Does Samsung Magician always need to be running?
MaXimus
1) Does Samsung Magician always need to be running to benefit from its OS optimizations/tweaks?
2) Also, what about RAPID Mode? does it also rely on Samsung Magician to work properly?
3) Is there a way to keep Samsung Magician running on startup, but not get a UAC prompt? All my other programs start with no UAC prompt so why does it need to prompt me everytime it starts?
    ALIENWARE 18 Laptop
    Intel Core i7-4940MX Extreme CPU @ 4 GHz
    Alienware 0FT9KT
    32 GB Kingston HyperX 1866MHz DDR3 PC3-14900 RAM
    Dual GeForce GTX 780M SLI 2x4GB GDDR5 RAM
    Realtek ALC668 HD Audio
    Dell 18.4" WLED FHD (1920 X 1080) TrueLife Display IPS 16:9 1080p [SDC4C48]
    2x SanDisk Extreme PRO 960GB SSDs + 850 EVO 1TB mSATA SSD
    Alienware TactX Keyboard
    Logitech G602 Wireless Gaming Mouse
    50 MBPS Download / 10 MBPS Upload
    ESET NOD32 Antivirus
MilesAhead
Eclectician
I've only looked at the OS optimization feature. It seems to be just a front end for setting Registry values. Once the Registry values are set, Magician running or not has no effect. Depending on the Registry setting, you may have to log off or restart for it to kick in.
The UAC is probably because programs that require running as Administrator can't be run immediately at startup withput triggering UAC. There are ways around it such as creating a scheduled task. But since it doesn't need to be running for the tweaks it may be moot.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Raedon 340 MB dedicated Ram
    Built in
    1366 x 768
    640 GB (spinner) Sata II
    Built in
    Touch pad
MaXimus
are you sure it doesn't need to be running at startup?? I still have my doubts man
    ALIENWARE 18 Laptop
    Alienware 0FT9KT
MilesAhead
Eclectician
Then check more than one source. The software publisher comes to mind.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Built in
    1366 x 768
    Built in
    Touch pad
MaXimus
I tried, they have no email to contact bro, I posted on their forums, not a single reply
will check more or I might call them to the USA
    ALIENWARE 18 Laptop
    Alienware 0FT9KT
MaXimus
I just called the online Tech Support (+1-800-726-7864) and they said there is no need for Magician to run on startup, once it has done the OS optimizations, it can safely be disabled from starting up automatically.
    ALIENWARE 18 Laptop
    Alienware 0FT9KT
