Solved download speed different from speed test
lebanese
so i ran a speed test with several different website and they all said my download speed is between 5 Mbps and 8 Mbps :
however when i actually download something my download speed stay at 1 Mbps or when i watch videos ( youtube ) :cry:
i dnt have this problem with my phone !
thank u
    win 8.1 64
    lenovo Z500 touch 20221
    intel core i7 3612QM
    31900004WIN8 STD SGL
    8 GB DDR3
    nividia GeForce GT 740M , intel hd 4000
    1 TB HDD
    chrome
    win defender
    network adapter : intel(R) Centrino(R) Wireless-N 2230
lebanese
help help help why ??
    win 8.1 64
    8 GB DDR3
    1 TB HDD
    chrome
    win defender
lebanese
why its normal ? the download speed decreased by 80%
    win 8.1 64
    8 GB DDR3
    1 TB HDD
    chrome
    win defender
lebanese
yeah the same connecting
    win 8.1 64
    8 GB DDR3
    1 TB HDD
    chrome
    win defender
caperjack
Just the Janitor
not sure about the phone but I know from my own internet speed test results ,I get nothing like this when downloading from any site ,likely because of where the data is coming from .
Speedtest.net by Ookla - My Results
    win8.1.1 enterprise
    Hinze57
    AMD FX 6100 6core 3.30gHz
    gigibyte ga-78lmy-s2p
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    19" viewsonic/ 22"Samsung
    1680x1050
    128gig ssd Kingston
    80gig WD 10000 rpm spinner
    micro
    microsoft curve 200
    Logitech wireless M215
    high speed 20
    ie 11
    windows defender
    updated enterprise apr 2/14
lebanese
hmm . im sure something wrong . bcs on my phone the download speed its the same as the result of speed test
    win 8.1 64
    8 GB DDR3
    1 TB HDD
    chrome
    win defender
caperjack
Just the Janitor
what program do you use to show the download speed from youtube
    win8.1.1 enterprise
    Hinze57
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    1680x1050
    128gig ssd Kingston
    micro
    microsoft curve 200
    high speed 20
    ie 11
    windows defender
Enigma
The mostly like reason for your speed drops is that the results of these tests merely measure the fastest up/down speeds that your connection is capable of, what you get in real-world situations will usually be lower than what the tests say, because various factors come into play.
    Windows 8.1 Pro x64, Windows Server 2012 R2 x64
    Lenovo G700
    Intel Core i7-3632QM, 2.20 GHz
    Lenovo
    6 GB DDR3
    NVIDIA 720M, Intel HD 4000
    1 monitor
    1600x900 (max)
    1 TB HDD (5400 RPM), 1.5 TB HDD (5400 RPM) installed in a 12.7mm disc drive caddy
    Lenovo
    Lenovo
    Laptop/notebook keyboard/touchpad
    It varies, since I'm mobile most of the time
    Chromium (the open-source browser which Google Chrome is derived from)
    Kaspersky, Malwarebytes, Spybot, Privatefirewall
    I will add more information here later
Wullail
Active Member
Also....a lot of ISPs (mine included) give priority to packets being sent and received by these speedtest servers...
So they can point at the results and say 'look how fast our connections are'.
now , if only I could route all my browsing and downloading through them...... :geek:
    Windows 8 Pro
    6 GB
    1280 x 1024
    12 TB in 6 disks
    TX650
    G15
    Intellimouse 3.0
    100 Mbits
    Chrome
    Trend Micro
CountMike
On Speedtest, try other points in the world, not just the speed to your ISP, you'll see widely different results. When downloading, the speed is also proportional to ISP's speed and bandwidth to the rest of internet. Load on ISP's server and various points on the net to FTP where you are downloading stuff from can also vary so you can never be sure how fast downloading will be. At default, Speedtest will show you just network speed between you and your ISP. For real world monitoring you can use something like "DU Meter".
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
lebanese
task manager : Screenshot (119).png
and : Screenshot (120).png
so there no solution for this problem ?!
    win 8.1 64
    8 GB DDR3
    1 TB HDD
    chrome
    win defender
Enigma
@ CountMike: Thanks for the DU Meter mention, looks good. I'm also currently using an app called NetLimiter to limit up/down speeds per app, mainly for the ones that don't have internal limiters of their own.
    Lenovo G700
    Lenovo
    6 GB DDR3
    1 monitor
    1600x900 (max)
    Lenovo
    Lenovo
chev65
Closed
task manager : View attachment 34076
and : View attachment 34077
I'm sure you have a good reason for using outdated wireless G ?
This certainly isn't helping your situation and you may see some improvement going to Wireless N. :)
Your Intel 2230N adaptor is capable of using N but you need to set the router up to use the 802.11N only setting in order to achieve true wireless N speeds.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
CountMike
Afraid it's up to your ISP. May I ask what's the speed (down/upload ) you are paying for ? Looks like 8/1 Mn/s.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
CountMike
802.11 G can go up to 100 Mb/s I don't think he's paying for that much and getting less than 8.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
chev65
Closed
How about allowing others to help rather than admonishing their useful comments. ;)
The connection certainly won't be any worse using wireless N and the LAN speeds may increase x6. Wireless G is over ten years out of date, it's very unlikely than any Windows 8 drivers have been optimized to use an outdated wireless standard. I won't get into the potential problems associated with using outdated security and encryption. I won't be going back and forth with you on this bro so have a nice day. You are not only unhelpful to the Op but your comment is completely incorrect for a variety of reasons as already stated. :cool:
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
CountMike
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
lebanese
aha ok i cant wait to buy a new n router .
as my isp said i pay 50$ for 20 MB/s and a limit of 30 GB
after many downloads i can tell that the speed of download start at 6 Mbps after 1 min it drop to 1 Mbps and after 1 min its drop to 0.5 Mbps and stay at 0.5 Mbps to all download finish . and while im downloading i test the speed with speed test and it tell me its 6 Mbps
so weird
and guys is that true that wep encryption not good with win 8.1 ?
sorry for my english frensh educated
thank u guys
    win 8.1 64
    8 GB DDR3
    1 TB HDD
    chrome
    win defender
