Solved Driver power state failure BSOD
jag213
6
Hello,
I have been getting a Driver power state failure bsod for about a week now. Some days it doesn't seem to occur that much while other its several times an hour. From googling it seems like the issue is either an out of date driver or my ram. I"ve run "whocrashed" and "bluescreenview" which point to
This was probably caused by the following module: [FONT=Segoe UI, Arial]ntoskrnl.exe[/FONT] (nt+0x14F9A0)
Bugcheck code: 0x9F (0x3, 0xFFFFE00101519060, 0xFFFFD0018AB69960, 0xFFFFE00106234C10)
but I guess this isn't the actual driver (or ram) causing the issue. Any help would be appreciated.
Thanks,
    Intel i5-i2500k
    ASRock Z68 Extreme3 Gen3
    16.00 GB
    (1) AMD Radeon HD 6900 Series (2) Intel(R) HD Graphics 3000
    (1) High Definition Audio Device (2) AMD High Definition Audio Device
    ST2000DL003-9VT166 ATA Device
axe0
BSOD Kernel Dump Analyst
2,431
Hi jag213,
Welcome to the 8forums.
Please do the following:
Open an admin command prompt
Copy/paste "sfc/scannow" (without quotes) and press enter
When it finished reboot your system
Open again an admin command prompt
Enter sfc/scannow again
If sfc/scannow doesn't say "Windows Resource Protection did not find any integrity violation", please upload the cbs.log file located at {windows partition}\Windows\Logs\CBS\, if the file is too large try a 3rd party uploader like dropbox, onedrive, google drive, mediafire etc.
System File Check(SFC a.k.a. Windows Resource Protection) needs to have your system rebooted in order for sfc to try to fix the problems that it finds.
Please fill in your system specs
Please go to this site and download the tool. The tool will give you detailed information about your system specs, please fill in your system specs more completely.​
How to fill in your system specs:
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Gigabyte B150-HD3P-CF
    16GB DDR4 2133 Crucial Ballistix Sport LT
    MSI GeForce GTX 1060 GAMING X 6G
    Built-in
    Liyama ProLite XB2483HSU-B2
    Crucial MX200 500GB & Toshiba DT01ACA300 3TB
    Corsair RM550x
    Fractal Design Define S
    Cooler Master TX3 i
    Func KB-460 (MX Red)
    Corsair Gaming M65 RGB
    Bitdefender Total Security 2017 + MBAM Pro + MBAE Pro
    Creative Sound Blaster Tactic3D Rage V2 headset
jag213
6
    Intel i5-i2500k
    16.00 GB
axe0
2,431
Please try sfc, reboot, sfc a few times.
It takes usually 4-5 times for sfc to solve it.
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Built-in
    Corsair RM550x
    Cooler Master TX3 i
jag213
6
I have run the test 7 times now and keep getting "found corrupt files but was unable to fix some of them".
    Intel i5-i2500k
    16.00 GB
axe0
2,431
Please upload the cbs.log file, if the file is too large try a 3rd party uploader like dropbox, onedrive, google drive etc.
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Built-in
    Corsair RM550x
    Cooler Master TX3 i
jag213
6
    Intel i5-i2500k
    16.00 GB
axe0
2,431
#8
Keep us posted.
Try in admin command prompt
"DISM /Online /Cleanup-Image /RestoreHealth" (without quotes)
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Built-in
    Corsair RM550x
    Cooler Master TX3 i
jag213
6
#9
Put that command in and also put the two sticks of ram back in. Maybe they were loose or dusty, i don't know but haven't bsod today. Hopefully the problem is solved.
    Intel i5-i2500k
    16.00 GB
jag213
6
#10
Haven't BSOD in a couple days so I am going to mark this one as solved. Thanks for your help.
    Intel i5-i2500k
    16.00 GB
axe0
2,431
#11
You're welcome :)
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Built-in
    Corsair RM550x
    Cooler Master TX3 i
