Driver power state failure (BSOD)
Kazam
New York
14
Hello,
I made a thread about this already but no one would reply can someone help me please? I really want to get rid of this BSOD :cry:
I want to know what the problem is, thanks
http://sdrv.ms/14ltYEj
edit: windows 8
    AMD FX 8350
    Asus M5 A97 R2.0
    Crucial Ballistix Sport 16GB
    EVGA GEFORCE GTX 650 Ti
    ASUS VS228H-P 22-Inch
    WD 500GB
    Corsair CX600M
    NXZT Source 210 Classic Midtower Chassis
    3 x 120mm fans
    wireless keyboard
    Perrixx MX-3000
    8.50 Mbps Wireless :'(
    Google Crome
    none
    I'm planing on upgrading my gpu and psu soon!
usasma
Mr. Cranky Pants
5,139
I'm late for work, please post back in order to remind me to follow up on this topic (I get email notification when you reply)>
Make sure that you have ALL available Windows Updates
While waiting, start with these free diagnostics: Initial Hardware Diagnostics
Analysis:
[FONT=lucida console]**************************Thu Aug  1 14:52:25.525 2013 (UTC - 4:00)**************************
Loading Dump File [C:\Users\John\SysnativeBSODApps\080113-27580-01.dmp]
Windows 8 Kernel Version 9200 MP (8 procs) Free x64
Built by: [B]9200[/B].16628.amd64fre.win8_gdr.130531-1504
System Uptime:[B]0 days 4:29:58.649[/B]
*** ERROR: Module load completed but symbols could not be loaded for partmgr.sys
*** WARNING: Unable to verify timestamp for amd_sata.sys
*** ERROR: Module load completed but symbols could not be loaded for amd_sata.sys
Probably caused by :[B]amd_sata.sys[/B]
BugCheck [B]9F, {3, fffffa800e4515a0, fffff80017199770, fffffa800e4407b0}[/B]
BugCheck Info: [URL="http://www.carrona.org/bsodindx.html#0x0000009F"]DRIVER_POWER_STATE_FAILURE (9f)[/URL]
Arguments:
Arg2: fffffa800e4515a0, Physical Device Object of the stack
Arg3: fffff80017199770, nt!TRIAGE_9F_POWER on Win7, otherwise the Functional Device Object of the stack
Arg4: fffffa800e4407b0, The blocked IRP
BUGCHECK_STR:  0x9F
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]0x9F_3_disk_IMAGE_amd_sata.sys[/B]
  BIOS Version                  1503
  BIOS Release Date             01/16/2013
  Manufacturer                  To be filled by O.E.M.
  Product Name                  To be filled by O.E.M.
[/FONT]
3rd Party Drivers:
nvhda64v.sys           Tue Jul  3 11:25:04 2012 (4FF30ED0)
hiber_storport.sys     Wed Jul 25 22:29:58 2012 (5010ABA6)
Rt630x64.sys           Mon Jul 30 12:03:12 2012 (5016B040)
RTKVHD64.sys           Tue Aug  7 06:49:39 2012 (5020F2C3)
usbfilter.sys          Tue Aug 28 21:27:12 2012 (503D6FF0)
amd_sata.sys           Mon Sep 17 04:40:39 2012 (5056E207)
hiber_amd_sata.sys     Mon Sep 17 04:40:39 2012 (5056E207)
amd_xata.sys           Mon Sep 17 04:40:43 2012 (5056E20B)
bcmwlhigh664.sys       Tue Oct 30 02:00:15 2012 (508F6CEF)
nvlddmkm.sys           Fri Jan 18 08:22:15 2013 (50F94C87)
[/FONT]
http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys
hiber_storport.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=usbfilter.sys
http://www.carrona.org/drivers/driver.php?id=amd_sata.sys
hiber_amd_sata.sys - this driver hasn't been added to the DRT as of this run. Please search Google/Bing for the driver if additional information is needed.
http://www.carrona.org/drivers/driver.php?id=amd_xata.sys
http://www.carrona.org/drivers/driver.php?id=bcmwlhigh664.sys
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
