FDF9BBD)
SYMNETS.SYS                 Fri Jul 20 22:07:07 2012 (500A0ECB)
Ironx64.SYS                 Mon Jul 23 20:34:50 2012 (500DEDAA)
dump_storahci.sys           Wed Jul 25 22:30:35 2012 (5010ABCB)
btwl2cap.sys                Thu Jul 26 11:14:41 2012 (50115EE1)
EraserUtilRebootDrv.sys     Tue Jul 31 19:36:50 2012 (50186C12)
eeCtrl64.sys                Tue Jul 31 19:36:51 2012 (50186C13)
ccSetx64.sys                Thu Aug 16 17:18:11 2012 (502D6393)
IDSvia64.sys                Tue Aug 28 22:48:40 2012 (503D8308)
bcbtums.sys                 Tue Sep 25 12:09:37 2012 (5061D741)
SRTSP64.SYS                 Tue Oct  2 18:55:54 2012 (506B70FA)
SYMDS64.SYS                 Tue Oct  2 22:52:00 2012 (506BA850)
SYMEFA64.SYS                Wed Oct  3 15:00:06 2012 (506C8B36)
btwampfl.sys                Fri Oct  5 20:49:51 2012 (506F802F)
btwavdt.sys                 Mon Oct 29 19:17:28 2012 (508F0E88)
btwrchid.sys                Mon Oct 29 19:22:51 2012 (508F0FCB)
btwaudio.sys                Wed Nov  7 18:58:13 2012 (509AF595)
idmwfp.sys                  Wed Nov 21 09:42:58 2012 (50ACE872)
EX64.SYS                    Thu Dec 20 04:22:39 2012 (50D2D8DF)
ENG64.SYS                   Thu Dec 20 04:24:21 2012 (50D2D945)
BHDrvx64.sys                Fri Jan 11 13:50:17 2013 (50F05EE9)
[/font]
http://www.carrona.org/drivers/driver.php?id=bcmwl63a.sys
http://www.carrona.org/drivers/driver.php?id=SYMEVENT64x86.SYS
http://www.carrona.org/drivers/driver.php?id=SYMNETS.SYS
http://www.carrona.org/drivers/driver.php?id=Ironx64.SYS
http://www.carrona.org/drivers/driver.php?id=dump_storahci.sys
http://www.carrona.org/drivers/driver.php?id=btwl2cap.sys
http://www.carrona.org/drivers/driver.php?id=EraserUtilRebootDrv.sys
http://www.carrona.org/drivers/driver.php?id=eeCtrl64.sys
http://www.carrona.org/drivers/driver.php?id=ccSetx64.sys
http://www.carrona.org/drivers/driver.php?id=IDSvia64.sys
http://www.carrona.org/drivers/driver.php?id=bcbtums.sys
http://www.carrona.org/drivers/driver.php?id=SRTSP64.SYS
http://www.carrona.org/drivers/driver.php?id=SYMDS64.SYS
http://www.carrona.org/drivers/driver.php?id=SYMEFA64.SYS
http://www.carrona.org/drivers/driver.php?id=btwampfl.sys
http://www.carrona.org/drivers/driver.php?id=btwavdt.sys
http://www.carrona.org/drivers/driver.php?id=btwrchid.sys
http://www.carrona.org/drivers/driver.php?id=btwaudio.sys
http://www.carrona.org/drivers/driver.php?id=idmwfp.sys
http://www.carrona.org/drivers/driver.php?id=EX64.SYS
http://www.carrona.org/drivers/driver.php?id=ENG64.SYS
http://www.carrona.org/drivers/driver.php?id=BHDrvx64.sys
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
chimcuttho
Wow, thank for quick reply @usasma , I just install wireless driver from dell support instead of using default driver and everything seem ok , I'll watch it a few more days for sure. But thank you very much ^^
