Solved driver power state failure BSOD
weishou
6
Hi,
I'm using a Asus UX32ln.
I've been having getting this BSOD for a while. However, I noticed that it only occurs some time (maybe 15-30mins) after i run an application using the dedicated GPU (Nvidia Geforce 840m). If only the integrated graphic card is used, it runs fine.
Thanks.
    Win 8.1
axe0
BSOD Kernel Dump Analyst
2,409
Hi weishou,
Welcome to the 8forums.
Unfortunately your attached zip file is empty.
Please try to upload the zip file again.
Please check the minidump folder for dump files: {windows partition}\Windows\Minidump.
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Gigabyte B150-HD3P-CF
    16GB DDR4 2133 Crucial Ballistix Sport LT
    MSI GeForce GTX 1060 GAMING X 6G
    Built-in
    Liyama ProLite XB2483HSU-B2
    Crucial MX200 500GB & Toshiba DT01ACA300 3TB
    Corsair RM550x
    Fractal Design Define S
    Cooler Master TX3 i
    Func KB-460 (MX Red)
    Corsair Gaming M65 RGB
    Bitdefender Total Security 2017 + MBAM Pro + MBAE Pro
    Creative Sound Blaster Tactic3D Rage V2 headset
weishou
6
Hmmm... I've tried the DM log collector tool a few more times after posting but it's always empty.
I've attache the most recent .dmp file. Would that work? Thanks!
    Win 8.1
axe0
2,409
In most cases yes, but I prefer the other files with it.
This to check some standard things.
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Built-in
    Corsair RM550x
    Cooler Master TX3 i
axe0
2,409
Please try the BSOD Inspector
I know the cause, but I would like to check a few things in those files.
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Built-in
    Corsair RM550x
    Cooler Master TX3 i
axe0
2,409
Thank you.
The cause is the Intel Wifi Adapter.
If you have a laptop, go to your manufacturers site and check for driver updates
If you have a desktop, visit Intel and update the driver.
0: kd> lmvm NETwbw02start             end                 module name
fffff800`b9880000 fffff800`b9c0b000   NETwbw02 T (no symbols)
    Loaded symbol image file: NETwbw02.sys
    Image path: \SystemRoot\system32\DRIVERS\NETwbw02.sys
    Image name: [U]NETwbw02.sys[/U]
    Timestamp:        [COLOR=#ff0000][U]Wed Dec 25 15:05:47 2013[/U][/COLOR] (52BAE63B)
    CheckSum:         00374200
    ImageSize:        0038B000
    Translations:     0000.04b0 0000.04e4 0409.04b0 0409.04e4
I wanted to check if you had any program installed that could cause BSOD's, like Daemon tools.
If you did, then I would have recommended to uninstall them.
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Built-in
    Corsair RM550x
    Cooler Master TX3 i
axe0
2,409
#9
You're welcome :)
Let me know if the problem still persist after updating :)
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Built-in
    Corsair RM550x
    Cooler Master TX3 i
axe0
2,409
#11
Diagnostic Test
DRIVER VERIFIER
Please make a backup of your important files and get your rescue media or create one.
Please create a restore point.
Please read and run driver verifier.
Some windows drivers are blamed in a crash, but that usually means that a 3rd party driver is actually the cause.
Driver verifier stresses your drivers and will crash your pc if any driver fails due to a violation.
Driver verifier should be performed for a max of 48 hours, or when you have a bluescreen, whatever comes first.
If driver verifier has found a violation and you can't get back into windows normally, try to boot into safe mode and reset in safe mode driver verifier, or in the troubleshooting options open command prompt and type verifier /reset.
Your system will act very sluggishly while driver verifier is enabled, this is normal as your drivers will be being subjected to heavy testing in order to make them crash.
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Built-in
    Corsair RM550x
    Cooler Master TX3 i
axe0
2,409
#12
I also see another driver causing trouble
Nvidia Video driver, if you have a desktop, please visit the Nvidia site for driver updates
If you have a laptop, check your manufacturer for driver updates
0: kd> lmvm nvlddmkmstart             end                 module name
fffff801`e500d000 fffff801`e5c9b000   nvlddmkm T (no symbols)
    Loaded symbol image file: nvlddmkm.sys
    Image path: \SystemRoot\system32\DRIVERS\nvlddmkm.sys
    Image name: [U]nvlddmkm.sys[/U]
    Timestamp:        [COLOR=#ff0000][U]Wed Jul 02 19:42:02 2014[/U][/COLOR] (53B4446A)
    CheckSum:         00C4C7C9
    ImageSize:        00C8E000
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Built-in
    Corsair RM550x
    Cooler Master TX3 i
axe0
2,409
#14
You're most welcome :)
    Windows 10 Pro
    Custom build
    i5-6500 @3.20GHz
    Built-in
    Corsair RM550x
    Cooler Master TX3 i
